20 Nov 2019 - TVDB Scraper v3.2.0 is now available which reinstates scraping. TVDB are still in the process of fixing a number of bugs so there may still be further breakages. See this post. 2901570 (post)
  • 58
  • 59
  • 60(current)
  • 61
  • 62
  • 187
  Thread Closed
v17 LibreELEC Testbuilds for x86_64 (Kodi 17.0)
(2016-06-18, 02:12)Milhouse Wrote:
(2016-06-18, 02:02)EricSol Wrote:
(2016-06-18, 01:37)Milhouse Wrote: Can you execute:
cat /storage/.kodi/userdata/addon_data/service.libreelec.settings/oe_settings.xml | paste
and paste the url, thanks.
There are no embedded custom urls in this build.
http://sprunge.us/XaDP
The only obvious difference is that you have a forward-slash (/) on the end of your custom url. Can't test this myself until tomorrow evening.
I tried with and without the slash, no difference
http://sprunge.us/KWcA
I've been trying to setup the addon v4.38.1. I'm not getting any v17, only v16 builds.
I addon the custom url but in the end when trying that, I get this message:
"No builds were found for RPi2.arm.
http://milhouse.libreelec.tv/builds/master/RPi2/
Please check the URL."
Not sure how to resolve this problem.
Also is there any plans to add Libreelec "Official Builds" to the addon?
Thanks in advance.Wink
(2016-06-17, 23:29)Roby77 Wrote:
(2016-06-17, 22:14)Roby77 Wrote:
(2016-06-17, 15:34)fritsch Wrote: post journalctl -a and
ls -l /storage/.config/forcedisplay | pastebinit
please
Hope it's correct...
https://www.dropbox.com/s/li4g9gnxbvs249...5.txt?dl=0
And
http://sprunge.us/diRJ
Thank you
@fritsch Could be useful xorg log ?
Attached again dr hdmi to see if resolve
Yes seems that i found out a problem in xorg
@fritsch and @Milhouse
here i have a two xorg log one with no boot problem and one with black screen
Boot perfect : https://www.dropbox.com/s/16xe1gifptmmr8...0.log?dl=0
Black screen boot: https://www.dropbox.com/s/3ihu9cbgqupe9x...0.log?dl=0
i'm not skilled but i see some difference about hdmi log
I see that a difference between that log is also this line
Output HDMI1 using initial mode 1920x1080 on
I tried also to set a custom xorg.conf
Also i set default hdmi 1 in setting/system default monitor
Tried 20/30 reboots/power off no problem
Switched on this morning again this problem Confused
@fritsch do you have any suggestion ?
the journalctl paste misses most of the information ... journalctl -a | pastebinit and use sprunge for the xorg logs.
First decide what functions / features you expect from a system. Then decide for the hardware. Don't waste your money on crap.
Maybe i must set advanced log in kodi ?
Thank you
New LibreELEC.tv Krypton build #0617: Generic
(Supercedes previous build)
# uname -a
Linux LibreELEC 4.6.2 #1 SMP Fri Jun 17 21:06:27 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160617210505-#0617-g2707304 [Build #0617]
Based on tip of LibreELEC.tv master (27073046, changelog) and tip of XBMC master (9248a823, changelog) with the following modifications:
  • Includes FernetMenta "VideoPlayer" patches
  • Includes latest kodi-platform master (c8188d82)
  • Includes latest libcec master (6d68d212)
  • Includes latest libnfs master (cdd1643c, ahead +28)
  • Includes latest p8-platform master (041a8c6c, ahead +1)
  • Includes latest addons: adsp.basic (2ae604e5), adsp.biquad.filters (01236bbe), adsp.freesurround (34f50406), asplib (da66f517), inputstream.mpd (3ac19c39, +15), inputstream.smoothstream (99b9c3c3, +1), peripheral.joystick (2db8029e), pvr.argustv (5f48dcec), pvr.demo (0fa9e1d0), pvr.dvblink (a92f1264), pvr.dvbviewer (3d0bea9a), pvr.filmon (8743511d), pvr.hdhomerun (b5ce9309), pvr.hts (acd1a6ac), pvr.iptvsimple (7a5a43f8), pvr.mediaportal.tvserver (172a273c), pvr.mythtv (e2b60252), pvr.nextpvr (150698b7), pvr.njoy (b5d65655), pvr.pctv (feed5990), pvr.stalker (fb24eda2), pvr.vbox (c6594819), pvr.vdr.vnsi (5498a8c1), pvr.vuplus (ea3b33f6), pvr.wmc (77af8daf)
  • Includes commits from xbmc/master, ahead +5 (FernetMenta)
  • Include [env] e7cbe9cb: xf86-video-intel: Explicitely disable TearFree and TripleBuffer
  • Include [env] ed774729: Intel: Implement Passthrough-Range
  • Include [env] 98c65e6a: Kodi: Use Limited Range by default
  • Include [env] patch: binary-addon: inputstream.rtmp
  • Include [env] patch: Add extra headers needed by 3D BD MVC
  • Include [env] patch: Bump libbluray - include MVC support
  • Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.*, os.* and peripheral.*
  • Include [env] patch: Add experimental splash video for RPi
  • Include [env] patch: Enable pvr addons, disable pvr updates
  • Include [env] patch: Enable other binary addons
  • Include [env] PR:432: build: start using .libreelec-unpack
  • Include [env] PR:433: libreelec: use build project directory for ccache
  • Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
  • Include [pkg] dd81c2f1: [librtmp] Update to 15-Dec-2015 from http://stream-recorder.com/forum/customi...16103.html (kodi)
  • Include [pkg] 441217d8: logging: Add microsecond timer to log messages (kodi)
  • Include [pkg] patch: drm/i915: Extend Fake HDMI live status to Valley View (linux)
  • Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
  • Include [pkg] patch: CSC: Remove average logic when saving NV12 surface on IVB+ (VAAPI fix) (libva-intel-driver)
  • Include [pkg] PR:26: fix save button in network config (service.libreelec.settings)
  • Include [pkg] PR:27: allow using custom update channels (service.libreelec.settings)
  • Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
  • Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
  • Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
  • Include [pkg] PR:9731: [WIP] 3dlut and simple ICC linking support for color correction
  • Include [pkg] PR:9803: [PeripheralCecAdapter] fix playback stopping on screensaver deactivated
Build Highlights:
  1. New VideoDB schema v106
Build Details:
  1. LibreELEC.tv:
    • mpd: enable build from clean (PR:459, 1 commit, 1 file changed)
  2. XBMC:
    • Fixes and improvements for ratings (PR:9907, 4 commits, 4 files changed)
    • Swig 3.0.10 (PR:9990, 2 commits, 2 files changed)
    • Use year in label2 when sorting by year (PR:9991, 1 commit, 1 file changed)
  3. inputstream.smoothstream:
    • bandwidth / maxres / remove url (99b9c3c3)
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
(2016-06-18, 09:20)CandyLuv Wrote: Hi,
v4.38.1 is the version which corresponds to the Leopold DevUpdate addon. This doesn't currently support LibreELEC. There is a fork of the DevUpdate addon which does support LibreELEC: 2319192 (post)
Also, this is the x86 thread... why are you trying to install an RPi2 build?
Note that #0617 has the lirc bump reverted.
There is a new build available, #0617x, with an updated lirc bump. Can those that have been having IR issues with the updated lirc please test #0617x and report if IR is now working as expected. Whether IR is working or not, please post:
systemctl status | pastebinit
dmesg | pastebinit
(2016-06-18, 10:39)Roby77 Wrote: Maybe i must set advanced log in kodi ?
Thank you
No it has nothing to do with kodi.
(2016-06-17, 23:44)EricSol Wrote:
(2016-06-17, 21:42)Guilouz Wrote: How is working update via LibreELEC addon ?
I have enable 'Show Custom Channels' and I have enter 'http://milhouse.libreelec.tv/builds/master/Generic/' for 'Custom Channel 1'.
I have set 'Update Channel' with 'Milhouse-8.0'. On available versions I see all updates, when I select an update, it tell me if I want update to newer version but when I select any version dialog close and nothing happens. No download progress.
Same problem here
http://sprunge.us/ZHbH
Can you execute:
I have this in oe_settings.xml :
<?xml version="1.0" ?>
<libreelec>
    <addon_config/>
    <settings>
        <system>
            <wizard_completed>True</wizard_completed>
            <ShowCustomChannels>1</ShowCustomChannels>
            <CustomChannel1>http://milhouse.libreelec.tv/builds/master/Generic/</CustomChannel1>
            <Channel>Milhouse-8.0</Channel>
        </system>
        <connman>
        </connman>
        <services>
        </services>
        <about>
        </about>
        <libreelec>
        </libreelec>
    </settings>
</libreelec>
 Estuary MOD V2
(2016-06-18, 14:17)Milhouse Wrote: Note that #0617 has the lirc bump reverted.
dmesg | pastebinit
Good news! It works! Smile Here are logs.
http://sprunge.us/DDaO
dmesg | pastebinit
http://sprunge.us/NjLf
http://sprunge.us/URTR
AppleTV 4K, LG 65E6 OLED TV, Marantz NR1606, Harmony Elite
(2016-06-18, 14:01)Milhouse Wrote: v4.38.1 is the version which corresponds to the Leopold DevUpdate addon. This doesn't currently support LibreELEC. There is a fork of the DevUpdate addon which does support LibreELEC: 2319192 (post)
HI,
Sorry about that. I've been online whole night into morning looking for an devupdate addon for Libreelec on all the different threads and got the 2 threads mixed up.
Thanks for still giving me some assistance.
Also is there an addon for "Official releases".
Thanks again and keep up the great work.
(2016-06-18, 19:31)CandyLuv Wrote: Also is there an addon for "Official releases".
The forked version is the only option for now.
dmesg | pastebinit
had been having issues with my MCE IR remote previously (can't remember which builds exactly), but works fine under 0617x
http://sprunge.us/KJbT
http://sprunge.us/iHAH
http://sprunge.us/eLPI
(2016-06-18, 10:33)fritsch Wrote: the journalctl paste misses most of the information ... journalctl -a | pastebinit and use sprunge for the xorg logs.
@fritsch
First switch on of beebox = black screen
LibreELEC:~ # journalctl -a | pastebinit
http://sprunge.us/UcXE
LibreELEC:~ # cat /var/log/Xorg.0.log | pastebinit
http://sprunge.us/GbSD
So i tried 3 reboot...no luck
Power off and again on and kodi load correctly
Here the log
http://sprunge.us/MQHa
http://sprunge.us/ghbM
  • 58
  • 59
  • 60(current)
  • 61
  • 62
  • 187
  Thread Closed
  • 11 Vote(s) - 3.91 Average
LibreELEC Testbuilds for x86_64 (Kodi 17.0)3.9111
