2016-06-11, 02:23
Ok thanks I ment right -eye and rio is what I use to test never auto switch
(2016-06-11, 02:03)hdmkv Wrote: Yes, still using this old graphics driver: GFX_Win7_8_8.1_64_10.18.10.3540
Re: left eye, that's like 90% of 3D BD's, so you shouldn't have to switch. About 10% are right-eye and most should auto-switch. For example 'Drive Angry' does, but not sure about 'Edge of Tomorrow', 'Rio' and others like 'The Hobbit' trilogy.
(2016-06-09, 07:53)Statikk Wrote: Does anyone know exactly what this refers to?
Quote:[3DBD] Added support of 3D-BluRay playback.
Is it support for playback from disc folder structure or something?
(2016-06-11, 16:13)hdmkv Wrote: What happens if you bypass your AVR and connect directly to 3D PJ?
(2016-06-11, 16:16)simbot41 Wrote: I don't seem however to be able to install any skins other than those that have official Jarvis support. I get a dependency error "xbmc.gui 5.10.0"The MVC builds are Krypton only; see post #1.
(2016-06-11, 16:16)simbot41 Wrote: Firstly my thanks to all who have contributed to this threa.
Amazing stuff. I just backed up my copy of Frozen 3D (for my daughter I swear) and not only is the 3D very impressive the picture is so much cleaner, colourful and vibrant in a good way.
Can anyone help me get around this. Even tried deleting the dependency but no luck
(2016-06-11, 16:20)movie78 Wrote:(2016-06-11, 16:16)simbot41 Wrote: Firstly my thanks to all who have contributed to this threa.
Not all the Skins are supported in Krypton, What Skin are you using?
(2016-06-11, 16:23)hdmkv Wrote: @movie78, the added support for BD menus is another unexpected treat, but looks like @afedchin has some work to support 3D menus.
(2016-06-11, 16:27)simbot41 Wrote:(2016-06-11, 16:20)movie78 Wrote:(2016-06-11, 16:16)simbot41 Wrote: Firstly my thanks to all who have contributed to this threa.
Ah I was hoping I wouldn't really break anything by using refocus as I like it the most.
Having said that I would rather have a really nice stable 3d at the moment
(2016-06-11, 16:31)movie78 Wrote:(2016-06-11, 16:27)simbot41 Wrote:(2016-06-11, 16:20)movie78 Wrote: Not all the Skins are supported in Krypton, What Skin are you using?
Try this Skin267343 (thread)
It also has ATMOS and DTS:X naming tag support.
(2016-06-11, 16:49)simbot41 Wrote:Let me know if you are interested in my color logo MOD.(2016-06-11, 16:31)movie78 Wrote:(2016-06-11, 16:27)simbot41 Wrote: Ah I was hoping I wouldn't really break anything by using refocus as I like it the most.
Thank you good sir
