Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
(2015-12-23, 05:31)graysky Wrote: [ -> ]I am getting a freeze of the kodi interface when this screensaver is invoked on an up-to-date Arch box. Here is the debug log as the screensaver is activated after the timeout period:
22:25:02 T:139951226218624 DEBUG: CAnnouncementManager - Announcement: OnScreensaverActivated from xbmc
22:25:02 T:139951226218624 DEBUG: GOT ANNOUNCEMENT, type: 4, from xbmc, message OnScreensaverActivated
22:25:02 T:139951226218624 DEBUG: Activating window ID: 12900
22:25:02 T:139951226218624 DEBUG: ------ Window Deinit (SettingsCategory.xml) ------
22:25:02 T:139951226218624 DEBUG: ------ Window Init () ------
22:25:02 T:139949689005824 NOTICE: Thread LanguageInvoker start, auto delete: false
22:25:02 T:139949689005824 INFO: initializing python engine.
22:25:02 T:139949689005824 DEBUG: CPythonInvoker(6, /var/lib/kodi/.kodi/addons/screensaver.atv4/atv.py): start processing
22:25:02 T:139949689005824 NOTICE: -->Python Interpreter Initialized<--
22:25:02 T:139949689005824 DEBUG: CPythonInvoker(6, /var/lib/kodi/.kodi/addons/screensaver.atv4/atv.py): the source file to load is "/var/lib/kodi/.kodi/addons/screensaver.atv4/atv.py"
22:25:02 T:139949689005824 DEBUG: CPythonInvoker(6, /var/lib/kodi/.kodi/addons/screensaver.atv4/atv.py): setting the Python path to /var/lib/kodi/.kodi/addons/screensaver.atv4:/usr/lib/python27.zip:/usr/lib/python2.7:/usr/lib/python2.7/plat-linux2:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/lib/python2.7/site-packages
22:25:02 T:139949689005824 DEBUG: CPythonInvoker(6, /var/lib/kodi/.kodi/addons/screensaver.atv4/atv.py): entering source directory /var/lib/kodi/.kodi/addons/screensaver.atv4
22:25:02 T:139949689005824 DEBUG: CPythonInvoker(6, /var/lib/kodi/.kodi/addons/screensaver.atv4/atv.py): instantiating addon using automatically obtained id of "screensaver.atv4" dependent on version 2.1.0 of the xbmc.python api
22:25:02 T:139949689005824 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
22:25:02 T:139951226218624 DEBUG: started alarm with name: sssssscreensaver
22:25:02 T:139951226218624 DEBUG: ------ Window Deinit () ------
22:25:02 T:139949689005824 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
22:25:02 T:139949689005824 DEBUG: ------ Window Init (SettingsCategory.xml) ------
22:25:02 T:139950066579200 NOTICE: Thread AlarmClock start, auto delete: false
22:25:02 T:139949689005824 DEBUG: CAnnouncementManager - Announcement: OnScreensaverDeactivated from xbmc
22:25:02 T:139949689005824 DEBUG: GOT ANNOUNCEMENT, type: 4, from xbmc, message OnScreensaverDeactivated
22:25:02 T:139949689005824 DEBUG: POParser: loaded 19 strings from file /var/lib/kodi/.kodi/addons/screensaver.atv4/resources/language/English/strings.po
22:25:02 T:139951226218624 DEBUG: ------ Window Init (DialogKaiToast.xml) ------
22:25:02 T:139951226218624 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/ImageLib-x86_64-linux.so)
22:25:02 T:139951226218624 DEBUG: Loading: /usr/lib/kodi/system/ImageLib-x86_64-linux.so
22:25:04 T:139951226218624 DEBUG: ------ Window Deinit (DialogKaiToast.xml) ------
The entire GUI is frozen at this point.
Problem is that a video is not really a screensaver, when you start a video you basically deactivate the screensaver. So the addon does a sort of a hack...
It starts by calling some input for the screensaver to be deactivated, waits for the event and starts the video playback. Sometimes, or for some machines the waiting time may not be enough and the screensaver starts playing near the deactivate action..freezing the interface.
I'll probably add a setting for users to configure this waiting timeout manually
I understand. I am happy to test out some code when you author it
I'm getting stuttering when the add-on is run after the screensaver activates, but not when I test it out. I was thinking at first it could be because of my internet connection, so I setup a folder on my server and tried to download the videos to there, but it's not working.
Debug log for downloading the videos:
http://xbmclogs.com/pwwbru1xb
Thanks for bringing this awesome videos to Kodi!
But the videos are not shuffeled here. They always have the same order.
I installed it from the offical repositories. v1.3.0
Already tried to reinstall the addon.
Thanks for a great add-on!
One thing thought - right now when screensaver is starting there's a message "Initialiazing" or whatever and notification sound. Can you get rid of the both? It makes experience a little bit smoother.
Plus I don't know whether it's a bug or not - but you can't start a screensaver using PREVIEW in Kodi's Appearences - Screensaver setting. It's just shows same notification and that is it (I got all the videos downloaded locally). But it's still working while idling in the menu
There's a setting in the addon settings to disable the notification. The preview is working fine for me on all my machines running Isengard unfortunately I cant reproduce the bug.
Can you provider more details about your system?
enen92 - Any time for you check into the
issue I am experiencing?
(2015-12-23, 23:07)enen92 Wrote: [ -> ]Problem is that a video is not really a screensaver, when you start a video you basically deactivate the screensaver. So the addon does a sort of a hack...
Hey enen92,
amazing Addon! I love it. However I've got a severe problem. When I play music or radio channels via the radio addon for Kodi and do not browse Kodi, the screensaver activates anyways. Meaning: Even though a file is played (music or radio), the video tries to play however freezes immediately. The music keeps playing but when I press a button to get rid of the frozen video/image the playing stops and I am back in the main menu or file browser.
I would love either of these solutions:
1) Play the screensaver videos during listening to music
-I know this is not possible as the screensaver videos are regardes as normal videos and you cant play two files at a time.
2) Deactivate the screensaver when playing audio files.
-I dont know if this is possible but would solve my problem too, i guess.
Thank you in advance for tips and tricks!
I use:
Raspberry Pi2
Kodi 15.2 Isengard in openelec 6.0.1
(2015-12-23, 00:49)graysky Wrote: [ -> ]Really cool; thank you for this. Where does the addon pull the videos? I see in offline mode is can cache them to the disk but what is the source?
EDIT: http://9to5mac.com/2015/10/19/apple-tv-4...nsavers-2/
Sorry, life has been pretty busy lately. Finally found some time to work a bit on it. It turns out I was instantiating the monitor class after the onDeactivate method
The monitor class would only catch the onDeactivate method by luck lol making the interface to freeze.
Also it looks like Helix has some problems with the screensaver (in fact it was developed and tested using Isengard) so I decided to bump also the python ABI version and hopefully will ask the Team to move it to isengard repository.
Can you please test the version in master and check if you still have troubles with it?
https://github.com/enen92/screensaver.atv4
Sorry for the big delay
PS: Tested on the weaker hardware I have available (RPI 1) and no freezes
(2016-02-02, 20:24)ShorK Wrote: [ -> ]Hey enen92,
I use:
Raspberry Pi2
Also moved the Player.HasMedia check somewhere before the window is started so with the version that is now on the master branch the screensaver should not be triggered when playing media. Please test and report back so an update can be issued:
(2016-02-03, 16:33)enen92 Wrote: [ -> ] (2016-02-02, 20:24)ShorK Wrote: [ -> ]Hey enen92,
I use:
Raspberry Pi2
Dude I love you. Works perfectly. My problem is solved!
However, the start of the screensaver changed. It looks like this:
Youtube Video
So basically it is retrieving the video list showing the Golden Gate bridge image in the background and loading a random video (according to my settings) afterwards.
As far as i remember this has not always been like that.
If yes, dont mind and ignore this.
It was supposed to be like that from the start
The bug wasn't allowing it to behave like in your video.
Thanks for the video as well, added to post #1
(2016-02-03, 16:32)enen92 Wrote: [ -> ]Sorry, life has been pretty busy lately. Finally found some time to work a bit on it. It turns out I was instantiating the monitor class after the onDeactivate method The monitor class would only catch the onDeactivate method by luck lol making the interface to freeze.
I replied in the github issue (
https://github.com/enen92/screensaver.atv4/issues/4) and will update there. Thanks!
Hi there I love the screensaver its amazing!! I was wondering if it is not possible to play music via kodi during screensaver playback due to the prior mentioned video usage. Would it be possible to allow airplay while the screensaver was active? I wanted to airplay music through kodi to my stereo and limit the burn in on my plasma! thanks great work!
(2016-02-03, 22:32)wizzord Wrote: [ -> ]Hi there I love the screensaver its amazing!! I was wondering if it is not possible to play music via kodi during screensaver playback due to the prior mentioned video usage. Would it be possible to allow airplay while the screensaver was active? I wanted to airplay music through kodi to my stereo and limit the burn in on my plasma! thanks great work!
Nop, the same problem applies. It doesn't matter much how the audio/videos reach Kodi but how they are played.
