2019-03-07, 11:58
(2019-03-07, 03:30)mardukL Wrote:Tested and finally everything is in it's right place; I found only a minor glitch:(2019-03-04, 07:26)Fuchs2468 Wrote: ....HI, can you or other PVR user report back if Time/Duration Labels and Progressbar is fixed now ?
Did all editings "blind" as i could not test.
Heres are the changes, from/for git hub(version)
https://github.com/marduklev/skin.titan....aa9b5f9be5
Also Radio could be interesting, espeacially for slim OSD.
- when "use slim osd panel" and "use default OSD" options are enabled, the "remaining time" info at far right of time bar is missing, whereas it is correctly showed when both previous options are disabled (or when plaiyng anything else than PVR).
Actually it's something I really don't care much, just noticed it and wanted to point out; right now you guys fixed one of the most annoying issues for me, your work is much much appreciated, thx!
Thank you guys for all your work!
