madvr it's not working at all, all commands resize upscaling etc has not effect on the video i don't know why, i have to assign the instance of madVR to kodi and then do something to enlarge the video
when i create the instance, madvr opens it's window and with pVW->put_Owner((OAHWND)g_hWnd); i put this in kodi, with the exe that i have posted i simply set hidden madvr windows and that was a totally wrong approach
after instance assignment maybe there is some other stuff to do because when i do this i have a black box of 300x200 pixel in an angle that i suppose is the old device of madvr detached and the video enlarged on the kodi windows has very bad resolution
i think it's the video 300x200 enlarged... as i already say i have not experience with d3d devices and without an help i can employ too much time to do this small things
the very big problem was to rendering the kodi gui on madvr and this it's done, but i don't know how work the other things.... aspect ratio too
i cannot see how evr work because obviously it's completely different from madvr
so now to do things are
- figure out why all options has not effect on video, i don't know if the instance assignement it's the key to solve this
- figure out how kick off the old device from madvr
- how set proper resolution and aspect ratio
then the menu integration to set all options it's very simple to me
ps
just to be clear if some other developer would help
this it's how i create the renderer, after that i don't know what other madvr need
Com::SmartPtr<IUnknown> pRenderer;
if (SUCCEEDED(hr = pCAP->CreateRenderer(&pRenderer))) {
*ppBF = Com::SmartQIPtr<IBaseFilter>(pRenderer).Detach();
// madVR supports calling IVideoWindow::put_Owner before the pins are connected
if (m_clsid == CLSID_madVR) {
if (Com::SmartQIPtr<IMadVRDirect3D9Manager> pMadVrD3d = pCAP) {
LPDIRECT3DDEVICE9 pD3DDevice;
pD3DDevice = g_Windowing.Get3DDevice();
pMadVrD3d->UseTheseDevices(pD3DDevice, pD3DDevice, pD3DDevice);
pMadVrD3d->ConfigureDisplayModeChanger(false, false);
if (Com::SmartQIPtr<IVideoWindow> pVW = pCAP)
CLog::Log(LOGDEBUG, "%s Allocator presenter successfully created", __FUNCTION__);
this it's the interface that madshi has developped to xbmc some years ago to let madvr use an already existent d3d device, i don't know if i have to call this command in an other moment
at end this it's the very bad result, the box with the old device over the picture with a low resolution
