Add-on could not be loaded
I am running LibreElec Kodi on Raspberry Pis 2 and 3. I have one out of five Pis without this problem.
I did a fresh install of the OS on a new sdCard. The first thing I did was install NextPVR add-on. I got an error after installation. I configured the add-on and rebooted. I get and error dialog box stating the addon could not be loaded.
As I mentioned all other PIs work. I have a wired connection. The backend works fine and I can see the webserver app page from inside and outside my network.
If I run an update from the repository menu the add-on starts to run and works fine.
Any suggestions would be great. Also I dont know how to get the logs from a Pi.
The instructions are here... debug log (wiki)
1.Enable debugging in Settings>System Settings>Logging,
2.Restart Kodi
3.Replicate the problem.
4.Upload the log to Kodi Paste Site manually or use the Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file (wiki)
In both instances, you should see the word DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
My Signature
Links to : Forum rules (wiki) | Banned_Add-ons (wiki) | Debug Log (wiki)
Links to : HOW-TO:Create_Music_Library (wiki) | HOW-TO:Create_Video_Library (wiki)  ||  Artwork (wiki) | Basic controls (wiki) | Import-export library (wiki) | Movie sets (wiki) | Movie universe (wiki) | NFO files (wiki) | Quick start guide (wiki)
(2019-07-17, 03:23)Karellen Wrote: To receive meaningful assistance you will need to provide a full debug log.
2.Restart Kodi
I have no idea if I used pastebin correctly but here is my first try:  fobesobilo.kodi (paste)
You are almost there. We need the full log from start to end, not a portion of it. Try again and remember to capture the problem. Lots of emby errors there also making it a more complex log.
My Signature
(2019-07-17, 04:41)Karellen Wrote: You are almost there. We need the full log from start to end, not a portion of it. Try again and remember to capture the problem. Lots of emby errors there also making it a more complex log.
 yitoxijiga.kodi (paste)
Yep, better. Hopefully emveepee will see the problem when he comes online.
My Signature
(2019-07-17, 04:56)Karellen Wrote: Yep, better. Hopefully emveepee will see the problem when he comes online.
Thank you for the help. Really appreciate it.
I'd confirm that you have the correct IP.
2018-06-22 06:12:00.616 T:1787974512 INFO: easy_acquire - Created session to http://192.168.1.11
2018-06-22 06:12:00.617 T:1787974512 ERROR: CCurlFile::FillBuffer - Failed: Couldn't connect to server(7)
I see that you also have some troubles initially connecting to emby on a different server.  I would make sure LE is configured to use
"Wait for network before starting Kodi"
Martin
(2019-07-17, 05:12)emveepee Wrote: I'd confirm that you have the correct IP.
Martin
The server is a static IP. I will check the "wait for network". It would be great if that was all it was. I will report back.
Several tests and it seems like that's the issue. I feel like crawling under a tech rock but great that's what it was.
(2019-07-18, 03:17)hootie318 Wrote: Several tests and it seems like that's the issue. I feel like crawling under a tech rock but great that's what it was.
No need to crawl under a rock.  That's one of those "obvious once you know about it" settings that I kind of wish was enabled by default given how much Kodi depends on a functioning network.
Providing a debug log: Log_file/Easy (wiki)
Leia Estuary mod: 333143 (thread)
Artist Slideshow: Add-on:Artist_Slideshow (wiki)
SpeedFan Information Display: Add-on:SpeedFan_Information_Display (wiki)
  • 0 Vote(s) - 0 Average
Add-on could not be loaded00
