2019-06-19, 08:01
(2019-06-18, 23:43)koekiemonster Wrote: [ -> ]you guessed correctly :-) And nope, I'm not active on the dutch htforum.Thanks for the reply. Win10 is my test machine. The main cinema I use pure Libreelec x86 and the music Libreelec Raspberry 3 Pi B + where I did not test. If it does and will be fully functional it will be perfect. Thanks again for your work.
good news: I figured out how to make stuff happen on player status changes (playback started/stopped/paused/resumed/etc). It is not too complex, but it does require a separate companion plugin (I'm now writing it). Once that is finished I'll improve the github page and make a separate thread.
My plan for setting things up (input welcome):
The hue controller plugin will stay as is: it shows your hue setup and allows you to toggle rooms and apply scenes. In addition to this the scenes will get a context menu, with options to set the selected scene as "apply when starting/resuming video playback", "apply when pausing video playback", "apply when stopping video playback". If you select one of these options, they get stored in the plugin configuration.
The companion plugin (currently called script.service.hue.events) will then look up and apply these scenes whenever playback status is changed.
Other options I'm thinking about are:
- a toggle for only changing the lighting if it is actually on (I have no need for movie lighting when the sun is up)
- a speed setting for the transition time when applying scenes
Once I've got this working I'll take a peek at windows support (sorry, low priority because I'm mostly running Linux)
