(2013-12-23, 14:43)pepeEL Wrote: [ -> ] (2013-12-23, 14:39)aisman Wrote: [ -> ] (2013-12-23, 14:08)pepeEL Wrote: [ -> ]Where is support/configure.inc ? On github SC i dont find it.
Are you kidding me? This is file of tvheadend.
(2013-12-23, 14:37)pepeEL Wrote: [ -> ]I did exactly as you write but do not have access because the debian chroot are other powers than the DSM.
updated
I'm sorry but I do not know so well ... But surely only pulls from github git from SC and everything on the fly unless you are doing and attracts source of tvheadend from github.
Ok i try your second...
clone tvheadend
rename tvheadend folder to tvheadend-3.9.279
cd tvheadend-3.9.279
tar -pczf tvheadend-3.9.279.tar.gz
put archive to your nas ( to folder with anonimous ftp access)
on compiling machine
change Makefile on /spksrc/cross/tvheadend (change PKG_VERS; PKG_EXT; PKG_DIST_SITE) for example:
PKG_NAME = tvheadend
PKG_VERS = 3.9.279
PKG_EXT = tar.gz
PKG_DIST_NAME = $(PKG_VERS).$(PKG_EXT)
PKG_DIST_SITE =
ftp://192.168.1.4/src-tvh/
PKG_DIR = $(PKG_NAME)-$(PKG_VERS)
and change Makefile in spk/tvheadend:
SPK_NAME = tvheadend
SPK_VERS = 3.9.279
SPK_REV = arm
SPK_ICON = src/tvheadend.png
DSM_UI_DIR = app
DEPENDS = cross/busybox cross/$(SPK_NAME)
MAINTAINER = pepeEL
DESCRIPTION = Tvheadend is a TV streaming server for Linux supporting DVB-S, DVB-S2, DVB-C, DVB-T, ATSC, IPTV and Analog video \(V4L\) as input sources. It also comes with a powerful and easy to use web interface both used for configuration and day-to-day operations, such as searching the EPG and scheduling recordings. Even so, the most notable feature of Tvheadend is how easy it is to set up: Install it, navigate to the web user interface, drill into the TV adapters tab, select your current location and Tvheadend will start scanning channels and present them to you in just a few minutes
DESCRIPTION_FRE = Tvheadend est un serveur de streaming pour linux gérant les sources DVB-S, DVB-S2, DVB-C, DVB-T, ATSC, IPTV et video analogique \\\(V4L\\\). Il possède aussi une interface web puissante et ergonomique pour la configuration tout comme l\\\'utilisation au quotidien : recherche EPG ou plannification d\\\'enregistrements. Le principal point fort de Tvheadend réside avant tout dans sa facilité d\\\'utilisation : installez-le, naviguez au travers de son interface web, choisissez votre adaptateur TV dans l\\\'onglet dédié ainsi que votre localisation et Tvheadend recherchera les cannaux et vous les affichera en seulement quelques minutes
ADMIN_PORT = 9981
RELOAD_UI = yes
DISPLAY_NAME = Tvheadend
CHANGELOG = "Update to version 3.9.279"
renove digets,
remove -Werror (not required with SC-compiling), remove 268-269 lines
