2013-10-19, 02:46
Hi everyone!
I see a lot of RaspBMC users that are interested in Kodi/XBMC test builds, therefor I started this thread.
This thread will contain unofficial Kodi/XBMC test builds for RaspBMC.
Note the difference, not Raspbmc builds, but only Kodi/XBMC builds.
Kodi 15 builds:
Updated Kodi 15 build 20141226 in post #1749
Helix builds:
Updated Helix build 20141216 in post #1731
Updated Helix build 20141130 in post #1722
Updated Helix build 20141125 in post #1710
Updated Helix build 20141120 in post #1703
Updated Helix build 20141120 in post #1697
Updated Helix build 20141118 in post #1689
Updated Helix build 20141115 in post #1688
Updated Helix build 20141113 in post #1685 (reboot/shutdown issue fixed, virtual suspend reversed)
Updated Helix build 20141112 in post #1674
Updated Helix build 20141111 in post #1669
Updated Helix build 20141110 in post #1665
Updated Helix build 20141109 in post #1654
Updated Helix build 20141106 in post #1644
Updated Helix build 20141105 in post #1638
Updated Helix build 20141103 in post #1616
Updated Helix build 20141102 in post #1572 Please read this before installing!
Updated Helix build 20141019 in post #1512
Updated Helix build 20141014 in post #1503
Updated Helix build 20141008 in post #1482
Updated Helix build 20141003 in post #1474
Updated Helix build 20140928 in post #1445
Updated Helix build 20140925 in post #1439
Updated Helix build 20140924 in post #1438
Updated Helix build 20140919 in post #1436
Updated Helix build 20140912 in post #1431
Updated Helix build 20140910 in post #1424
Updated Helix build 20140905 in post #1414
Updated Helix build 20140902 in post #1403
Updated Helix build 20140902 in post #1402
Updated Helix build 20140825 in post #1394
Updated Helix build 20140825 in post #1393
Updated Helix build 20140823 in post #1391
Updated Helix build 20140823 in post #1390
Updated Helix build 20140821 in post #1383
Updated Helix build 20140821 in post #1382
Updated Helix build 20140818 in post #1381
Updated Helix build 20140817 in post #1376
Updated Helix build 20140805 in post #1364
Updated Helix build 20140804 in post #1357
Updated Helix build 20140804 in post #1356
Updated Helix build 20140801 in post #1347
Updated Helix build 20140731 in post #1345
Updated Helix build 20140711 in post #1336
Updated Helix build 20140708 in post #1332
Updated Helix build 20140707 in post #1325
Updated Helix build 20140706 in post #1324
Updated Helix build 20140627 in post #1317
Updated Helix build 20140617 in post #1313
Updated Helix build 20140615 in post #1312
Updated Helix build 20140612 in post #1311
Updated Helix build 20140611 in post #1310
Updated Helix build 20140607 in post #1305
Updated Helix build 20140606 in post #1304
Updated Helix build 20140605 in post #1298
Updated Helix build 20140601 in post #1291
Updated Helix build 20140528 in post #1290
Updated Helix build 20140527 in post #1288
Updated Helix build 20140521 in post #1279
Updated Helix build 20140513 in post #1268
Updated Helix build 20140507 in post #1252
Updated Helix build 20140430 in post #1240
Updated Helix build 20140427 in post #1223
Older XBMC builds:
You can find all builds (old and new) here: http://goo.gl/WB41Xv
Older builds will no longer install directly from it´s forum post, and they might have different structure.
If you need to test older Helix Alpha or Gotham builds you have to download the specific build to your computer, upload it to your Pi and extract it.
Some notes regarding old Gotham builds:
• Builds prior to 20140313 does NOT include GPU firmware.
• Builds between 20131207 and 20140323 does NOT include dvdcss libraries, but it is enabled.
• Builds prior to 20131207 is compiled without dvdcss support entirely.
To install:
1. Download build/tarball from here: http://goo.gl/WB41Xv
2. Upload the tarball to your Pi (/home/pi/.upgrade/).
3a. On 140313 or later builds (firmware included), SSH to your Pi and run the following commands (and reboot):
Firmware files are included so no need to manually downgrade.
3b. On 140311 or earlier builds (firmware NOT included), SSH to your Pi and run the following commands (and reboot):
Remember that you might need to downgrade your firmware (download from git).
4. If you need dvdcss, see to that you have it installed on your system and run the following commands
(will only work with the 20131207 build and later, and not necessary on 140323 or later):
Recommendations
• Fresh guisettings.xml
• Recheck all settings after install as some things can change and/or revert to default
• Latest firmware from master (now included in builds)
• Addons not updated for latest Kodi/XBMC might not work properly. I recommend that you set it up from scratch.
Alternative players
Since nc4 there is no longer any need to set or choose different video players, Kodi will do it for you.
This feature has also gone into Kodi master tree since Sep 03 2014.
When it comes to music you can still choose between PAPlayer (default) and DVDPlayer.
OMXPlayer is now ”embedded” in DVDPlayer. You now have settings within the GUI to enable/disable different features (under Settings - Video - Acceleration):
• Select omxplayer or dvdplayer automatically
This will make Kodi choose which player to use. OMX (if enabled) will be default except for unsupported formats and DVD´s/ISO´s where DVDPlayer will be used.
• Allow hardware acceleration (OMXPlayer)
Enables OMXPlayer
• Allow hardware acceleration (OpenMax)
Enables DVDPlayer with HW acceleration
To see what player being used, bring up codec info when playing a video:
omx-h264 = omxplayer
mmal-h264 = dvdplayer with hardware acceleration
ff-h264 = dvdplayer withouth acceleration
Any settings in advancedsettings.xml regarding players should be removed.
Also, if you have a custom playercorefactory.xml in your userdata you should edit it (remove anything regarding OMX and DVDPlayer) or remove the file.
Update firmware
NB! From March 13 2014 and forward the firmware is included in the build, so no need to update firmware manually!
To update firmware, download firmware files and copy them to the vfat partition on your SD (/boot).
Latest official firmware from master tree
start_x.elf
fixup_x.dat
Update to latest firmware via SSH:
You can check what firmware you are running either in the Kodi/XBMC log or via SSH:
Misc.
If you run into trouble you can easily revert/change Kodi/XBMC build in Raspbmc settings.
If Kodi/XBMC does not start/work you can also revert to release version via SSH and run:
If for some reason Kodi/XBMC does not start/reload, try:
Delete old builds via SSH:
Kodi 15 builds:
Helix builds:
Older XBMC builds:
To install:
cd /home/pi/.upgrade
pv XBMC_BUILD_NAME.tar.gz | tar xzf - -C /home/pi/.upgrade
sudo cp /home/pi/.upgrade/XBMC_BUILD_NAME/{fixup_x.dat,start_x.elf} /boot
ln -sfn /home/pi/.upgrade/XBMC_BUILD_NAME/xbmc-bcm /home/pi/.xbmc-current
mkdir -p XBMC_BUILD_NAME
pv XBMC_BUILD_NAME.tar.gz | tar xzf - -C XBMC_BUILD_NAME
cd /home/pi/.upgrade/XBMC_BUILD_NAME/xbmc-bcm/xbmc-bin/lib/xbmc/system
cp /usr/local/lib/libdvdcss.so.2.1.0 .
ln -sf libdvdcss.so.2.1.0 libdvdcss.so.2
ln -sf libdvdcss.so.2 libdvdcss.so
Recommendations
Alternative players
Enables OMXPlayer
Update firmware
start_x.elf
fixup_x.dat
sudo wget -O /boot/fixup_x.dat http://goo.gl/ETC4mX --no-check-certificate
sudo wget -O /boot/start_x.elf http://goo.gl/f53WhZ --no-check-certificate
sudo reboot
vcgencmd version
Misc.
rm /home/pi/.xbmc-current
sudo initctl stop xbmc
sudo initctl start xbmc
rm /home/pi/name_of_build.tar.gz
sudo rm -R /home/pi/.upgrade/name_of_build
