Currently getting 'script failed to load' message on Kodi 5.0.5 , cuboxi 4i
tried reinstalling, got the APi key everything looks fine...
Any suggestions?
(2015-01-19, 05:59)ampedandwired Wrote: [ -> ] (2015-01-19, 02:57)vijayk416 Wrote: [ -> ]It seems the fix didn't work. My system automatically rolled to 1.14.1 and it has stopped working - I get an error when trying to launch the addon. I noticed that the files that irsy mentioned are no longer in the folder structure. If I was going to try and replicate the same fix with this version, which files should I modify/delete?
The oauth2 module is now loaded from "<kodi_home>/addons/script.module.oauth2". You'll find "_version.py" file in there under "lib/oauth2".
There's another potential fix though that I wouldn't mind someone using OpenELEC trying out, because if it works I might be able to roll it into the plugin to fix the issue permanently. Download the pyutil package and extract it into <kodi_home>/addons/plugin.audio.rdio/lib. If you try this let me know if it works.
I'll try and get OpenELEC running in a VM in the meantime so I can try some stuff myself.
I can also confirm this works perfectly on OpenElec V 5.0.8, Kodi V14.2, Rdio V 1.14.1 . Would be great if this could be rolled into the plugin. Thanks ampedandwired, three happy uses here once again
Since the half of June I'm getting an error: Check your API credentials in plugin settings.
It worked before. API pass etc is correct. Has it something to do with the new OAuth2.0. I'm using the OAuth1.0a. On the mashery dashboard you can see that it worked before:
What could be the issue?
I can also confirm that I'm getting the same error, I rechecked the settings.xml and the codes are correct. Also, I have reinstalled the addon and it still does not work.
Rdio worked perfectly fine until two days ago. I can still access my account through the web interface, just not through Kodi.
My addon and Openelec system are fully up-to-date.
can i make a requst.
possible for tital and UFC
Same issue here. I'm using AppleTV and am getting script failed errors. I;ve triple checked all my details which were working fine for 2 years up until a couple of days ago. Any ideas?
Cheers,
Tim
Any idea when we'll get a fix?
When I try to apply for an Rdio API account, I get the following message "Registration is currently disabled"
What can I do about this?
I got the same msg. as llevin but i can apply for oauth 2.0 api without prob.
But cant login to rdio using that in xbmc
no prob in logging in to web interface
Really like this addon... shame it seems abandoned for the moment
Ok... instead of moaning I just made some changes to get this working with Rdio OAuth2.0.
Here's the Pull Request:
https://github.com/ampedandwired/rdio-xbmc/pull/18
If anyone wants to test it feel free to get it from my Repo directly here:
https://github.com/bluezed/rdio-xbmc/rel...ag/v1.15.2
You'll need to sign up for a new OAuth2.0 application on the Rdio website here:
http://www.rdio.com/developers/create/
For URL and Redirect URI you can enter any URL for now...
And then enter the Client ID and Client Secret into the Addon settings.
Then when you start the Addon you get prompted for an Authorization-Key.
You need to go to this website:
https://www.rdio.com/device/
You might have to log into your Rdio account there and then enter the key that's displayed in the dialog.
Then after a few seconds the addon should get the authorization and should be good to go
Note that streaming full songs only seems to work with a paid for subscription at the moment. If you've got a free Rdio account then you'll only get previews of the songs...
Guess they got more strict with the new API
Hope this helps getting this Addon back on track though...
thank you very much bluezed! i will test this tomorrow.
