2015-02-18, 00:56
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86
2015-02-18, 03:42
(2015-01-22, 00:20)corona Wrote: [ -> ]
This thread is for old / broken version of the plugin.
New thread for this plugin: http://forum.kodi.tv/showthread.php?tid=211574
Please continue all discussions there. Update to version in repo described in new thread first.
2015-03-20, 18:40
Error log http://xbmclogs.com/pjckw2hps (cant run netflixbmc in kodi)
2015-03-21, 11:49
(2015-02-18, 00:56)samldr1984 Wrote: [ -> ]I've followed all instructions and I can't see Netflix in the Repo, does it not work on Kodi 14.1? I'm on android too?
You didn't follow any instruction.
Read post #1 before responding.
This addon doesn't work for android., see faq.
I see that you did post 3 posts till now.
Remember that you respond to the first post in a forum, If you don't make use of quotes. That's the one who did start this thread.
Perhaps an other solution to your problem would be making use of a chromecast device.
I did buy one a few weeks ago, it's working very well.
With chromecast you can cast movies, tv episodes etc. from your android device to your tv. I am making use of an openelec device, also not working with this addon.
Since a few weeks I am making use of two devices connected to my tv, an openelec device (aurora) and a chromecast device.
I also have a htpc lenovo q190 (windows 8.1), which does have problems with this addon also. But from within the windows chrome browser I can cast every website to my tv also, making use of the chrome chromecast extension.
I don't make use of this addon no more, to much problems.
2015-04-01, 18:01
it took me a while but i finally got netflixbmc to install from the repo in the latest version of Kodi (Helix) as of 31/03/15... the app keeps giving me script failed errors when I try to access any content in netflix...
2015-04-11, 13:31
Hi
I am new to the forum so I am hoping I am listing this issue in the correct spot...
I keep getting a script error when trying to run Netflix xbmc on kodi helix 14.2 Any suggestions how to fix.
I also have chrome launcher installed.
2015-04-12, 15:47
(2015-04-11, 13:31)curlerman Wrote: [ -> ]Hi*******************************************************************
2015-04-14, 08:36
(2015-04-12, 15:47)JasonPell Wrote: [ -> ](2015-04-11, 13:31)curlerman Wrote: [ -> ]Hi*******************************************************************
This thread can be old, but the new thread did never work for me.
I don't think the new thread is the solution, my solution was stop making use of this addon, I did buy a chromecast device, which is working much better then this addon ever did.
2015-04-15, 00:14
(2015-04-14, 08:36)hstegeman Wrote: [ -> ]Seems like a overreaction. But each to their own. Many people successfully use the new addon and there are now 3+ developer contributing to its upkeep.(2015-04-12, 15:47)JasonPell Wrote: [ -> ](2015-04-11, 13:31)curlerman Wrote: [ -> ]Hi*******************************************************************
2015-05-01, 18:03
Hello!
I've installed the add-on and configured my account properly (tested it on the web browser) but couldn't get to log into my Netflix. When I try to browse the movies, tv shows, etc. It keeps showing the "Script Failed!" message.
Also I've installed the Chrome Launcher add-on.
By the way, I'm using the Helix 14 version.
Could anyone give some guidance or advice?
Thanks a lot!
Regards
Thanks a lot!
Regards
2015-05-01, 20:19
(2015-05-01, 18:03)RodrigoB Wrote: [ -> ]Hello!
Thanks a lot!
Regards
http://www.alelec.net/kodi/repository.alelec.zip
2015-05-02, 10:11
This thread should have been closed before, updates won't come from this thread.
2015-05-02, 21:52
(2015-05-02, 10:11)hstegeman Wrote: [ -> ]This thread should have been closed before, updates won't come from this thread.
That's why I posted above to guide towards the new thread.
2015-05-13, 17:51
Is OPENELEC 5.95 supported for both Chrome Launch and NetflixXBMC? I am getting script error form openelec 5.95. I also don't know how to view logs.
Any help would be greatly appreciated.
Windows version of plugin error log
11:58:25 T:8452 NOTICE: Thread LanguageInvoker start, auto delete: false
11:58:25 T:8452 NOTICE: -->Python Interpreter Initialized<--
11:58:25 T:8452 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <class 'urllib2.HTTPError'>
Error Contents: HTTP Error 500: Internal Server Error
File "C:\Users\Owner\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py", line 977, in <module>
listVideos(url, type)
File "C:\Users\Owner\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py", line 140, in listVideos
content = opener.open(url).read()
File "C:\Program Files (x86)\Kodi\system\python\Lib\urllib2.py", line 410, in open
response = meth(req, response)
File "C:\Program Files (x86)\Kodi\system\python\Lib\urllib2.py", line 523, in http_response
'http', request, response, code, msg, hdrs)
File "C:\Program Files (x86)\Kodi\system\python\Lib\urllib2.py", line 448, in error
return self._call_chain(*args)
File "C:\Program Files (x86)\Kodi\system\python\Lib\urllib2.py", line 382, in _call_chain
result = func(*args)
File "C:\Program Files (x86)\Kodi\system\python\Lib\urllib2.py", line 531, in http_error_default
raise HTTPError(req.get_full_url(), code, msg, hdrs, fp)
HTTPError: HTTP Error 500: Internal Server Error
11:58:25 T:8388 ERROR: CAESinkWASAPI::InitializeExclusive: IsFormatSupported failed (AUDCLNT_E_UNSUPPORTED_FORMAT) - trying to find a compatible format
11:58:25 T:7164 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.netflixbmc/?mode=listVideos&thumb&type=movie&url=http%3a%2f%2fwww.netflix.com%2fWiRecentAdditionsGallery%3fnRR%3dreleaseDate%26nRT%3dall%26pn%3d1%26np%3d1%26actionMethod%3djson
11:58:25 T:7164 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.netflixbmc/?mode=listVideos&thumb&type=movie&url=http%3a%2f%2fwww.netflix.com%2fWiRecentAdditionsGallery%3fnRR%3dreleaseDate%26nRT%3dall%26pn%3d1%26np%3d1%26actionMethod%3djson) failed
11:58:25 T:5752 NOTICE: Thread LanguageInvoker start, auto delete: false
11:58:25 T:5752 NOTICE: -->Python Interpreter Initialized<--
11:58:25 T:4352 NOTICE: Thread BackgroundLoader start, auto delete: false
2015-05-20, 22:29
Wrong thread
