2014-06-05, 06:30
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
2014-06-08, 13:37
I'm getting dependencies not met after my upgrade to gotham on another machine? What dependencies does this addon have?
2014-06-08, 14:54
xbmc.python version 2.1.0
And that's it.
And that's it.
2014-06-11, 15:00
Hi anyone.
I have added a skin to the list view for LazyTV as well as a context menu.
The context menu allows you to:
- select more than one show at a time
- play the selection
- play from "here" option
- export shows to any folder
- mark an episode as watched
- update the library
- refresh the list
Would be great if people could try it out and let me know any bugs they find.
Finally, I have played around with a number of ideas for a new icon. Feel free to identify the one you like the most.
The latest version is in the Master Branch on GitHub.
https://github.com/KODeKarnage/script.lazytv
- refresh the list
watch gallery
2014-06-15, 11:13
Latest Release Changelog
0.9.9
Added context menu
- refresh the list
Add skinned list view (you can switch back to the default list view in the Settings.)
The icons below are some alternatives I have come up with. Let me know which one you like the best.
0.9.9
Added context menu
- refresh the list
watch gallery
2014-06-15, 11:14
Latest version is submitted to the official repo now.
Will update in a week or two when the translations are complete.
2014-06-16, 21:16
Glad you're adding skins to this! Unfortunately there are some issues making them currently unusable for me. Looks like there is no background, so it just becomes a mess when the skin elements are overlayed on the other elements behind. Standard view still works normally. Here are some screenshots:
Big Screen view: http://i.imgur.com/QSsraWE.png
Posters view: http://i.imgur.com/7u5YMUH.png
If it helps, my screen is a 1080p TV and I'm using the Ace skin on XBMC 13.1.
Finally, in my opinion this is by far the best icon!
2014-06-17, 00:11
(2014-06-16, 21:16)john6555 Wrote: [ -> ]Glad you're adding skins to this! Unfortunately there are some issues making them currently unusable for me. Looks like there is no background, so it just becomes a mess when the skin elements are overlayed on the other elements behind. Standard view still works normally. Here are some screenshots:
Thanks for giving it a go.
Your issue with the background is an odd one, and I cant replicate it, but I havent been able to try Ace skin yet. Will do later tonight.
There is a background specified in the xml. No idea why it isnt showing for you.
2014-06-17, 07:49
(2014-06-17, 00:11)Karnagious Wrote: [ -> ](2014-06-16, 21:16)john6555 Wrote: [ -> ]Glad you're adding skins to this! Unfortunately there are some issues making them currently unusable for me. Looks like there is no background, so it just becomes a mess when the skin elements are overlayed on the other elements behind. Standard view still works normally. Here are some screenshots:
I seem to have the same problem and my skin is Aeon Nox Gotham Plus
2014-06-17, 09:00
It appears that none of the artwork is showing up. I suspect a folder naming problem.
Nope, thats not it.
I wonder if some skins dont allow scaling of images?
Nope that cant be it either.
Nope, thats not it.
2014-06-17, 09:52
Ha! Figured it out.
The images werent uploaded to Github, only the links!
Will have it fixed in a couple of hours.
2014-06-17, 11:57
OK, images are updated.
Thanks for your patience.
2014-06-17, 17:59
There we go - looking good! My only suggestion right now would be to add an option to hide the episode summary (to avoid spoilers).
2014-06-18, 01:07
Good point. I will do that soon.
The plot only shows in the Posters view, not the Big Screen view.
2014-06-19, 13:13
(2014-05-11, 18:50)rjcogin Wrote: [ -> ]hi, a feature i used to really like was when the random list was generated lazyTV would always play the last episode you were already half way through,
is this feature still in the add-on? every time i start the plug-in now it starts a new random series even if i have a half watched episode.
(2014-05-12, 00:11)Karnagious Wrote: [ -> ]It didnt work with the new structure I was working on for the addon, but I can look at adding it back in now.
Hi, this feature worked about 3 updates ago but since the latest couple of updates it seems to not work again. any chance it could be added back in?
Cheers
