2017-01-17, 21:29
beelink BT7 Atom X7 Z8700 unable to get 3d to function. Only plays in 2d mode. Is this chip compatible.
(2017-01-18, 01:56)Geoff29 Wrote:(2017-01-17, 15:28)hdmkv Wrote: Are you using your integrated Intel graphics card, and not the nVidia card?I'm using the Nvidia card.
(2017-01-18, 03:08)TheShoe Wrote: that chipset supports nvidia 3D vision. i think though you may need to install it separately? IIRC i had to do that on my macbook pro running win10 which defaults to the nvidia mobile chipset it has. from there both the kodi mvc build and jriver + madvr + lav worked for 3DI'm confused about what Nvidia 3D vision is, but I think I may already have it installed. I'm able to select stereoscopic 3D mode in the Nvidia control panel.
http://www.geforce.com/hardware/technology/3d-vision
(2017-01-17, 07:49)Geoff29 Wrote: When I try to play a 3D MVC Blu-ray, the screen goes black, then it returns to the Kodi menu screen, but the audio is still playing. There is no video. I followed all the instruction in the original post. Does anyone know what might be wrong?I'm ignoring what is posted after above reaction because I ask myself if you did put the "libmfxsw32.dll" in the Kodi install dir?
I'm using a HTPC with an i5-3570 CPU and Nvidia GTX 660.
(2017-01-18, 20:56)afedchin Wrote: libmfxsw32.dll isn't used wit HW accelerated decoding as at your screenshot.You are right, the libmfxsw32.dll was erased when installing the latest build?
(2017-01-12, 17:26)hdmkv Wrote: Yes, should work... I haven't seen any actual user reports using Intel HD Graphics 5500 yet however. 4600 yes, 6000 yes. If you get the i3-5005U, please let us know about 3D MVC on it.
(2017-01-20, 07:16)Charger Hellcat Wrote: Using a Windows 10 based tiny PC isn't an issue but there's a number of different NUC units that range in price quite dramatically.
I'd like to replace a Rasp Pi2 that is just SLOOOOOW and using OpenElec makes things even more difficult.
