2013-01-22, 18:01
(2013-01-22, 17:19)sleipner42 Wrote: [ -> ]Edit: solved problem! It was wrong password :S
Thanks anyways for letting me know.
I'll have to take care of that and show a better message than a script error.
(2013-01-26, 17:36)MDDSD Wrote: [ -> ]Could you send me the xbmc.log file via pm.
Does the other part with the browser work?
Is the correct url loaded in the browser?
(2013-02-11, 23:47)reddanse Wrote: [ -> ]Hi, i´m also getting errors when trying to start the HBO plugin. Using Mac OS and XBMC Frodo.
When i start HBO it works fine but when try to "play" series Safari is starting up and i got those error messages.
(2013-02-12, 17:22)dukevim Wrote: [ -> ]Can you use this with a VPN, assuming you could get one of their vouchers?
(2013-02-12, 08:11)MDDSD Wrote: [ -> ](2013-02-11, 23:47)reddanse Wrote: [ -> ]Hi, i´m also getting errors when trying to start the HBO plugin. Using Mac OS and XBMC Frodo.
I've done some testing and I'm not able to reproduce the error.
What version of Mac OS are you running. I've done the testing on Mac OS X 10.8 (Mountain Lion) and it works.
I'm currently looking into the possibility to add automatic login to Mac OS X, but i'm not promising anything just yet...
(2013-02-12, 22:05)reddanse Wrote: [ -> ](2013-02-12, 08:11)MDDSD Wrote: [ -> ](2013-02-11, 23:47)reddanse Wrote: [ -> ]Hi, i´m also getting errors when trying to start the HBO plugin. Using Mac OS and XBMC Frodo.
Hi, 10.8.2 is my Mac version.
(2013-02-12, 22:26)MDDSD Wrote: [ -> ](2013-02-12, 22:05)reddanse Wrote: [ -> ](2013-02-12, 08:11)MDDSD Wrote: [ -> ]I've done some testing and I'm not able to reproduce the error.
That's the same version I'm running on my test mac.
What webbrowser are you using as your default browser?
When I tested the addon I had Safari as my default webbrowser.
