have you got a recent tutorial for the installation of dsplayer and madvr and all others
i've gave it a try but no luck, some off my mkv doesn't read and madvr seems to not install in my system !!!
(2014-03-28, 14:48)Ed76 Wrote: [ -> ]hi aracnoz,
at first i want to say thanks for your work on dsplayer and especially for your work on the pvr-part. the only thing i really miss is the jump forward/back option within live tv (timeshift). do you know why this isnt working? it seems the seeking/searching (30 seconds) doesnt work. do you also use the pvr part of xbmc dsplayer or does you have a pvr equipment for testing?
Unfortunately I do not have much time to dedicate to the project DSPlayer
you can not imagine how exhausting it's work on a project like DSPlayer, you continue thinking all day about how to solve the last problem that came out, too much for me
if someone else wants to take over my latest github source for changes or improvements, or would like to start over from the last release of eduard k. because you think that my work is not so good, he can feel free to do so, DSPlayer does not have an owner, all are free of work as they believe, of course my huge admiration goes to tiben20 and who with him has created DSPlayer for the first time
I can only imagine how much work you had to do
I do not want to disappoint anyone, I will continue to work to bring DSPlayer until the final release of gotham, but I can not work on any improvement
p.s.
gotham beta3 it's out i've updated my links
ciauzz
hi aracnoz,
this was just a question, no command. its absolutly understandable if you havent the time for improvements...
Thanks aracnoz, you are already doing much more than what we could have expected just a few weeks ago.
@ed76: hos fast Are your swiching times with timesats enabled in dsplayer version? When i use dvbviewer rekorden service as backend it is alment 20 seconds..
@aracnoz: your work with dsplayer is VERY appreciated and the same goes for Tiben20. I Will wait for the final release before updating both my server and clients. As of now im still using old 12.0 so looking forward to try the new release
Just a noob question:
What is the benefit of using the DSplayer build? What will be better?
Has anyone gotten rar files to play on the latest XBMC 12 builds? They don't work for me. Haven't tried any of the Gotham builds yet.
(2014-04-02, 17:30)StinDaWg Wrote: [ -> ]Has anyone gotten rar files to play on the latest XBMC 12 builds? They don't work for me. Haven't tried any of the Gotham builds yet.
no it won't work, when the russian developer took over the project he modified the filter loading system and he didn't kept the file source filter i written to handle the compressed files. It's a big piece of work and i don't really want to do it once again.
(2014-04-02, 09:39)sualfred Wrote: [ -> ]Just a noob question:
It's just to use windows codec instead of built in codecs. If your not really familiar with what directshow can do you won't see much benefit
Bjur,
20 secondes switching time with timeshift enabled is normal with dvbviewer backend.and it doesnt matter if you use xbmcs dvdplayer or dsplayer. its because dvbviewer recordingservice doesnt support timeshift like the other tv backends do ( the timeshift option in the xbmc plugin seems to work in another way than other tv backend does, it seems there is a kind of "workaround" because the backend itself doesnt support timeshift). if you want shorter switching times and perfect timeshift (and you use windows) i recommend argustv or mediaportal backend. both are for free, working very stable (for me) and switching time with margos patch is 1 second with dvdplayer and 2-3 seconds with dsplayer.
and another thing: i doubt you are using dsplayer with option timeshift enabled. are you really sure? press "o" to check. normally the rules i posted should only work if you disable the timeshift option in dvbviewer plugin....
Hi just a quick question, what patch was responsible for "Native iMON support" ? Couldnt get my imon to work without ugly third party apps any other way, now i have Gotham beta3 and my IMON doesnt work at all.
(2014-04-06, 18:20)Dinth Wrote: [ -> ]Hi just a quick question, what patch was responsible for "Native iMON support" ? Couldnt get my imon to work without ugly third party apps any other way, now i have Gotham beta3 and my IMON doesnt work at all.
To put it shot: there is no such 'patch' from end-user's perspective. AFAIK, the support is (was?) integrated into the base code.
gotham beta4 it's out
all links are updated
ciauz
Thanks aracnoz!
Have been using the previous build with vsfilter for a while without any problems, but in the other day I noticed a small bug.
Using vsfilter, when going to the OSD menu > selecting the "Audio" menu icon > then use the "Browse for Subtitle" dialog, the selected subtitle don't load.
It's not a big deal and I only noticed because I misnamed a subtitle file and then tried to load it manually without going to the PC, but I think I should report it anyway.
Thanks for all the effort on DSPlayer!
It'll be awesome to get a xbmc displayer build with Margo's fast channel change PVR branch
