Thanks but i"ll have to wait for next Gotham build cause the current dosn't run well on my Pi
Never seen it so slow before :/ Unusable.
Hi popcornmix,
replaced start.elf and fixup.dat on the latest gotham.
Seems to have sorted a/vsync
However live tv overall is more flaky - i.e channel switches are slower, video can stutter for first 10-15secs of changing channels.
When in preview video in background sometimes stops and stutters. Gui feels slower as well?
thanks very much for all the work - but guess you want as much feedback as possible
If it is of an use the previous build I mentioned feels a lot more solid ( 14704)
pootler
Confirmed: replacing start.elf and fixup.dat fixed the audio sync issue on LiveTV. Channel switching is somewhat slower though, but still very usable. Keep up the good work, it's much appreciated!
In my hunt for a 100% working build with Livetv/pvr and the rest of xbmc i tested
http://forum.xbmc.org/showthread.php?tid...pid1468727
Ok:
+Aspect ratio is ok!
+Audio offset, ok
+Channel change with numbers , ok !
+Subtitles on sdtv and hdtv, Ok !
Not ok:
-Live tv blackscreen , sometimes but not often.
-Live tv not starting on channel change and heads back to home Live tv/pvr meny happens when you go from a channnel with ac3 audio to a channel with mpeg audio
-Dvd meny navigation issues
So the hunt goes on
Edit found when channel change/start issue happens, se above.
Hey I need some help my raspberry pi not playing video only audio on live tv stream on my 512mb PI running Raspbmc ,but it does play on my 256mb pi try raspbmc only shows video on the 256mb Pi on the 512mb only audio.Using Openelec rbji frodo last frodo build from rbji on both just audio no video .Yes i have both codecs keys for both Pi try on two 512mb PI and one 256 mb Pi.Just try one more 512mb Pi still a no good with live tv video just audio about to try Xbian latest build to see .
(2013-07-26, 02:29)nuttypro69 Wrote: [ -> ]Hey I need some help my raspberry pi not playing video only audio on live tv stream on my 512mb PI running Raspbmc ,but it does play on my 256mb pi try raspbmc only shows video on the 256mb Pi on the 512mb only audio.Using Openelec rbji frodo last frodo build from rbji on both just audio no video .Yes i have both codecs keys for both Pi try on two 512mb PI and one 256 mb Pi.Just try one more 512mb Pi still a no good with live tv video just audio about to try Xbian latest build to see .
Please paste output of
vcgencmd codec_enabled MPG2
on the failing platforms.
(2013-07-26, 16:10)Jönke Wrote: [ -> ]So channel change from channel with audio:
Ac3->Ac3 , ok
Ac3->mpeg2, not ok
mpeg2->Ac3 , ok
I really need a file with the audio codec change in. Either from a recording, or using some muxing software to produce it
(I'm not sure if ffmpeg or mkvmerge, or any of the tools here:http://forum.videohelp.com/threads/272116-Edit-cut-MPEG2-TS can do this).
I' ve posted 2 diffrent samples from recording of one channel with ac3 audio and one with mpeg audio. And i'ts the live tv-channel change between the 2 tv-channels it fails. Not a audio codec change in a running tv-channel.
Haven't had that issue with Gotham build , only Frodo. But i'm looking for something working when Gotham have to many pvr bugs thats working in Frodo
If it would help, and if you have fast internet i could give you access to my Tvheadend server so you can view live-tv and se whats happening
Ok popcornmix what I did was download the short movie clip to my linux computer copy it to a usb drive and still was a no go with any openelec build so I pop raspbmc back in there and work like a charm so I google around found a post from a while back where someone removed the config.txt and I did the same put made my own like the one in raspbmc and boom both video play on all the 256mb and 512 mb Pi .so my question they must be something in the Openelec config,txt that does allow live ota strm to play even If each pi has right codec keys.Just sharing my finding again thanks . Ok got it now I had to remove the + from each line i add some to thanks popcornmix.
Good to see it finally works. I didn't experienced any serious issues. The only thing left to fix is aspect ratio problem. "Normal" aspect ratio still works incorrectly. I need to set 16:9 or 4:3 to get video displayed as should.
(2013-08-05, 00:12)Jönke Wrote: [ -> ] (2013-07-26, 16:10)Jönke Wrote: [ -> ]From http://forum.xbmc.org/showthread.php?tid=169674
@sraue or popcormix
Can you please take a look at my log http://xbmclogs.com/show.php?id=39243
Its from this build in this post http://forum.xbmc.org/showthread.php?tid...pid1468727
My problem is that tvchannel change from a tvchannel with ac3 audio to a tvchannel with mpeg2 audio always fail.
So tvchannel change from tvchannel with audio:
Ac3->Ac3 , ok
Ac3->mpeg, not ok
mpeg->Ac3 , ok
If i stop playback first mpeg, ok
@popcornmix, now this issue have made its way into Gotham as well !
Just tried rbejs latest Gotham build from here http://forum.xbmc.org/showthread.php?tid...pid1477148
I´m willing to let you use my Tvheadend server to debug this if it helps you?
I had the same problem and tried several versions and settings to get PVR working with my tvheadend running on my synology box. Since yesterday the setup is working with the latest FRODO version from rbej. In addition to the update I also removed my databases and the advancedsettings as well as the guisettings. I replaced the advancedsettings with the file provided by rbej and it finally worked. Not sure if an old setting caused the problems.
Are we talking rbej Frodo or Openelec 3.1.5 ?
