Opssss.... Just realized i lost the ability to change audio or subtitles on DSPlayer when playing a movie, after i updated the last version....
mediascofig.xml is correct, same it was before
grrr.... when i press "m" (menu and audio, i simply don't see the audio streams
Any clue? anyone else happened to experience similar issue?
I'm sure is on my side but i'm getting mad investigating, lol
(2013-10-07, 20:03)vicmanpergar Wrote: [ -> ]Opssss.... Just realized i lost the ability to change audio or subtitles on DSPlayer when playing a movie, after i updated the last version....
Actually, instead of cyclic audio and subs stream switching in latest versions new menus for choosing audio and subtitles were introduced. They should open when you select respective items in Audio Settings menu. Also, you can turn off those new menus by adding the following properties to advancedsettings.xml:
<advancedsettings>
<video>
<audioexpandedselector>false</audioexpandedselector>
<subsexpandedselector>false</subsexpandedselector>
</video>
</advancedsettings>
Those menus should work both in DVDplayer and DSplayer.
P.S. I've also updated links in the OP.
(2013-10-07, 22:23)Roman_V_M Wrote: [ -> ] (2013-10-07, 20:03)vicmanpergar Wrote: [ -> ]Opssss.... Just realized i lost the ability to change audio or subtitles on DSPlayer when playing a movie, after i updated the last version....
<advancedsettings>
<video>
</video>
</advancedsettings>
Thank u Roman, gonna take a look to that
Edit: Ok, they're again working. I have no idea what the new menus are or where they are but i had no aparent way to change audios or subs as far as i noticed. Now i'm curious, lol
Anyway the old system is working for me, at least. Thanks again.
I've relieved the restrictions of the server whichs hosts the builds a bit so people with firewalled Referer header should be able to download, too.
(2013-10-09, 14:38)panni Wrote: [ -> ]I've relieved the restrictions of the server whichs hosts the builds a bit so people with firewalled Referer header should be able to download, too.
Sorry Panni but still no joy... Ive completely taken down my IE firewall but still cant download from Fragstore
Can you try Firefox or Chrome please? IE seems to have problems with the SSL ciphers my server uses.
I found an option in XBMC to change the color and alpha of the subtitles and this works with the internal player (although not the alpha value), but these settings are ignored when used with DSPlayer. Is there a workaround or can I use an extra filter to be able to do this?
(2013-10-09, 15:16)panni Wrote: [ -> ]Can you try Firefox or Chrome please? IE seems to have problems with the SSL ciphers my server uses.
Sorted with Firefox.... Thanks Panni
(2013-09-25, 12:52)999unreal Wrote: [ -> ]Hello.
About DSPlayer Frodo build.
A thumbnail is not displayed when a bookmark is created.
Is it a bug?
This should be fixed in the latest code. Please wait until me or some other release builder will post a new binary installer.
(2013-10-11, 16:17)Roman_V_M Wrote: [ -> ]This should be fixed in the latest code. Please wait until me or some other release builder will post a new binary installer.
Thank , Roman_V_M.
I am waiting for 3D version.
By the way, I have been using a special filter (Marumo ISDB Splitter)
but the information of
audio and video can not be displayed in OSD.
DirectShow filter that specializes in digital broadcasting in Japan. (ISDB MPEG-2 TS)
Is it possible to display in OSD?
Note: File Source (Async.) is required to use this filter.
Marumo ISDB Splitter and very small video sample here :
http://www.mediafire.com/?mcsua99b40ppiep
--- filtersconfig (isdbsplitter.ax) ---
<filter name="isdbsplitter" type="splitter">
<guid>{B8CF9F40-3DE2-48CE-AE55-14A8C4016431}</guid>
<osdname>Marumo ISDB Splitter</osdname>
</filter>
--- my mediasconfig ---
<rule filetypes="ts">
<source filter="filesource" />
<splitter filter="isdbsplitter" />
<video filter="lavvideo" />
<audio filter="ac3filter" />
</rule>
OSD
my graph
(2013-10-13, 13:37)Slurm Wrote: [ -> ]Here's the latest version with pvr and 3D patches:
THANKS ! (xbmc is too slow without the PVR patch...)
@999unreal: does the "maruno splitter" only works for japan-live tv or all kinds of ts streams? or in other words is it possible to use dsplayer and pvr/livetv with that splitter outside of japan?
(2013-10-13, 21:44)Ed76 Wrote: [ -> ]@999unreal: does the "maruno splitter" only works for japan-live tv or all kinds of ts streams? or in other words is it possible to use dsplayer and pvr/livetv with that splitter outside of japan?
Sorry.
Only MPEG-2 TS format of ISDB.
It does not correspond to the ATSC and DVB.
I have never tested the TS-FILE outside of Japan.
Please test the TS-FILE ISDB format of your own.
ISDB (Green Country)
