bobrap
Posting Freak
Just wanted to say thanks for a great skin and ask a few things. Would it be possible to add a larger image preview when selecting artwork? Is there a way to change the number of items shown on a widget? I use Recommended episodes from Library data Provider when using Aeon Nox Silvo. I set the number of items to five. In Madnox it seems that UpNext episode widget does about the same thing but displays 20+ items. Would like to limit it. If I setup a widget and get rid to the label by backspacing the title and then add a space, I can't access the widget using the keyboard up arrow. My current work around is us a . instead of the space. Hope this makes sense. Again, thanks and really enjoying the skin.
YOYIZDERZOMENEMOHOZEZAZEZDENDERIZHOZEZ
bobrap
Posting Freak
Thanks for the quick changes. One problem, can't change the number of widget items. A feature request for the future maybe? When onup to a widget item, would it be possible to add an option to display the movie/episode plot? Thanks.
2020-10-07, 00:56
(This post was last modified: 2020-10-08, 00:34 by quebert.)
Mr. V this skin is amazing, I looked around all the settings I could find and have a question.
cdart isn't showing up for cd's, I'm just getting the default blank disc. I use Artwork Beef and the cdart comes up in Aeon MQ8. I'm trying to figure out how to fix this, hopefully a way I can still get my cdart to still come up in Mq8 - Although after an afternoon with this skin I dunno how often I'll go back to MQ8. I understand this is alpha but I saw screenshots in this thread with cdart, so I'm guessing I'm just overlooking a setting somewhere.
Mr. V,
I use showcase view 98% of the time and I like the ratings information you have in dialogivdeoinfo. I believe I read you are now using Jurialmunkey's plug in and would like to add all the ratings to the info box on showcase view. You already have ratings and top #250. What file do I need to play with to add all the ratings that the plugin offers?
2020-10-18, 15:16
(This post was last modified: 2020-10-18, 17:55 by tymmy.)
Hello and thanks for your work. It took a little work of cleaning up my system but no to bad. I had to rename logo to clearlogo and cdart to discart in my music, but thanks for the hint of bulk renaming that went quick . ALL cleasrlogo and discart and showing up after a refresh, I am changing over 3 systems from aeon-madnox to your madnox and very pleased with all results so far. I have run into on block that i can't figure out. When I start playing music the screen never goes to now playing screen automatically, I have to hit the tab key for it to happen. I Know find it will go to the now playing screen automatically if I select 2 or more songs. I wondering if i have some setting off. This happens on all 3 systems. Any Ideas what's happing? (Edit) Well a hour later I know realize it may be acting as intended. I play 1 song it does not go to Now Playing. When I select a second song (even if it min later) it quicky jumps tp the now playing screen. and strays on it for all songs.
2020-10-20, 18:30
(This post was last modified: 2020-10-26, 00:58 by Dimetrixdemon.)
Hello again, did test the last verison of your madnox and it work's great.
Atmos\DTSX icons, actor's icons showing up now.
in many movies new clearlogo's, discart and other extra fanart images can't be found in fanart menu selection.
thanks for this great skin.
