2014-11-30, 01:10
(2014-11-29, 21:13)-Dis Wrote: [ -> ]I get this error:
Any ideas how to fix this?
What OS are you running ?
Looks like some python code is unsupported
(2014-11-30, 13:32)Justintoxicated Wrote: [ -> ]So I got this working on 13.2, well somewhat anyways. When I try to play TV shows I get a script error. Movies seem to play fine though using chrome plugin. "My List" and "Viewing Activity" do not seem to work for movies or TV. Anyone know why I get script errors when trying to view tv shows? Without that working I'm still going to need to buy a dedicated device
(2014-11-30, 13:39)marcelveldt Wrote: [ -> ](2014-11-30, 13:32)Justintoxicated Wrote: [ -> ]So I got this working on 13.2, well somewhat anyways. When I try to play TV shows I get a script error. Movies seem to play fine though using chrome plugin. "My List" and "Viewing Activity" do not seem to work for movies or TV. Anyone know why I get script errors when trying to view tv shows? Without that working I'm still going to need to buy a dedicated device
There are currently some issues with the add-on, we're waiting (and hoping) for the author, AddonScripterDE to fix those.
In the meanwhile several users have published some DIY fixes in this forum and member corona and myself provided a modded version.
Are you using one of the modded versions with the fixes ?
(2014-11-30, 20:07)Justintoxicated Wrote: [ -> ](2014-11-30, 13:39)marcelveldt Wrote: [ -> ](2014-11-30, 13:32)Justintoxicated Wrote: [ -> ]So I got this working on 13.2, well somewhat anyways. When I try to play TV shows I get a script error. Movies seem to play fine though using chrome plugin. "My List" and "Viewing Activity" do not seem to work for movies or TV. Anyone know why I get script errors when trying to view tv shows? Without that working I'm still going to need to buy a dedicated device
I can't get your modded version to install I get an installation failed error. I'm on windows 7 if that matters. Oh, and your version and corornas both fail to install. Where is the log located?
Are there steps I need to take prior to installing your version? I tried both installing over and removing the old version from within xbmc.
I mean I see the source file under the plugin, but I'm not familiar with python. If I want to make some changes how to I re-compile and zip it back up? (I'm a java dev that has never played with python)
Quote: I mean I see the source file under the plugin, but I'm not familiar with python. If I want to make some changes how to I re-compile and zip it back up? (I'm a java dev that has never played with python)
20:23:36 T:140140974114560 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <class 'urllib2.URLError'>
Error Contents: <urlopen error [Errno 1] _ssl.c:510: error:14077410:SSL routines:SSL23_GET_SERVER_HELLO:sslv3 alert handshake failure>
File "/home/oliver/.kodi/addons/plugin.video.netflixbmc/default.py", line 1024, in <module>
index()
File "/home/oliver/.kodi/addons/plugin.video.netflixbmc/default.py", line 99, in index
if login():
File "/home/oliver/.kodi/addons/plugin.video.netflixbmc/default.py", line 638, in login
content = opener.open(urlMain+"/Login").read()
File "/usr/lib/python2.7/urllib2.py", line 410, in open
response = meth(req, response)
File "/usr/lib/python2.7/urllib2.py", line 523, in http_response
'http', request, response, code, msg, hdrs)
File "/usr/lib/python2.7/urllib2.py", line 442, in error
result = self._call_chain(*args)
File "/usr/lib/python2.7/urllib2.py", line 382, in _call_chain
result = func(*args)
File "/usr/lib/python2.7/urllib2.py", line 629, in http_error_302
return self.parent.open(new, timeout=req.timeout)
File "/usr/lib/python2.7/urllib2.py", line 404, in open
response = self._open(req, data)
File "/usr/lib/python2.7/urllib2.py", line 422, in _open
'_open', req)
File "/usr/lib/python2.7/urllib2.py", line 1222, in https_open
return self.do_open(httplib.HTTPSConnection, req)
File "/usr/lib/python2.7/urllib2.py", line 1184, in do_open
raise URLError(err)
URLError: <urlopen error [Errno 1] _ssl.c:510: error:14077410:SSL routines:SSL23_GET_SERVER_HELLO:sslv3 alert handshake failure>
20:23:36 T:140142988552128 ERROR: GetDirectory - Error getting plugin://plugin.video.netflixbmc/
20:23:36 T:140142988552128 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.netflixbmc/) failed
(2014-11-30, 22:32)mrnorm Wrote: [ -> ]Great plugin! Just got a workable solution now on my Ubuntu 14.04 box.
I'm having an issue when going through my SNI proxy for Netflix US shows. I'm seeing the following message:
Code:20:23:36 T:140140974114560 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
index()
if login():
<snip>
Has anyone else got this? Seems to be related to POODLE as it's referring to SSLv3
Any help would be appreciated.
17:41:49 T:3692 ERROR: CAESinkDirectSound::Initialize: Failed to create the DirectSound device with error DSERR_NODRIVER, trying the default device.
17:41:49 T:3692 ERROR: CAESinkDirectSound::Initialize: Failed to create the default DirectSound device with error DSERR_NODRIVER.
17:41:49 T:5044 NOTICE: Thread AESinkNull start, auto delete: false
17:41:50 T:2752 NOTICE: Thread JobWorker start, auto delete: true
17:41:50 T:5684 NOTICE: Thread LanguageInvoker start, auto delete: false
17:41:50 T:3440 NOTICE: Thread JobWorker start, auto delete: true
17:41:50 T:5684 NOTICE: -->Python Interpreter Initialized<--
17:41:50 T:5140 NOTICE: Thread RSSReader start, auto delete: false
17:42:04 T:5840 NOTICE: Thread BackgroundLoader start, auto delete: false
17:42:30 T:3440 ERROR: XFILE::CFile::Delete - Error deleting file C:\Users\Crystalstar\AppData\Roaming\XBMC\addons\plugin.video.netflixbmc\resources\NetfliXBMC_Utility.exe
17:42:30 T:3440 ERROR: XFILE::CFile::Delete - Error deleting file special://home/addons/plugin.video.netflixbmc/resources/NetfliXBMC_Utility.exe
17:42:30 T:3440 ERROR: Could not read addon description of plugin.video.netflixbmc
17:42:30 T:2564 NOTICE: Thread BackgroundLoader start, auto delete: false
18:10:40 T:3376 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.NameError'>
Error Contents: global name 'country' is not defined
File "C:\Users\Crystalstar\AppData\Roaming\XBMC\addons\plugin.video.netflixbmc\default.py", line 1076, in <module>
listSeasons(name, url, thumb)
File "C:\Users\Crystalstar\AppData\Roaming\XBMC\addons\plugin.video.netflixbmc\default.py", line 397, in listSeasons
content = getSeriesInfo(seriesID)
File "C:\Users\Crystalstar\AppData\Roaming\XBMC\addons\plugin.video.netflixbmc\default.py", line 496, in getSeriesInfo
url = "http://api-global.netflix.com/desktop/odp/episodes?languages="+language+"&forceEpisodes=true&routing=redirect&video="+seriesID+"&country="+country
NameError: global name 'country' is not defined
18:10:40 T:2128 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.netflixbmc/?mode=listSeasons&name=Futurama&thumb=C%3a%5cUsers%5cCrystalstar%5cAppData%5cRoaming%5cXBMC%5cuserdata%5caddon_data%5cplugin.video.netflixbmc%5ccache%5ccovers%5c70153380.jpg&url=70153380
18:10:40 T:2128 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.netflixbmc/?mode=listSeasons&name=Futurama&thumb=C%3a%5cUsers%5cCrystalstar%5cAppData%5cRoaming%5cXBMC%5cuserdata%5caddon_data%5cplugin.video.netflixbmc%5ccache%5ccovers%5c70153380.jpg&url=70153380) failed
if len(language.split("-"))>1:
country = language.split("-")[1]
ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.netflixbmc/?mode=playVideoMain&url=70140691
18:37:19 T:4344 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.netflixbmc/?mode=playVideoMain&url=70140691) failed
17:32:12 T:140096627681024 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.ValueError'>
Error Contents: No JSON object could be decoded
File "/var/lib/vdr/.kodi/addons/plugin.video.netflixbmc/default.py", line 1076, in <module>
File "/var/lib/vdr/.kodi/addons/plugin.video.netflixbmc/default.py", line 398, in listSeasons
content = json.loads(content)
File "/usr/lib/python2.7/json/__init__.py", line 326, in loads
return _default_decoder.decode(s)
File "/usr/lib/python2.7/json/decoder.py", line 366, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/usr/lib/python2.7/json/decoder.py", line 384, in raw_decode
raise ValueError("No JSON object could be decoded")
ValueError: No JSON object could be decoded
17:32:12 T:140097762994048 ERROR: GetDirectory - Error getting plugin://plugin.video.netflixbmc/?mode=listSeasons&name=30.11.2014%20-%20The%20X-Files%3a%20Kausi%201%3a%20%22Shapes%22&thumb=%2fvar%2flib%2fvdr%2f.kodi%2fuserdata%2faddon_data%2fplugin.video.netflixbmc%2fcache%2fcovers%2f70134177.jpg&url=70134177
17:32:12 T:140097762994048 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.netflixbmc/?mode=listSeasons&name=30.11.2014%20-%20The%20X-Files%3a%20Kausi%201%3a%20%22Shapes%22&thumb=%2fvar%2flib%2fvdr%2f.kodi%2fuserdata%2faddon_data%2fplugin.video.netflixbmc%2fcache%2fcovers%2f70134177.jpg&url=70134177) failed
17:32:12 T:140096627681024 NOTICE: Thread BackgroundLoader start, auto delete: false
17:55:48 T:140095856310016 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.UnicodeDecodeError'>
Error Contents: 'ascii' codec can't decode byte 0xc3 in position 8: ordinal not in range(128)
File "/var/lib/vdr/.kodi/addons/plugin.video.netflixbmc/default.py", line 1050, in <module>
listVideos(url, type)
