(2014-03-24, 22:21)negge Wrote: [ -> ]@J3mm: you're changing the wrong files, the installed addons are in ~/.xbmc/addons.
Ah ok... so if I look in that directory, I don't seem to have anything related to per clients:
:~/.xbmc/addons$ ls
metadata.album.universal plugin.video.iplayer script.module.elementtree service.libraryautoupdate
metadata.artists.universal plugin.video.netflixbmc script.module.mechanize service.qlock
metadata.common.allmusic.com plugin.video.youtube script.module.parsedom service.rom.collection.browser
metadata.common.amazon.de repository.addonscriptorde-beta script.module.requests2 service.skin.widgets
metadata.common.fanart.tv script.aeonmq5.extrapack script.module.simple.downloader service.subtitles.opensubtitles
metadata.common.hdtrailers.net script.artistslideshow script.module.simplejson service.xbmc.versioncheck
metadata.common.htbackdrops.com script.artwork.downloader script.moviequiz skin.aeonmq5
metadata.common.imdb.com script.cinema.experience script.playalbum skin.aeon.nox
metadata.common.last.fm script.common.plugin.cache script.playlists skin.amber
metadata.common.musicbrainz.org script.cu.lrclyrics script.randomandlastitems skin.bello
metadata.common.theaudiodb.com script.facebook.media script.rss.editor skin.hybrid
metadata.common.themoviedb.org script.favourites script.simpleplaylists skin.nbox
metadata.musicvideos.theaudiodb.com script.game.netwalk script.tv.show.next.aired skin.pm3-hd
metadata.themoviedb.org script.games.rom.collection.browser script.tvtunes skin.transparency
metadata.tvdb.com script.globalsearch script.videolanguage skin.xperience1080
packages script.module.beautifulsoup script.xbmc.audio.mixer skin.xperience-more
plugin.audio.di.fm script.module.buggalo script.xbmcbackup weather.wunderground
plugin.program.chrome.launcher script.module.chardet script.xbmc.debug.log
I've tried uninstalling the tvh add-on manager, and now I can't even add the old one back for some reason!?
Just unzip pvr.tvh to ~/.xbmc/addons, it will then show up under Disabled addons. And remove the ones from /usr/share/whatever/addons (if you've installed them using apt-get then use apt-get to remove them, otherwise just remove them manually).
(2014-03-24, 22:43)negge Wrote: [ -> ]Just unzip pvr.tvh to ~/.xbmc/addons, it will then show up under Disabled addons. And remove the ones from /usr/share/whatever/addons (if you've installed them using apt-get then use apt-get to remove them, otherwise just remove them manually).
Thanks - ok, it's showing up correctly but when I try enabling it, it fails, and the log shows:
21:08:48 T:2551151424 ERROR: Unable to load /home/me/.xbmc/addons/pvr.tvh/XBMC_pvr_tvh.pvr, reason: /home/me/.xbmc/addons/pvr.tvh/XBMC_pvr_tvh.pvr: wrong ELF class: ELFCLASS64
Have I got the wrong version?
$ uname -a
Linux zbox 3.5.0-46-generic #70-Ubuntu SMP Wed Jan 8 18:43:34 UTC 2014 i686 i686 i686 GNU/Linux
You're trying to use the 64-bit addon on a 32-bit system. You'll have to compile it yourself.
(2014-03-24, 23:44)negge Wrote: [ -> ]You're trying to use the 64-bit addon on a 32-bit system. You'll have to compile it yourself.
Gah of course... should have spotted that!
Ok so I've cloned and compiled from
https://github.com/adamsutton/xbmc-pvr-addons
cd xbmc-pvr-addons
./bootstrap
./configure --prefix=/home/me/.xbmc
sudo make install
It didn't put the files in the right places, so I moved them into .xbmc/addons and rebooted, just to make sure.
It's now reporting version 0.4 and is working, but no EPG...?
You can't use --prefix that way, you're supposed to configure without a prefix, compile and then run "make zip" to create the ZIP files that can then be installed normally in XBMC. But it seems you got it working anyway.
Many people have complained about EPG issues, I suggest you reset the PVR database and if it doesn't work, enable the "Asynchronous EPG" option in the addon. I haven't had time to look at the EPG issues myself, it works fine for me at least with the async option.
Ok, so have enabled asynchronous EPG, but still no info. If I enable the trace it's definitely coming through - going bonkers in the log - excerpt here:
http://pastebin.com/6khBBP7J
Also I just can't play recordings via the add-on. Never have, so perhaps not a version thing but it just breaks up as if I'm playing something it can't cope with (yet other 1080p media from server plays fine, if I map an NFS share it's happy). Gig ethernet wired to the backend, and the mem / cpu barely even registers. Debug trace of trying to play a recording here - there's something manic going on here I can't quite get my head around...
http://pastebin.com/8Uawbsxp
BTW not sure where I got the --prefix idea from, I think it was from a tvheadend thread on compiling, but tvheadend.org has been down for quite a while so can't check some of the links I've got bookmarked...
Try resetting the PVR database, that should get you going.
What version of tvheadend are you using?
Resetting the PVR db doesn't do much unfortunately - keep trying that...
3.5.247~g098b7de~saucy
This appears to be where it gets stuck on the playback:
23:49:12 T:2042587968 DEBUG: ffmpeg[79BF6B40]: [mpegts] parser not found for codec none, packets or times may be invalid.
23:49:12 T:2042587968 DEBUG: Previous line repeats 1 times.
23:49:12 T:2042587968 ERROR: ffmpeg[79BF6B40]: [h264] non-existing SPS 0 referenced in buffering period
23:49:12 T:2042587968 ERROR: ffmpeg[79BF6B40]: [h264] non-existing PPS referenced
I was referring to the missing EPG, naturally resetting the database won't fix your recordings. It sounds like a bug in tvheadend, but there's no development for the stable version anymore so you'll have to try the master branch to see if it fixes the issue.
Yes, doesn't fix the EPG for me unfortunately. All the info is in the logs, but no EPG and no ability to watch recordings
I'm probably out of my depth but I switched from a Myth backend to TVheadend as I was having problems with Myth, and I think I've just jumped out of the frying pan into the fire
Does the EPG work with the official pvr.hts addon?
(2014-03-26, 19:28)negge Wrote: [ -> ]Does the EPG work with the official pvr.hts addon?
Yes indeed. Of course, I can't guarantee I haven't broken it somehow else, but I don't believe I have at least
As a last resort you could uncheck "Use EPG database" and then reset the whole PVR database once more. Also check the async option in the addon. That's the settings I use and it works fine.
I had a look today and I was completely unable to get the EPG to *not* appear. I tried all combinations of settings and all worked. Are guys completely sure you're using the very latest build (cause this bug was fixed some time ago)?
