What problem? The cnd thing? Disable it manually or wait for me to fix it. The best would be to update the cnd link to correct table sorter or to remove that file from the cnd option. I don't have time to fix it now. I'm in my own birthday party :p
When i go into the setting area CDN has a check box, I uncheck and hit save. The check box reappears (this actually happens on all the settings). Restarting the server doesn't help.
Happy Birthday...
Have a beer on me... where's the donate button?
So except from breaking cnd.. Anybody tested or found any bugs in the filter/search table?
I went into the database, it's fixed. Happy Birthday!
Mine seems to be a lot slower since the update yesterday. Used to load pretty much instantly but now seems to take a good few seconds longer.
Normally it would load the top menu bar then the dashboard content but now it seems to be stalling loading the top menu and dashboard together.
Would have been after the update on Tuesday I think. I honestly don't know, sorry.
Also when did the Latest Albums dashboard modules change? Although it looks good being the same as Movies and TV Shows the artwork is stretched as album art tends to be square.
2015-07-16, 09:53
(This post was last modified: 2015-07-16, 09:54 by hellow.)
Yesterday, you can still use the previous "look". (Look for old albums in dash settings), It's was a choice between a cropped and a stretched image.
Ahh ok no probs, I do like the new style as it looks really good with them all along the top being the same size.
Just needs some work to display the art correctly if there even is a way.
