Good so now it will get supported ? thanks
i completed translate 75% of the Arabic language until now and i hope you sync my translation in the next release.
i see the letters in the rows in your code.
here is the pic of the present Keyboard in 2.4.0 ..
you can see
ج and و and ة are missing.
Hi,is there any way to remove RightList View?
Franciscocrb, why remove, if don´t like RightList, have many others available, only need change.
In some addons put another view and then again RightList
sorry for my English
Rightlist is default mode view, and it´s no global, you need change addon by addon for other view mode.
New background for movies, will be available in the next release. About image, I don´t have idea, I think Marcos changed.
(2015-10-26, 12:22)Wanilton Wrote: [ -> ]@Franciscocrb, why remove, if don´t like RightList, have many others available, only need change.
Hi wanilton
Where is this menu found ?
I've been looking to change my view but gave up looking.
I have been pressing up when in my library but can't find it there like with other skins
Cheers
Hi wanilton
Cheers
when in library, just press up 3 times.
Or left/right/down.. it depends on which view you're in. You basically move off the menu. If you have a vertical menu, go to the sides. If you have a horizontal menu, go to the top or bottom. If you can bring up the menu for view styles, art, etc.. it's UP after that.
Steve_uk and Trotter81, here one video about
I am missing the subtitle and audio info, in the movies section.
the swith is ON.
Is this a MOD or it not in 3.0.0 yet ?
Need script videolanguage for show, see image
Where do find this script? Mq6 for RPI2.
