I am using dsplayer to make SVP work with XBMC. However, playing Videos with win 7 on the secondary display is stuttering and SVP is reporting performance issues, although my i7 is only used at 25%. No problem in primary display or with win 8.
I read a recommendation to use MadVR set for exclusive mode. Is it now possible to use dsplayer with madVR? If so, could you guys give me a hint on how to make this happen?
Not possible at the moment.
Too sad. Do you guys see other chances to tackle this problem?
xbmc 13.0 final release it's out
i've updated my links
DSPlayer will be alive at least until next year after all
ciauz
aracnoz, may I ask, what's the diff between the DSPlayer Setup and the DSPlayer ExeOnly?
(2014-05-04, 20:28)ArieS Wrote: [ -> ]aracnoz, may I ask, what's the diff between the DSPlayer Setup and the DSPlayer ExeOnly?
Thanks a lot aracnoz!
ExeOnly is for overwrite normal XBMC installation.
(2014-05-04, 22:04)oldpoem Wrote: [ -> ] (2014-05-04, 20:28)ArieS Wrote: [ -> ]aracnoz, may I ask, what's the diff between the DSPlayer Setup and the DSPlayer ExeOnly?
Oh, thanks a lot for the info
Just to be sure. Is it okay to install DSplayer version and afterwards overwrite the exe taken from the original XBMC if you want to go back to original?
I haven't gotten my dev environment up and running yet. If anyone compiled XBMC 13.0 Gotham Final with DSPlayer and Margo's Fast Channel Zapping branch, could you post a link to it for download. You'll be my hero
3 questions:
1. so the one from aracnoz is not with margros changes?
2. And what is the performance difference with channel changes and timeshift enabled?
3. It has taken some time to reinstall to gotham 13 on server and clients. Is there any problems with just overwriting aracnozs version with slurms version for margros changes?
(2014-05-08, 13:51)Bjur Wrote: [ -> ]3 questions:
Yes. Margro's changes aren't in any gotham build currently.
(2014-05-08, 13:51)Bjur Wrote: [ -> ]2. And what is the performance difference with channel changes and timeshift enabled?
I'm using it with dvbviewer backend and even with timeshift enabled the switching times are around 2-3 seconds.
(2014-05-08, 13:51)Bjur Wrote: [ -> ]3. It has taken some time to reinstall to gotham 13 on server and clients. Is there any problems with just overwriting aracnozs version with slurms version for margros changes?
There shouldn't be any problems. If you have set your pvr to use dsplayer you have to revert it to use all the features like timeshift and the fast switching times (though they aren't bad with dsplayer, but there's no good timeshift), that's all.
