Full Version: HOW-TO Compile Tvheadend & HDHomerun on Synology NAS
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35
Thanks for the advice hoontune! I scp'd the files in the link (dvb_hdhomerun_core.ko, dvb_hdhomerun_fe.ko, dvb_hdhomerun.ko) to /opt/dvb_native. Now getting this when I try to run my start_homerun script.
DS212J> ./start_homerun
insmod: can't insert '/opt/dvb_native/dvb-core.ko': No such file or directory
insmod: can't insert '/opt/dvb_native/dvb_hdhomerun_core.ko': File exists
insmod: can't insert '/opt/dvb_native/dvb_hdhomerun.ko': File exists
insmod: can't insert '/opt/dvb_native/dvb_hdhomerun_fe.ko': File exists
making node hdhomerun_control 57
mknod: `/dev/hdhomerun_control': File exists
./start_homerun: line 30: /opt/dvbhdhomerun/userhdhomerun/build/userhdhomerun: not found
Creating DVB device nodes to major device #212...
mknod: `/dev/dvb/adapter1/frontend0': File exists
mknod: `/dev/dvb/adapter1/demux0': File exists
mknod: `/dev/dvb/adapter1/dvr0': File exists
DS212J>
Sorry original files have been deleted from Redmine forum. Download the dvb-core.ko file from mediafire and put it with the other drivers.
Thanks for uploading the file for me! I'm now getting this message when I try to run start_homerun
./start_homerun: line 2: ad: not found
./start_homerun: line 31: /opt/dvbhdhomerun/userhdhomerun/build/userhdhomerun: not found
cut: /sys/class/dvb/dvb0.frontend0/dev: No such file or directory
mknod: missing operand after `212'
Try `mknod --help' for more information.
cut: /sys/class/dvb/dvb0.demux0/dev: No such file or directory
cut: /sys/class/dvb/dvb0.dvr0/dev: No such file or directory
cut: /sys/class/dvb/dvb1.frontend0/dev: No such file or directory
cut: /sys/class/dvb/dvb1.demux0/dev: No such file or directory
cut: /sys/class/dvb/dvb1.dvr0/dev: No such file or directory
DS212J>
I'm not sure what I'm doing wrong. This is the list of commands I ran in this order. Am I missing something?
wget http://ipkg.nslu2-linux.org/feeds/optware/cs08q1armel/cross/stable/syno-mvkw-bootstrap_1.2-7_arm.xsh
chmod +x syno-mvkw-bootstrap_1.2-7_arm.xsh
./syno-mvkw-bootstrap_1.2-7_arm.xsh
reboot
ipkg update
ipkg upgrade
ipkg install optware-devel
ipkg install git
ipkg install openssl
ipkg install gcc
ipkg install openssl-dev
mkdir /opt/dvb_native
scp dvb_*.files
cd /opt
vi start_homerun
chmod +x start_homerun
./start_homerun
Maybe best to try the spk these guys have built:
http://forum.synology.com/enu/viewtopic....90&t=55075
Thanks! I ended up doing that and it worked out great. And thanks again for your help!
Hi all! Here a new tvheadend-master for arm.
(2013-10-23, 22:09)aisman Wrote: [ -> ]Hi all! Here a new tvheadend-master for arm.
Thanks for posting it here. Only read that the automatic recorder is messed up in 3.5.245?
Debian on ppc-qoriq does not work, most likely due to the fact that debian does not support all processors of PPC. But I was able to build needed toolchain and made spk package. Enjoy Smile
UPD for arm-users:
I was wrong about debian-chrot from Sinocommunity, it works fine, and we'll not have the pain of scripts mount DVB. Soon I will correct package and will give instruction.
Thank you! Looking forward to the instructions! :-)
This is a guide for the installation and building yourself of the next tvheadend, only for arm-processors, not for armhf and qoriq.
1. Install python 2.7 from Synocommunity. Wait until python end all of its operations and stop loading processor. After this reboot better.
2. Install debian-chroot from SynoCommunity. This process is not fast, make sure it has the status of "enabled".
3. Put (updated) this package to /volume1/@appstore/debian-chroot/var/chroottarget/home
4.
chroot /volume1/@appstore/debian-chroot/var/chroottarget /bin/bash
5.
apt-get update && apt-get dist-upgrade -y
6.
updated
apt-get install build-essential automake autopoint python ncurses-dev libssl-dev pkg-config zlib1g-dev gettext git curl libgc-dev libcurl4-openssl-dev -y
7. Install tvheadend
We are still inside of debian:
cd home
dpkg -i tvheadend-3.9.277-syno-armel.deb
We need to run tvheadend with the start of system.
a) put this file to /usr/syno/etc.defaults/rc.d/ or create it yourself:
S99debian.sh
#!/bin/sh
chroot /volume1/@appstore/debian-chroot/var/chroottarget/ /root/runapps.sh &
b) put this file to /volume1/@appstore/debian-chroot/var/chroottarget/root/ or create it yourself:
runapps.sh
#!/bin/bash
sleep 40
/etc/init.d/tvheadend start
cd /root
chmod +x runapps.sh
exit
We are in the host as root:
chmod +x /usr/syno/etc.defaults/rc.d/S99debian.sh
finally
reboot
______________________________________________________________
Now you can build yourself tvheadend:
cd home
git clone https://github.com/tvheadend/tvheadend
cd tvheadend
./configure --prefix=/usr --enable-what-you-want --disable-what-you-want
make
make install
exit
reboot
Thanks for the guide. Going to try it soon!
Hi there!
tvheadend 3.9.277 for ppc (qoriq) here, for armhf (armadaxp) here.
(2013-12-06, 08:52)aisman Wrote: [ -> ]Hi there!
Hi
Could you compile spk file for me new TVHeadend version 3.9 for Synology DS213 wit processor Marvell Kirkwood mv6282 armv5te (arch 88f6281)
Please...
