2017-11-18, 22:22
Is it possible to add ,HEVC or H265 Codec to metadata selection page? Even manually
(2017-11-28, 11:57)JanM201 Wrote: Why is it not working with the settings I'm using in the beginningI think your skin compare the MPAA value only for "MPAA = Rated R" and not for "MPAA StartWith Rated R" or "MPAA Contains Rated R". This is something you can fix in the IncludesVariables.xml of your skin, but it whould be overwriten each time you update your skin. Also I don't know the exactly code that has to be used. I think it will be better to ask the skin dev for this additional changes.
(2017-11-28, 12:43)DanCooper Wrote:Perhaps using some kind of regex would help.(2017-11-28, 11:57)JanM201 Wrote: Why is it not working with the settings I'm using in the beginningI think your skin compare the MPAA value only for "MPAA = Rated R" and not for "MPAA StartWith Rated R" or "MPAA Contains Rated R". This is something you can fix in the IncludesVariables.xml of your skin, but it whould be overwriten each time you update your skin. Also I don't know the exactly code that has to be used. I think it will be better to ask the skin dev for this additional changes.
(2017-11-28, 14:04)redglory Wrote:Where would I use that?(2017-11-28, 12:43)DanCooper Wrote:Perhaps using some kind of regex would help.(2017-11-28, 11:57)JanM201 Wrote: Why is it not working with the settings I'm using in the beginningI think your skin compare the MPAA value only for "MPAA = Rated R" and not for "MPAA StartWith Rated R" or "MPAA Contains Rated R". This is something you can fix in the IncludesVariables.xml of your skin, but it whould be overwriten each time you update your skin. Also I don't know the exactly code that has to be used. I think it will be better to ask the skin dev for this additional changes.
(2017-11-28, 14:38)JanM201 Wrote: Dan,
See picture:
The release date for this movie is not scraping. With all my other movies it's scraping fine.
Any idea?
(2017-11-28, 14:49)DanCooper Wrote:Thanks. I changed it to TMDB & it's working fine now. For some reason it's not working with IMDB.(2017-11-28, 14:38)JanM201 Wrote: Dan,
See picture:
Any idea?
Works for me with latest build from komplex and TMDB scraper with media language "en-US". Any hint in the log?
(2017-11-29, 14:46)JanM201 Wrote:I've just moved to images positions from "hard coded" values to the theme XMLs: Github(2017-11-28, 14:49)DanCooper Wrote:Thanks. I changed it to TMDB & it's working fine now. For some reason it's not working with IMDB.(2017-11-28, 14:38)JanM201 Wrote: Dan,
See picture:
Any idea?
Just another question. See picture:
When I move the middle bar where only movies is in view, you can see a little bit of the disc art.
See next pic:
Now if I move the middle bar to the right so you can see all 3 tabs the discart disappears.
Is there a way that the discart can be moved to the left so it's also in view when the 3 tabs are displaying?
(2017-11-30, 03:04)AnthonyJS02 Wrote: Using latest build. For some reason I can’t get the watched status to column to show in movie list. Tried moving it up in list, unchecking some other visible columns no luck. It shows in tv shows just fine.Use the Reset button to rewrite the settings for the new column that is used as "Watched" state (I've changed that in one of my many commits in last moths. Do the same in tv show settings for each list):
