2014-10-31, 19:02
(2014-10-31, 18:38)Matt Devo Wrote: [ -> ]if you're trying to do a standalone OpenELEC, and your install media isn't working, then just use a different USB stick/SD card, download OpenELEC from their site, and create the install media as per their instructions. Info is on the ChromeBox wiki. Since you've performed a standalone setup (which flashes the firmware), your ChromeBox is basically a regular PC now, not a ChromeOS device.
there's no need to do a factory reset, but if you were going to, you need to first restore the stock firmware, again as per the wiki.
Wow... I was trying to do something wrong, definitely. Openlec works fine now, thanks
Br,
