2018-05-26, 11:30
(2018-05-22, 10:44)primaeval Wrote: version 0.0.52@primaeval seems to work your hint but now I getting the following error when I choose "Recording Once":
@kaable Your start and stop times didn't have a utc offset in them.
I've added some code to add " +0000" to them.
Your xmltv is from Webgrab so I assume the dates are in a valid format.
If IPTV Recorder needs an offset you'll have to add the tvg-shift offset into the m3u file.
See here for how to do it in the example.
https://kodi.wiki/view/Add-on:IPTV_Simple_Client#Usage
If you want to do a Portuguese translation I'll add it in for you.
txt:08:07:11.123 T:1584395168 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.TypeError'>
Error Contents: record_once() takes at least 3 arguments (4 given)
File "/storage/.kodi/addons/plugin.video.iptv.recorder/main.py", line 2869, in <module>
plugin.run()
File "/storage/.kodi/addons/script.module.xbmcswift2/lib/xbmcswift2/plugin.py", line 332, in run
items = self._dispatch(self.request.path)
File "/storage/.kodi/addons/script.module.xbmcswift2/lib/xbmcswift2/plugin.py", line 306, in _dispatch
listitems = view_func(**items)
File "/storage/.kodi/addons/plugin.video.iptv.recorder/main.py", line 2065, in full_service
service_thread()
File "/storage/.kodi/addons/plugin.video.iptv.recorder/main.py", line 2100, in service_thread
record_once(programmeid=uid, do_refresh=False, watch=watch, remind=remind)
TypeError: record_once() takes at least 3 arguments (4 given)
08:10:14.859 T:1945854144 ERROR: Control 602 in window 12901 has been asked to focus, but it can't
Can you help me ?
thanks in advance
