Great skin, works perfectly on my windows box. I used this opportunity to finally update my openelec box from 2.0 to 3.1.5 but unfortunately the thumbnails for recently added media don't appear to work on linux.
I tested the original xperience1080 skin to try and figure out what was going on, but the indicators kept spinning forever without ever loading any images, so it seems like the issue may go back to the parent skin. Thumbnails and fanart are working correctly in library mode, and recently added thumbs show up correctly in confluence, so it does appear to be related to the skin somehow.
I've been looking through the debug log but I can't see anything obvious. Any ideas?
Edit: How about this?
20:14:26 T:140684045186880 DEBUG: ------ Window Deinit (Startup.xml) ------
20:14:26 T:140684045186880 DEBUG: ------ Window Init (Home.xml) ------
20:14:26 T:140684045186880 INFO: Loading skin file: Home.xml, load type: KEEP_IN_MEMORY
20:14:26 T:140684045186880 WARNING: Skin has invalid include: Widgets_Slide
20:14:26 T:140684045186880 WARNING: Previous line repeats 4 times.
20:14:26 T:140684045186880 ERROR: unmatched parentheses in StringCompare(Skin.String(tvshow.widget.type),New tv shows
20:14:26 T:140684045186880 ERROR: unmatched parentheses in StringCompare(Skin.String(tvshow.widget.type),Ongoing tv shows
20:14:26 T:140684045186880 ERROR: unmatched parentheses in StringCompare(Skin.String(tvshow.widget.type),Spotlight
20:14:26 T:140684045186880 ERROR: unmatched parentheses in StringCompare(Skin.String(music.widget.type),Most played albums
20:14:27 T:140684045186880 ERROR: unmatched parentheses in StringCompare(Skin.String(music.widget.type),New albums
20:14:27 T:140684045186880 ERROR: unmatched parentheses in StringCompare(Skin.String(music.widget.type),Spotlight
20:14:27 T:140684042704640 DEBUG: Suspended the Sink
20:14:27 T:140683264390912 DEBUG: CRecentlyAddedJob::UpdateMusic() - Running RecentlyAdded home screen update
20:14:27 T:140684045186880 DEBUG: ExecuteXBMCAction : Translating ReloadSkin()
20:14:27 T:140684045186880 DEBUG: ExecuteXBMCAction : To ReloadSkin()
20:14:27 T:140684045186880 INFO: Unloading old skin ...
20:14:27 T:140684045186880 DEBUG: ------ Window Deinit () ------
20:14:27 T:140684045186880 DEBUG: ------ Window Deinit (Home.xml) ------
Full log here:
http://pastebin.com/AG4YKVtm
I've just tried the 3.0.6 stable version and it seems to be working correctly, so looks like it's not a problem on your end. Apologies.
(2013-08-04, 13:18)jurialmunkey Wrote: [ -> ] (2013-08-04, 12:50)Kokonutcreme Wrote: [ -> ]Nice work Jurial.
Just noticed an inconsistency, the custom item has been removed from the home menu but custom still appears as a configurable option in the backgrounds menu.
Is the custom menu item still an option in the future?
It should still be there. 'Skin Settings > Home > Manage Categories > Custom". The option just doesn't fit in the dialog box so you have to scroll down (I really should make it bigger )
Apologies my bad forgot that custom item is only available for now in simple view
(2013-08-04, 13:10)Azake Wrote: [ -> ]Hmpf..
Last Update 04.08.2013 6:37
,,and I already updated your new changes.
Strange. Something must have gone wrong when you updated because both simple and panel home use exactly the same code for the submenu items now. You might need to delete the skin and re-clone the repo (you wont loose your skin settings because xbmc stores them elsewhere).
(2013-08-04, 17:07)Smobbo Wrote: [ -> ]It works quite well on a raspberry pi, a bit slow but it looks great, so I can handle the delays .
I noticed that one dialog screen (for the subtitle delay setting during playback) was missing, don't know if you were aware of this?
Anyway, great skin kep up the good work !
Excellent. I was wondering if it would even run on a pi. If you change the effectsslowdown setting in skin.arctic/addons.xml it may help with making it feel a little snappier.
Ah. I accidentally deleted the image for the background of the slider when I was doing the cleanup. Its back now.
(2013-08-04, 18:58)vimarbla Wrote: [ -> ]I would like to know also if it is possible to add rating in numbers (Imdb rating or other), as an option - selecting numbers or stars - or simply added in general and info views.
I do not want to waste your time and previously I have been searching in this thread for some question related with this, but I have not found results.
I do think that it would be good to have an option to switch the rating in the info tags at the bottom of the screen to a number. I'll add it in when I get a chance.
(2013-08-04, 22:37)Jimmeh Wrote: [ -> ]I've just tried the 3.0.6 stable version and it seems to be working correctly, so looks like it's not a problem on your end. Apologies.
Glad its working properly now.
(2013-08-04, 23:33)Kokonutcreme Wrote: [ -> ]Apologies my bad forgot that custom item is only available for now in simple view
No problem. Customisation of the home categories is next on my list once I get the last few menus done.
To everyone who uses simple homescreen:
I'm thinking of making a couple of changes to the simple homescreen so that it is consistent with the rest of the skin (namely, I'm going to be removing the glass edging). However, I'm wondering on what peoples thoughts are regarding whether it should extend the full width of the screen or have a slight gap like the panel. This is what it would look like:
I personally like the gap.
+1 for the small gap. I like that the profile icon and indicator / totals are now located down on the bottom panel.
(2013-08-05, 04:00)jurialmunkey Wrote: [ -> ] (2013-08-04, 13:10)Azake Wrote: [ -> ]Hmpf..
[NEGATIVE SQUARED LATIN CAPITAL LETTER B]To everyone who uses simple homescreen:[/B]
+1 for the gap
Okay I've committed the changes to git. I think it looks much more consistent with everything else this way.
(2013-08-05, 04:39)pentaflake Wrote: [ -> ]+1 for the small gap. I like that the profile icon and indicator / totals are now located down on the bottom panel.
Yeah, much much better there (you can actually still read it if the background image is dark.). Also good to use that space now that I've removed the power button from there.
I added an option to switch the info tags at the bottom of the screen to show a numeric rating. "Skin Settings > Views > Prefer Numeric Rating". Its at the very bottom of the list so you have to scroll down to see it.
Yeah like the changes to the Simple home screen and prefer the gap, looking forward to installing latest GIT after work tonight
Thanks for rating in numbers. Works perfectly!
jurialmunkey could you add the rating in the OSD (for video and songs)?
jurialmunkey please could you add the metro home?
Is there anyway to customize the main menu options ?
Ie, I use Smart Playlists to separate things, so I have a Movies | Kids Movies | 3D Movies Playlists.
With some skins I can change the Movies so it opens "Movies Playlist" or I can add the Playlists as Menu Items.
I figured out how to add them to the Movies Submenu but not how to add them to the main menu (if its possible)
Thanks anyway, even if its not possible. This is a gorgeous looking skin.
(2013-08-05, 04:00)jurialmunkey Wrote: [ -> ] (2013-08-04, 17:07)Smobbo Wrote: [ -> ]It works quite well on a raspberry pi, a bit slow but it looks great, so I can handle the delays .
Thanks for your quick response!
I'll update the skin when i get home to get the background for the slider back
I'll also look into editing the effectsslowdown setting in addons.xml. I assume this is a value i can lower to dimish the effect? I'll try a couple of settings and will report back!
