I installed tvheadend as described in the post #179
sudo apt-get install curl
curl http://apt.tvheadend.org/repo.gpg.key | sudo apt-key add -
sudo nano /etc/apt/sources.list
add this line in the end of file:
deb http://apt.tvheadend.org/unstable wheezy main
sudo apt-get update
sudo apt-get install tvheadend
TVHeadend running around was also created during installation user named HTS and tvheadend is installed in /home/hts/.hts
I want the update version to latest git and for example change the configure. I do this:
chroot /volume1/@appstore/debian-chroot/var/chroottarget /bin/bash
cd home
git clone https://github.com/tvheadend/tvheadend (it will be latest!)
cd tvheadend
./configure --prefix=/usr --enable-bundle --disable-avahi
make
make install
But tvheadend did not update. I know because on my old DS213 afetr this update and configuration have option transcoding in option>configuration>general and now have not transcoding option avaible. In this and still have version 3.9.373 whezzy
Btw, I contacted the support about my DVB-S2 Skystar USB HD on armadaxp. It would be nice if you contacted them about your HDHR and 5.0 Only they require kernel debugging, for this will need to temporarily remove third-party packages. And again have to temporarily install 5.0. But they will think and work, now half of the devices stated in the compatibility sheet doesn't work on half of the DS
(2014-01-27, 21:47)aisman Wrote: [ -> ]@Smiggel
you are wellcome
I have just one small issue left. For some reason I can not access mysql anymore with my XBMC system. Also phpMyAdmin on the NAS will not connect anymore. Do you know what this can be?
Did you see what version installed from repo? The main git hasn't been updated for 10 days, you are trying to install new, but it's up to date.
(2014-01-27, 21:56)aisman Wrote: [ -> ]Btw, I contacted the support about my DVB-S2 Skystar USB HD on armadaxp. It would be nice if you contacted them about your HDHR and 5.0 Only they require kernel debugging, for this will need to temporarily remove third-party packages. And again have to temporarily install 5.0. But they will think and work, now half of the devices stated in the compatibility sheet doesn't work on half of the DS
I will contact them about it. Would be a shame not being able to upgrade to 5.0 because of this problem.
(2014-01-27, 22:01)Smiggel Wrote: [ -> ] (2014-01-27, 21:47)aisman Wrote: [ -> ]@Smiggel
you are wellcome
Is there big loading of RAM? Did you install update-4?
(2014-01-27, 22:02)aisman Wrote: [ -> ]Did you see what version installed from repo? The main git hasn't been updated for 10 days, you are trying to install new, but it's up to date.
Yes i see
3.9.373~g55c2bbb~wheezy
But i want install version without wheezy and with default option transcoding show in GUI.
And if so what I wrote as I was doing the update is correct?
(2014-01-27, 22:03)aisman Wrote: [ -> ] (2014-01-27, 22:01)Smiggel Wrote: [ -> ] (2014-01-27, 21:47)aisman Wrote: [ -> ]@Smiggel
you are wellcome
Hmmm, nevermind. Have no idea what happened, but it suddenly worked.
Really don't get it.
Oh yes, after manually updating to 4.3 I let the NAS upgrade itself to 4.3-4
if it is /usr/bin/tvheadend in future ./configure -- prefix=/usr
you may now do this
apt-get remove tvheadend
go to your building od tvheadend and
Yes
root@Synology_DS713:/home/tvheadend# which tvheadend
/usr/bin/tvheadend
In update i describe in post #256 i use:
After apt-get remove tvheadend , the app was deleted.
I go to /home/tvheadend where clone git and do
make install and:
root@Synology_DS713:/home/tvheadend# make install
CC tvheadend
install -d /usr/bin
install /home/tvheadend/build.linux/tvheadend /usr/bin/tvheadend
install -d /usr/share/man/man1
install /home/tvheadend/man/tvheadend.1 /usr/share/man/man1/tvheadend.1
for bundle in docs/html docs/docresources src/webui/static data/conf data/dvb-scan; do \
mkdir -p /usr/share/tvheadend/$bundle ;\
cp -Lr /home/tvheadend/$bundle/* /usr/share/tvheadend/$bundle ;\
done
find /usr/share/tvheadend -name .git -exec rm -rf {} \; &>/dev/null || /bin/true
Nothing right now I do not understand.
and what you are not understand? You installed tvheadend. All is good.
But now i want to update this to latest git and with my option config as i updated in my old DS213 as describe very simple.
After remove and make install webgui didnt work:
http://adres ip:9981
didnt display
What do you mean in "option config"? Your config in ./configure --blah --blah --blah
ok works ok. I must stop and start /etc/init.d/tvheadend
