(2014-03-26, 13:10)gebruikerh Wrote: [ -> ] (2014-03-26, 12:32)Smiggel Wrote: [ -> ] (2014-03-26, 12:28)gebruikerh Wrote: [ -> ]Ok learned Russian :-)...but downloaded both packages: drivers and the latest version of TVH3.9 you made in post 353.. Hopefully I will get a time slot to night to test it.
Keep you posted and Aisman thanks for al the effort until now
Did the download link work for you frmo post 353? I tried it too, but download does not start.
[Update] Nevermind. See the other url now. Did not see it before. :-)
Only the link works ...you need google translate to understand some Russian or just start clicking . But I downloaded it with the link.
I just use status bar to see download link/url. Most right button is for comments if i'm correct
(2014-03-26, 13:29)samukas Wrote: [ -> ] (2014-03-26, 12:58)schumi2004 Wrote: [ -> ] (2014-03-26, 12:56)samukas Wrote: [ -> ]I hadn't seen it... Only for ARM though
You didn't mention architecture
You're right... Got all excited there for a moment.
I've got a DS3612xs with Intel processor, but so far I haven't been able to find an SPK for TVH3.9, or compile one myself.
I can build one also if needed but takes a while since I never build for Intel on this machine so i need to re-download stuff.
(2014-03-26, 13:37)aisman Wrote: [ -> ]I'll make it today. Coming soon :-)
(2014-03-26, 12:58)schumi2004 Wrote: [ -> ]I can build one also if needed but takes a while since I never build for Intel on this machine so i need to re-download stuff.
Wow, thanks to both of you
(2014-03-26, 15:45)aisman Wrote: [ -> ]tvh-3.9.438 for intel
Thanks for that, aisman.
However, like other, I seem to be having problems downloading from box.com - the download won't even start. Any change for another hoster?
Are there any results available yet? :-) Really curious if it is working on dsm 5 or not.
Ok guys tested the driver package. It possible to select the correct DVB. I'm my case DVB-C (only the first time). But after klikking on apply I get operation faild..so not sure what is wrong here. Just for the recorded I have update it to DSM 5.1 (due to fact that I had some problems with external USB drives...still have..
If need to send any log's or so. Please let me know how to. And I will provide them overhere.
ok, will create test 2 pack, but it will be tomorrow. You can try to install drivers manually (I'll share it, and comands), if it will be works correctly, then I'll make a package.
Ok great i will try it toight
Hi iasman could you maybe post the instruction how to install the drivers manually? Maybe I have some time today or I will try it tomorrow or sunday
thx!
I trired the intel package on my DS 1512+ It installed but wouldn't start. any ideas on what could be wrong.
(2014-03-28, 19:59)zikronix Wrote: [ -> ]I trired the intel package on my DS 1512+ It installed but wouldn't start. any ideas on what could be wrong.
I forgot to mention it as I`ve been quite busy, but I got the same behaviour on my DS3612xs
(2014-03-28, 21:26)samukas Wrote: [ -> ] (2014-03-28, 19:59)zikronix Wrote: [ -> ]I trired the intel package on my DS 1512+ It installed but wouldn't start. any ideas on what could be wrong.
Ok so its not just me. Im willing to try anything to get this thing working properly.
Im running a DS1512+ and DSM 4.3
