Updated Helix build,
Kodi/XBMC master from Sep 26 +
newclock4 commits.
Kodi/XBMC Master:
Master changelog
Newclock4 additions:
• [renderer] Avoid warning for too few buffers with bypass renderer
• [mmal] Increase number of render buffers
• [omxplayer] Fix bad audio when sample_fmt is not reported on Open
• fix null pointer dereference when invoking non-addon scripts
• squash: boost centre
• [mmalrenderer] Always use higher buffer_num. Avoids an ENOMEM failure
• remember user selected 3D modes between videos until playback ended
• handle stereoscopic mode of videos in mixed playlists
• [mmalcodec] squash: whitespace
• [mmalrenderer] squash: Make update logging only verbose
• [dvdplayer] exerimental: don't raise priority of audio thread
• [omxplayer] Don't sync up to passthrough audio packets - let GPU handle it
• fix wrong printf format mismatches
• [airplay] Updated: fix broken airplay with ios8 clients
GPU firmware from Sep 27 included:
• MMAL: Pass dec_params in opaque buffers
• gpioman: Reduce huge amount of log spam
• hdmi: add gencmd to limit rate of change of hdmi clock adjustment
• services: Avoid bad behaviour from calling init functions more than once
• Remove dts_whole_frames config option
• dtsbits: Handle parsing (and discarding) extension packets
To install Kodi/XBMC build, SSH to Pi:
wget -O kodi-14-20140928-nc4.tar.gz http://goo.gl/sSwWbW --no-check-certificate
pv kodi-14-20140928-nc4.tar.gz | tar xzf - -C /home/pi/.upgrade
sudo cp /home/pi/.upgrade/kodi-14-20140928-nc4/{fixup_x.dat,start_x.elf} /boot
ln -sfn /home/pi/.upgrade/kodi-14-20140928-nc4/xbmc-bcm /home/pi/.xbmc-current
sudo reboot
See post #1 for more info
