2014-03-19, 02:51
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
2014-03-20, 10:50
So i found a way to watch area restricted content with external episodes. If you put the proxy on from the start and you do a search for your tv show of your interest the add on returns script error. If you put the proxy off and you do a search for your tv show of your interest the add on finds the tv show but when you press the episode does not show the external link in order to choose it and play. So the trick is :
- Put the proxy off
- Search for your tv show
- select it in order to see the episodes
- Now get into the add on menu setup and put the proxy on
- Press the episode that you want to see and this is it, the exeternal link appears and you can watch it now.
- Put the proxy off
2014-03-21, 04:04
(2014-03-20, 10:50)gusmin Wrote: [ -> ]So i found a way to watch area restricted content with external episodes. If you put the proxy on from the start and you do a search for your tv show of your interest the add on returns script error. If you put the proxy off and you do a search for your tv show of your interest the add on finds the tv show but when you press the episode does not show the external link in order to choose it and play. So the trick is :
- Put the proxy off
lol actually. I'll fix that I thought I put that fix in. I can get it to work without doing all that. so I can test, which external videos are you watching that you had to do this to?
2014-03-21, 10:18
Karadayi take 2 series
2014-03-23, 00:45
(2014-03-21, 10:18)gusmin Wrote: [ -> ]Karadayi take 2 series
ok it's fixed. I just pushed update version 1.1.15 which won't error when you search with proxy turned on
2014-03-23, 13:13
I check it and it is ok now
Thank you
Thank you
2014-03-26, 04:58
I'm getting no subtitle when proxy is turn on. It's enable and I can see the sub.srt(unknown)(1/1) but its not displaying.
I have video so right now only way to get subtitle is download manually and browse to it.
Is there anything I can do to fix this?
2014-03-27, 01:06
(2014-03-26, 04:58)h04n9 Wrote: [ -> ]I'm getting no subtitle when proxy is turn on. It's enable and I can see the sub.srt(unknown)(1/1) but its not displaying.
ok strange it actually sounds like an xbmc issue and not an addon problem but I'll have to look into it. I have a couple of questions first.
1. What device are you using xbmc on?
2. How are you manually downloading the subtitle?
3. Can you post a log? (remember to generate the issue/error first then export the logs)
2014-03-27, 03:43
I'm using Pi with latest official openelec.
I've tried uninstall reboot, then re-install reboot etc but it didn't solve the problem
Your addon can grab the subtitle link in the log, thats what I use to download manually.
Regional restriction just started for me maybe last two days here, enable proxy, thats when it started acting strange with the subtitle.
Last night subtitle did not display on screen the whole day.
But today its working fine now with proxy turn on.
Thank you DK
Here is the log when I had the problem
[/quote]
Thank you DK
19:10:14 T:2743997536 NOTICE: ============================ POSTING TRACK EVENT ============================
19:10:14 T:2743997536 NOTICE: ============================ POSTING ANALYTICS ============================
19:10:14 T:2743997536 NOTICE: 1035027v
19:10:14 T:2743997536 NOTICE: God's Gift - 14 Days Episode 7
19:10:14 T:2743997536 NOTICE: http://api.viki.io/v4/videos/1035027v.json?app=65535a&t=1395799815&site=www.viki.com&sig=93a7aa623f6c87c873c43486d1def3e0ea48f344
19:10:15 T:2743997536 NOTICE: http://api.viki.io/v4/videos/1035027v.json?app=65535a&t=1395799816&site=www.viki.com&sig=91b96bfd4355cb095def7750984b6e6b7661d63a
19:10:15 T:2743997536 NOTICE: http://api.viki.io/v4/videos/1035027v/streams.json?app=65535a&t=1395799816&site=www.viki.com&sig=c25f3021e27fb80e76ae65f2accd5eee405855e1
19:10:15 T:2743997536 NOTICE: http://api.viki.io/v4/videos/1035027v/subtitles/en.srt?app=65535a&t=1395799816&site=www.viki.com&sig=1c2ef73cc4c8d476c6ca3a2dcbc49a436f48bf5f
19:10:15 T:2743997536 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.TypeError'>
Error Contents: 'int' object is not iterable
File "/storage/.xbmc/addons/plugin.video.viki/default.py", line 718, in <module>
getVidQuality(url,name,filename,True)
File "/storage/.xbmc/addons/plugin.video.viki/default.py", line 432, in getVidQuality
for seas in mydata:
TypeError: 'int' object is not iterable
19:10:16 T:3046859424 ERROR: GetDirectory - Error getting plugin://plugin.video.viki/?mode=4&name=God%26%23x27%3bs%20Gift%20-%2014%20Days%20Episode%207&url=1035027v
19:10:16 T:3046859424 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.viki/?mode=4&name=God%26%23x27%3bs%20Gift%20-%2014%20Days%20Episode%207&url=1035027v) failed
19:10:16 T:2743997536 NOTICE: Thread BackgroundLoader start, auto delete: false
19:10:34 T:2743997536 NOTICE: Previous line repeats 1 times.
19:10:34 T:2743997536 NOTICE: Thread XBPyThread start, auto delete: false
19:10:35 T:2743997536 NOTICE: -->Python Interpreter Initialized<--
19:10:43 T:2743997536 NOTICE: ============================ POSTING TRACK EVENT ============================
19:10:43 T:2743997536 NOTICE: ============================ POSTING ANALYTICS ============================
19:10:43 T:2743997536 NOTICE: 1035027v
19:10:43 T:2743997536 NOTICE: God's Gift - 14 Days Episode 7
19:10:43 T:2743997536 NOTICE: http://api.viki.io/v4/videos/1035027v.json?app=65535a&t=1395799844&site=www.viki.com&sig=2e20e4c1da8c84037ec8e564e1c05b2d83cd62e7
19:10:44 T:2743997536 NOTICE: http://api.viki.io/v4/videos/1035027v.json?app=65535a&t=1395799845&site=www.viki.com&sig=002118df741ff6a1c894178b8751e98a1fe05601
19:10:44 T:2743997536 NOTICE: https://losangeles-s02-i01-traffic.cyberghostvpn.com/go/browse.php?u=http%3A%2F%2Fapi.viki.io%2Fv4%2Fvideos%2F1035027v%2Fstreams.json%3Fapp%3D65535a%26t%3D1395799844%26site%3Dwww.viki.com%26sig%3D10fe6934d4fed018400d7db636dc46d3897af8b6&b=1
19:10:44 T:2743997536 NOTICE: http://api.viki.io/v4/videos/1035027v/subtitles/en.srt?app=65535a&t=1395799845&site=www.viki.com&sig=23c89b5dbc8794d2416e495232d078d06ae59980
19:10:44 T:2782930016 NOTICE: Thread BackgroundLoader start, auto delete: false
19:10:47 T:2743997536 NOTICE: Thread XBPyThread start, auto delete: false
19:10:48 T:2743997536 NOTICE: -->Python Interpreter Initialized<--
19:10:55 T:2743997536 NOTICE: http://v.viki.io/1035027v/1035027v_high_480p_1403250123.mp4?e=1395843044&h=e65312cc29e9415eced2342b48d4c6ab
19:10:55 T:2782930016 NOTICE: Thread CGUIDialogCache start, auto delete: true
19:10:55 T:3046859424 NOTICE: COMXPlayer: Opening: http://v.viki.io/1035027v/1035027v_high_480p_1403250123.mp4?e=1395843044&h=e65312cc29e9415eced2342b48d4c6ab
19:10:55 T:3046859424 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
19:10:55 T:3046859424 NOTICE: CXBMCRenderManager::ResetRenderBuffer - using 5 render buffers
19:10:55 T:2767189088 NOTICE: Thread COMXPlayer start, auto delete: false
19:10:55 T:2767189088 NOTICE: Creating InputStream
19:10:55 T:2767189088 NOTICE: Creating Demuxer
19:10:55 T:2721285216 NOTICE: Thread CFileCache start, auto delete: false
19:11:00 T:2767189088 NOTICE: Opening video stream: 0 source: 256
19:11:00 T:2767189088 NOTICE: Creating video thread
19:11:00 T:2782930016 NOTICE: Thread COMXPlayerVideo start, auto delete: false
19:11:00 T:2767189088 NOTICE: Opening audio stream: 1 source: 256
19:11:00 T:2767189088 NOTICE: Creating audio thread
19:11:00 T:2754606176 NOTICE: Thread COMXPlayerAudio start, auto delete: false
19:11:00 T:2767189088 NOTICE: OMXClock using audio as reference
19:11:00 T:2782930016 NOTICE: Display resolution DESKTOP : 1920x1080 @ 60.00 - Full Screen (16)
19:11:00 T:2782930016 NOTICE: CXBMCRenderManager::ResetRenderBuffer - using 5 render buffers
19:11:00 T:3046859424 NOTICE: Using GL_TEXTURE_2D
19:11:00 T:3046859424 NOTICE: GL: Using BYPASS render method
19:11:00 T:3046859424 NOTICE: GL: NPOT texture support detected
19:11:01 T:2743997536 WARNING: Attempt to use invalid handle -1
19:11:01 T:2767189088 NOTICE: Opening Subtitle stream: 0 source: 1024
19:11:01 T:2767189088 ERROR: OpenStream - Unable to create subtitle parser
19:11:01 T:2767189088 WARNING: OpenSubtitleStream - Unsupported stream 0. Stream disabled.
19:11:05 T:2767189088 NOTICE: FlushBuffers: q:0 pts:604536000 a:0
19:11:10 T:2767189088 NOTICE: FlushBuffers: q:0 pts:639785000 a:0
19:11:40 T:3046859424 NOTICE: COMXPlayer::CloseFile
19:11:40 T:3046859424 NOTICE: COMXPlayer: waiting for threads to exit
19:11:40 T:2767189088 NOTICE: COMXPlayer::OnExit()
19:11:40 T:2767189088 NOTICE: OMXPlayer: closing audio stream
19:11:40 T:2767189088 NOTICE: Closing audio stream
19:11:40 T:2754606176 NOTICE: thread end: OMXPlayerAudio::OnExit()
19:11:40 T:2767189088 NOTICE: OMXPlayer: closing video stream
19:11:40 T:2767189088 NOTICE: Closing video stream
19:11:40 T:2782930016 NOTICE: thread end: video_thread
19:11:40 T:2767189088 NOTICE: COMXPlayer::OnExit() deleting demuxer
19:11:40 T:2767189088 NOTICE: COMXPlayer::OnExit() deleting input stream
19:11:40 T:3046859424 NOTICE: DVDPlayer: finished waiting
19:11:40 T:2767189088 NOTICE: Thread BackgroundLoader start, auto delete: false
19:11:40 T:2721285216 NOTICE: Thread Jobworker start, auto delete: true
19:11:41 T:3046859424 NOTICE: COMXPlayer::CloseFile
19:11:41 T:3046859424 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
19:11:41 T:3046859424 NOTICE: COMXPlayer: waiting for threads to exit
19:11:41 T:3046859424 NOTICE: DVDPlayer: finished waiting
2014-03-28, 06:51
(2014-03-27, 03:43)h04n9 Wrote: [ -> ]I'm using Pi with latest official openelec.[/quote]
Thank you DK
I think I figured it out but it will have to wait until the weekend for me to fix. Seems that the issue is with the timestamp. It's using your local time to generate a timestamp but comparing it to the timestamp in the proxy region you select. So if you select US the timestamp fails because the timestamp used doesn't match the US time.
2014-03-28, 16:00
I was able to watch videos until the last two updates. I am located in the US but I tried enabling the proxy to USA to see if this makes any difference. It does not. Additionally, I tried to uninstall, reboot and reinstall several times.
Anyway, I am using ATV2 on Frodo 12.3 and unable to go beyond the episodes listing. Once I try to get to the next screen with the screen resolution option - it gives VIKI script error.
Here is the logfile. The VIKI script just stops.
http://xbmclogs.com/show.php?id=160344
Thank you for your work in this plugin!
2014-03-29, 04:41
(2014-03-28, 16:00)grebit2 Wrote: [ -> ]I was able to watch videos until the last two updates. I am located in the US but I tried enabling the proxy to USA to see if this makes any difference. It does not. Additionally, I tried to uninstall, reboot and reinstall several times.
Ok, I think I fixed the issue. close it all down do an update and see if it works now.
2014-03-29, 15:53
I reupdated the module and still having errors.
I uploaded the logfile from the time I started the Viki til when I get the error message to give you a bigger picture. Does it matter which Advanced XML file I use?
Thanks again!
http://xbmclogs.com/show.php?id=161284
Thanks again!
2014-03-29, 20:48
Hi dknlght, just FYI Viki is giving a script error. It looks like grebit2 is having the same problem. I will try to find out how to post my log like he did so maybe I can help.
2014-03-30, 00:10
(2014-03-29, 15:53)grebit2 Wrote: [ -> ]I reupdated the module and still having errors.
Thanks again!
unfortunately the logs aren't giving me any details on the error. I thought your issue was the same h04n9 but looks like it's not. Has it been working for you on this same device and all of a sudden doesn't work? this error is usually related to you not having the right modules it needs but it normally shows up with a new install or someone starting over because they forgot to install all the components.
