2015-04-28, 12:30
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
2015-04-29, 11:11
(2015-04-28, 12:30)majdalina Wrote: [ -> ]Kdnight heeeeeelp the subtitles change section doesn't work.
Thank you for all your hard work
are you saying that selecting a different subtitle language doesn't work? seems to work for me. did you get an error while trying to select it?
2015-04-29, 11:20
(2015-04-28, 02:17)scott967 Wrote: [ -> ](2015-04-26, 23:54)dknlght Wrote: [ -> ]I just pushed a fix. I had to do a lot of re-write with this current change.
Thanks for the quick fix. Unfortunately found a bug. The script is failing in SearchVideoresults:
Code:ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.TypeError'>
Error Contents: 'NoneType' object has no attribute '__getitem__'
File "E:\Media\Kodi 14.0 test\portable_data\addons\plugin.video.viki\default.py", line 1008, in <module>
SEARCHVideos()
File "E:\Media\Kodi 14.0 test\portable_data\addons\plugin.video.viki\default.py", line 618, in SEARCHVideos
SearchVideoresults(searchurl,searchText.lower())
File "E:\Media\Kodi 14.0 test\portable_data\addons\plugin.video.viki\default.py", line 598, in SearchVideoresults
if(typeitem.a["href"].find("/tv/") == -1):
TypeError: 'NoneType' object has no attribute '__getitem__'
so I did a little testing, and it seems like the failure is due to the specific format of the search text. In my case I was searching with i do i do. So I tried i do and it failed, then a bc and it failed, and also a b, so maybe at least the case of letter-space-one or two letters it is having a problem. As a final try I quoted the search string as "i do" and that did work.
scott s.
actually it had to do with the result of the search not the search text. I just pushed a fix it should work now
2015-04-29, 13:02
(2015-04-29, 11:11)dknlght Wrote: [ -> ]Hello thanks for the quick answer.(2015-04-28, 12:30)majdalina Wrote: [ -> ]Kdnight heeeeeelp the subtitles change section doesn't work.
When I open the selection it gives me a blank window. And then the whole xbmc turn off.
Also a message says Viki: script error
2015-04-30, 18:10
Hello in the settings if I enable use proxy it does not work anymore, I get only a blank screen no lists of video. If I disable the proxy the addons works with the latest version.
2015-05-01, 00:11
(2015-04-29, 11:20)dknlght Wrote: [ -> ]actually it had to do with the result of the search not the search text. I just pushed a fix it should work now
Working like a champ. Thanks for your hard work.
scott s.
2015-05-13, 22:40
http://fusion.xbmchub.com/xbmc-repos/rep...paddon.zip
Can't download from the link anymore.. anyone have updated link ?
2015-05-14, 00:13
(2015-05-13, 22:40)oninayr84 Wrote: [ -> ]http://fusion.xbmchub.com/xbmc-repos/rep...paddon.zip
I just updated the link in the first post so try it now. Sorry they keep changing the folder structure
2015-05-25, 20:46
dknlght, the subtitle field is blank, does not appear option for choice of languages. please take a look.
2015-05-27, 02:44
(2015-05-25, 20:46)nagai72 Wrote: [ -> ]dknlght, the subtitle field is blank, does not appear option for choice of languages. please take a look.
I'll take a look. seems the site changed again
2015-05-27, 15:31
2015-05-30, 21:49
this should be fixed. I pushed an update
2015-05-31, 11:31
Hi thanks again. Quick check, can this video addon be used to download for offline viewing say on my tablet?
2015-06-01, 14:50
(2015-05-30, 21:49)dknlght Wrote: [ -> ]this should be fixed. I pushed an update
Thank dknlght! working perfectly, the joy returned, :-)
2015-06-04, 22:16
I'm new to the Kodi thing Infact this is supposed to be my husbands new toy. But I am home all day with the baby and decided I wanted to catch up on some korena soaps and I can't seem to add the viki add on. Is there a process I must do in order to put it on? Or do I just add it? Because it keeps giving me an error
