2014-01-27, 22:50
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35
2014-01-27, 22:50
On my DS713+ i also do this as the same :
We need to run tvheadend with the start of system.
a) put this file to /usr/syno/etc.defaults/rc.d/ or create it yourself:
S99debian.sh
#!/bin/sh
chroot /volume1/@appstore/debian-chroot/var/chroottarget/ /root/runapps.sh &
b) put this file to /volume1/@appstore/debian-chroot/var/chroottarget/root/ or create it yourself:
runapps.sh
#!/bin/bash
sleep 40
/etc/init.d/tvheadend start
We are still inside of debian:
cd /root
chmod +x runapps.sh
2014-01-27, 22:51
shure!
2014-01-27, 22:51
Yes i install as root. And what ?
But instalation create user "hts".
2014-01-27, 22:56
(2014-01-27, 22:51)pepeEL Wrote: [ -> ]Yes i install as root. And what ?
It works? Excellent! Now try not to remember, and understand what you did, and why it works
2014-01-27, 22:58
I do not really know why it works ... miracle
I think it is too difficult for me to linux. I need simple tips as it was for the arm.
It is a pity that you have to install from source wheezy and then delete and do make install. It can not be easier.
2014-01-27, 23:03
(2014-01-27, 21:38)Smiggel Wrote: [ -> ]@aisman Thank you! :-)
I have successfully restored my NAS back to 4.3! TVHeadend is working perfectly again.
Did however change one thing! Did the following:
1. Edited /etc.defaults/VERSION
2. Set the following values:
majorversion="4"
minorversion="3"
buildphase="release"
buildnumber="3776"
smallfixnumber="0"
builddate="2013/09/16"
3. Now go to the configuration screen and go to DSM and manual update to 3810.
4. Wait for the system to update.
Because I set the buildnumer to 3776 the system does not get stuck after updating and does start without problems! The system fully boots and loads the DSM 4.3. :-)
Really glad it all worked out. Good to know I can always go back safely. :-)
Nice when a person is able to think Since my armadaxp was only on 3810 - I forgot to offer you do it with 3776 And with 411j completely forgot about it. Cool improvement!
2014-01-27, 23:11
(2014-01-27, 23:03)aisman Wrote: [ -> ](2014-01-27, 21:38)Smiggel Wrote: [ -> ]@aisman Thank you! :-)
majorversion="4"
minorversion="3"
buildnumber="3776"
smallfixnumber="0"
Lol, well all the credits go to you! Could not have done it without your help!
2014-01-27, 23:12
(2014-01-27, 22:58)pepeEL Wrote: [ -> ]It is a pity that you have to install from source wheezy and then delete and do make install. It can not be easier.
But on my 414 I do it without installing from repo. Just it better for you I create a user, configure the system, install the packages and as user install tvheadend. Then copy two files, set the user and all is works When you will have time - will try to do everything from begining
2014-01-27, 23:14
Can you describe step by step this
Yeasterday i try.
2014-01-27, 23:38
You mean tomorrow
1. Backup sh files to not re-create them.
2. Backup the files from /etc/ ...
3. remove DC
4. Install Dc.
5.apt-get install sudo mc locales openssh-server xterm build-essential automake autopoint python ncurses-dev libssl-dev pkg-config zlib1g-dev gettext git curl libgc-dev libcurl4-openssl-dev-y
5.5. dpkg-reconfigure locales (set en_US utf8 and pl_PL utf8, then you can set as default pl_PL)
dpkg-reconfigure tzdata
6. adduser pepeEL then set password for pepeEL
7. adduser pepeEL sudo
7.5 add this line to /home/pepeEL/.profile: export LANG=pl_PL.UTF-8
8. Change port 22 to 2222 at /etc/ssh/sshd_config
9. Add line to runapps.sh: /etc/init.d/ssh start (before "sleep")
10. after reboot you can go via ssh to DC as pepeEL (in client set port 2222)
11. clone, configure, build and install tvheadend
12. Change user "hts" to "pepeEL" at /etc/default/tvheadend
13. Chmod 777-R /home/pepeEL/.hts
14. reboot and all is works
3. remove DC
4. Install Dc.
2014-01-27, 23:44
(2014-01-27, 23:38)aisman Wrote: [ -> ]8. Change port 22 to 2222 at /etc/ssh/sshd_config
8. Change port it is in DC or DSM ?
11. This is OK ?
In DC
cd home
git clone https://github.com/tvheadend/tvheadend
cd tvheadend
./configure --prefix=/usr --enable-bundle --disable-avahi
make
make install
Can i add user name "HTS" ?
2014-01-27, 23:51
1.of course in DC, in DSM you haven't this file
2. Correct, may configure without bundle and enable what you want, and sudo make install
(2014-01-27, 23:44)pepeEL Wrote: [ -> ]Can i add user name "HTS" ?yes
2014-01-27, 23:52
2014-01-27, 23:56
#283
(2014-01-27, 23:44)pepeEL Wrote: [ -> ]cd homeno. Login as your user, and work at /home/your-user/ it will be automatically when you login
