2014-04-11, 15:16
Ok, I will try that. I haven't had time to program my remote to work with Netflixbmc or xbmc for that matter, but will give it a shot this weekend.
(2014-04-11, 03:44)rmrende Wrote: [ -> ]I am getting "Could not connect to remote server" using both Frodo and Gothem Beta 3. I am running the newest OSX. I tried the recommendation above about changing the login URL. The error in the Xbmc logs is the same either way:
Quote:21:33:16 T:2953924608 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <class 'urllib2.URLError'>
Error Contents: <urlopen error [Errno 8] _ssl.c:480: EOF occurred in violation of protocol>
File "/Users/rmrende/Library/Application Support/XBMC/addons/plugin.video.netflixbmc/default.py", line 771, in <module>
index()
File "/Users/rmrende/Library/Application Support/XBMC/addons/plugin.video.netflixbmc/default.py", line 101, in index
if login():
File "/Users/rmrende/Library/Application Support/XBMC/addons/plugin.video.netflixbmc/default.py", line 473, in login
content = opener.open("http://movies.netflix.com/Login").read()
File "/Applications/XBMC Frodo.app/Contents/Frameworks/lib/python2.6/urllib2.py", line 397, in open
response = meth(req, response)
File "/Applications/XBMC Frodo.app/Contents/Frameworks/lib/python2.6/urllib2.py", line 510, in http_response
'http', request, response, code, msg, hdrs)
File "/Applications/XBMC Frodo.app/Contents/Frameworks/lib/python2.6/urllib2.py", line 429, in error
result = self._call_chain(*args)
File "/Applications/XBMC Frodo.app/Contents/Frameworks/lib/python2.6/urllib2.py", line 369, in _call_chain
result = func(*args)
File "/Applications/XBMC Frodo.app/Contents/Frameworks/lib/python2.6/urllib2.py", line 605, in http_error_302
return self.parent.open(new, timeout=req.timeout)
File "/Applications/XBMC Frodo.app/Contents/Frameworks/lib/python2.6/urllib2.py", line 391, in open
response = self._open(req, data)
File "/Applications/XBMC Frodo.app/Contents/Frameworks/lib/python2.6/urllib2.py", line 409, in _open
'_open', req)
File "/Applications/XBMC Frodo.app/Contents/Frameworks/lib/python2.6/urllib2.py", line 1169, in https_open
return self.do_open(httplib.HTTPSConnection, req)
File "/Applications/XBMC Frodo.app/Contents/Frameworks/lib/python2.6/urllib2.py", line 1136, in do_open
raise URLError(err)
URLError: <urlopen error [Errno 8] _ssl.c:480: EOF occurred in violation of protocol>
(2014-04-12, 20:50)rmrende Wrote: [ -> ]Has anyone else had this problem?Looks like you have problems with ssl. Are you using a proxy? If so, it must support ssl.
Play/Pause : ACTION_SELECT_ITEM
Seek backward : ACTION_MOVE_LEFT
Seek forward : ACTION_MOVE_RIGHT
Volume Up : ACTION_MOVE_UP
Volume Down : ACTION_MOVE_DOWN
Close Browser: ACTION_SHOW_INFO | ACTION_SHOW_GUI | ACTION_STOP | ACTION_PARENT_DIR | ACTION_PREVIOUS_MENU | KEY_BUTTON_BACK
(2014-04-12, 11:17)TVRRichard Wrote: [ -> ]Hi, I've almost got this working on Linux Mint 16. The issue I have is that after selecting a tv show/ movie etc. the item loads, and I can drag the progress bar and the correct frame will show, however I can't get the movie to play? I'm sure it's something stupid I'm doing as have not seen the issue here. Any pointers would be great, thanks.
(2014-04-14, 06:35)zepfan Wrote: [ -> ](2014-04-12, 11:17)TVRRichard Wrote: [ -> ]Hi, I've almost got this working on Linux Mint 16. The issue I have is that after selecting a tv show/ movie etc. the item loads, and I can drag the progress bar and the correct frame will show, however I can't get the movie to play? I'm sure it's something stupid I'm doing as have not seen the issue here. Any pointers would be great, thanks.
That's a pipelight issue. I've got the same atm, if I find a fix, I'll let you know.
(2014-04-13, 22:28)AddonScriptorDE Wrote: [ -> ](2014-04-12, 20:50)rmrende Wrote: [ -> ]Has anyone else had this problem?Looks like you have problems with ssl. Are you using a proxy? If so, it must support ssl.
(2014-04-14, 09:44)garydebergerac Wrote: [ -> ]I had the login error and applied that fix and then started getting script failed errors. This was yesterday so I don't remember what other fix I applied (line 63 or something?), but no change. First time ever messing with Windows 8, good god what a mess. I'm also logging in via a DNS, in case that makes any difference.
Log-
http://pastebin.com/uENDwSCX
(2014-04-14, 08:22)Krazyflipj Wrote: [ -> ]Anyone able to watch anything with WASAPI sound setting?
(2014-04-13, 22:28)AddonScriptorDE Wrote: [ -> ]Some also still had problems with dns/vpn. Have you tried the "locale" thing?
(2014-04-15, 03:11)Dixon Butz Wrote: [ -> ](2014-04-14, 08:22)Krazyflipj Wrote: [ -> ]Anyone able to watch anything with WASAPI sound setting?
Nope. With WASAPI on I get error code N8157-3142
Works with direct sound fine.
(2014-04-15, 21:27)ullms Wrote: [ -> ](2014-04-15, 03:11)Dixon Butz Wrote: [ -> ](2014-04-14, 08:22)Krazyflipj Wrote: [ -> ]Anyone able to watch anything with WASAPI sound setting?
WASAPI works but you have to turn off "Keep Audio Device Alive" under Audio settings. Had that issue also until I turned that off.
