Full Version: Aerial (ATV4 Screensavers)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
i'm not able to choose a download folder for offline screensaver. i choose a folder and press on download videos but still it asks to choose folder...help?
EDIT: issue fixed by allowing the screensaver to start while the download folder is selected. then after waking up from screensaver, the download videos button will work.
(2015-11-18, 06:32)fritzboyle Wrote: [ -> ]Has anyone put this on the Nvidia shield or some other android TV device?
I was able to install is and it works great, except for the issue that it is actually running a video vs being a standalone screensaver. this makes it so that it will stop any audio (was hoping to have the screensaver while playing audio). FULL DISCLOSURE: I have not turned this back on in a couple months so I am not sure whether this issue has been addressed or fixed.
all that being said, it looks beautiful and I really hope it can be made to work more seamlessly.
Hi!
I am using version 1.3.1 on openelec 6.0.1/Pi 2 and I have the following issue:
Kodi is running and I'm switching the source on my TV (to another Input or TV-Mode). At that moment when the screensaver is starting (--> after 5 minutes), my TV is switching back to the source of my rapsberry (HDMI) automatically.
I don't want that automatic switch. Is there an option to disable it?
thanks!
Thats an option in config.txt of the pi distro, i dont remember exactly which one. But it is external to the addon.
Irrc its hdmi_ignore_hotplug=1
(2016-02-21, 17:33)enen92 Wrote: [ -> ]Irrc its hdmi_ignore_hotplug=1
No, this will be a CEC issue. Try system/input/peripherals/cec.
(2016-02-21, 18:07)popcornmix Wrote: [ -> ]
Yes, I was looking there but I don't know which option I have to choose. Huh
Popcornmix is right it's a CEC issue. I think it is the same behaviour that happens when your tv is off and you restart the pi. The tv is automatically turned on.
I really don't remember the name of the property to disable that default behaviour you are probably better looking in raspberry pi forums. It is not hdmi_ignore_hotplug, probably hdmi_ignore_cec_init=1? Popcornmix probably knows better.
Okay I had to disable "switch source to this device on startup" in the CEC preferences
Hey enen92,
enjoying your good work, I realized another little "inconvenience". After running for quite some time, the screensaver turns into a black screen. I think it occurs when all videos have been played but I am not sure about it. Is possible to change the settings to play them in an endless loop?
Cheers mate.
Hi
I have a little problem/bug: When the screensaver was active, the video playing is switched to loop: So if I watch a video after the screensaver was running the video will be replayed consistently and I have to go to the playlist-preferences and disable the repeat-option.
Is there a possibility to change that?
This thing is beautiful! Thank you!
For some reason, I am not seeing it truly full screen:
This a view using TeamViewer, but it looks the same on my TV.That's Aeon Nox in the background/borders.
Any thoughts on how to expand the screensaver to full screen?
(2016-02-26, 16:28)effe.rnr Wrote: [ -> ]Hi
I still have the problem. It's really annoying to change the repeat thing every time. I thing this line is not working for me:
def onPlayBackStopped(self):
xbmc.log(msg='ATV4 Screensaver player has been stopped', level=xbmc.LOGDEBUG)
xbmc.executebuiltin("PlayerControl(RepeatOff)", True)
return
just grabbed this from official repo in kodi 16 (jarvis), went to settings, setup offline folder and told it to grab all the vidoes.
now going to settings > appearance > screen saver > preview.. kodi hangs.
15:03:14 T:1084   DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
15:03:15 T:1084   DEBUG: CInputManager::OnKey: return (0xf00d) pressed, action is Select
15:03:15 T:1084   DEBUG: CAnnouncementManager - Announcement: OnScreensaverActivated from xbmc
15:03:15 T:1084   DEBUG: GOT ANNOUNCEMENT, type: 4, from xbmc, message OnScreensaverActivated
15:03:15 T:1084   DEBUG: Activating window ID: 12900
15:03:15 T:1084   DEBUG: ------ Window Deinit (SettingsCategory.xml) ------
15:03:15 T:1084   DEBUG: ------ Window Init () ------
15:03:15 T:3312   DEBUG: Thread LanguageInvoker start, auto delete: false
15:03:15 T:3312    INFO: initializing python engine.
15:03:15 T:3312   DEBUG: CPythonInvoker(8, C:\Users\mel\AppData\Roaming\Kodi\addons\screensaver.atv4\atv.py): start processing
15:03:15 T:3312   DEBUG: -->Python Interpreter Initialized<--
15:03:15 T:3312   DEBUG: CPythonInvoker(8, C:\Users\mel\AppData\Roaming\Kodi\addons\screensaver.atv4\atv.py): the source file to load is "C:\Users\mel\AppData\Roaming\Kodi\addons\screensaver.atv4\atv.py"
15:03:15 T:3312   DEBUG: CPythonInvoker(8, C:\Users\mel\AppData\Roaming\Kodi\addons\screensaver.atv4\atv.py): setting the Python path to C:\Users\mel\AppData\Roaming\Kodi\addons\screensaver.atv4;C:\Program Files (x86)\Kodi\system\python\DLLs;C:\Program Files (x86)\Kodi\system\python\Lib;C:\Program Files (x86)\Kodi\python27.zip;C:\Program Files (x86)\Kodi\system\python\lib\plat-win;C:\Program Files (x86)\Kodi\system\python\lib\lib-tk;C:\Program Files (x86)\Kodi;C:\Program Files (x86)\Kodi\system\python;C:\Program Files (x86)\Kodi\system\python\lib\site-packages
15:03:15 T:3312   DEBUG: CPythonInvoker(8, C:\Users\mel\AppData\Roaming\Kodi\addons\screensaver.atv4\atv.py): entering source directory C:\Users\mel\AppData\Roaming\Kodi\addons\screensaver.atv4
15:03:15 T:3312   DEBUG: CPythonInvoker(8, C:\Users\mel\AppData\Roaming\Kodi\addons\screensaver.atv4\atv.py): instantiating addon using automatically obtained id of "screensaver.atv4" dependent on version 2.1.0 of the xbmc.python api
15:03:15 T:3312   DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
15:03:15 T:1084   DEBUG: started alarm with name: sssssscreensaver
15:03:15 T:1084   DEBUG: ------ Window Deinit () ------
15:03:15 T:3312   DEBUG: CGUIWindowManager::PreviousWindow: Activate new
15:03:15 T:3312   DEBUG: ------ Window Init (SettingsCategory.xml) ------
15:03:15 T:820   DEBUG: Thread AlarmClock start, auto delete: false
15:03:15 T:3312   DEBUG: CAnnouncementManager - Announcement: OnScreensaverDeactivated from xbmc
15:03:15 T:3312   DEBUG: GOT ANNOUNCEMENT, type: 4, from xbmc, message OnScreensaverDeactivated
15:03:15 T:3312   DEBUG: POParser: loaded 19 strings from file C:\Users\mel\AppData\Roaming\Kodi\addons\screensaver.atv4\resources\language\English\strings.po
15:03:15 T:1084   DEBUG: ------ Window Init (DialogKaiToast.xml) ------
15:03:16 T:4276   DEBUG: CVideoDatabase::RunQuery took 0 ms for 0 items query: select * from musicvideo_view
15:03:16 T:4276    INFO: CPythonInvoker(6, C:\Users\mel\AppData\Roaming\Kodi\addons\script.videoextras\service.py): script successfully run
15:03:16 T:4276    INFO: Python script stopped
15:03:16 T:4276   DEBUG: Thread LanguageInvoker 4276 terminating
15:03:17 T:1084   DEBUG: ------ Window Deinit (DialogKaiToast.xml) ------
15:03:20 T:3312 WARNING: CSkinInfo: failed to load skin settings
15:03:39 T:3024   DEBUG: Thread JobWorker 3024 terminating (autodelete)
15:03:39 T:4988   DEBUG: Thread JobWorker 4988 terminating (autodelete)
15:03:39 T:2472   DEBUG: Thread JobWorker 2472 terminating (autodelete)
15:03:39 T:4852   DEBUG: Thread JobWorker 4852 terminating (autodelete)
grabbing latest from: https://github.com/enen92/screensaver.atv4
extracting over existing install...
now preview works, always plays the same first video.. go to settings and disable ny now it plays the next one.. but always that one (not sure if its supposed to randomize... most screensavers would.. why im noting it).
one thing I noticed is that it plays the video.. (choppy) then after 5 secs it pauses.. then plays smoothly afterwards. it does this every time if i back out and then back into preview.
machine is core i7 2.8ghz+ssd+nvidia GeForce GT 730.. so i find it quite abnormal to see any choppy video... logs below:
15:22:33 T:4860   DEBUG: started alarm with name: sssssscreensaver
15:22:33 T:4860   DEBUG: ------ Window Deinit () ------
15:22:33 T:3536   DEBUG: CGUIWindowManager::PreviousWindow: Activate new
15:22:33 T:3536   DEBUG: ------ Window Init (SettingsCategory.xml) ------
15:22:33 T:3536   DEBUG: CAnnouncementManager - Announcement: OnScreensaverDeactivated from xbmc
15:22:33 T:3536   DEBUG: GOT ANNOUNCEMENT, type: 4, from xbmc, message OnScreensaverDeactivated
15:22:33 T:3536   DEBUG: POParser: loaded 19 strings from file C:\Users\mel\AppData\Roaming\Kodi\addons\screensaver.atv4\resources\language\English\strings.po
15:22:33 T:4860   DEBUG: ------ Window Init (DialogKaiToast.xml) ------
15:22:33 T:3536 WARNING: CSkinInfo: failed to load skin settings
15:22:33 T:4860   DEBUG: ------ Window Init (C:\Users\mel\AppData\Roaming\Kodi\addons\screensaver.atv4\resources\skins\default\720p\screensaver-atv4.xml) ------
15:22:33 T:4860    INFO: Loading skin file: C:\Users\mel\AppData\Roaming\Kodi\addons\screensaver.atv4\resources\skins\default\720p\screensaver-atv4.xml, load type: LOAD_ON_GUI_INIT
15:22:33 T:4860   DEBUG: CGUIMediaWindow::GetDirectory ()
15:22:33 T:4860   DEBUG:   ParentPath = []
15:22:33 T:3536   DEBUG: CAnnouncementManager - Announcement: OnAdd from xbmc
15:22:33 T:3536   DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnAdd
15:22:33 T:3536   DEBUG: CVideoDatabase::GetMovieId (E:\ATV4\b5-3.mov), query = select idMovie from movie where idFile=11815
15:22:33 T:3536   DEBUG: CVideoDatabase::GetEpisodeId (E:\ATV4\b5-3.mov), query = select idEpisode from episode where idFile=11815
15:22:33 T:3536   DEBUG: CVideoDatabase::GetMusicVideoId (E:\ATV4\b5-3.mov), query = select idMVideo from musicvideo where idFile=11815
15:22:33 T:3536   DEBUG: PLAYLIST::CPlayList::Shuffle shuffling at pos:0
15:22:33 T:3536   DEBUG: ATV4 Screensaver player has been created
15:22:33 T:4860   DEBUG: Loading settings for E:\ATV4\b5-3.mov
15:22:33 T:4860   DEBUG: CPlayerCoreFactory::GetPlayers(E:\ATV4\b5-3.mov)
15:22:33 T:4860   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: system rules
15:22:33 T:4860   DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules
15:22:33 T:4860   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: mms/udp
15:22:33 T:4860   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout
15:22:33 T:4860   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtmp
15:22:33 T:4860   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtsp
15:22:33 T:4860   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: streams
15:22:33 T:4860   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvd
15:22:33 T:4860   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdimage
15:22:33 T:4860   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf
15:22:33 T:4860   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: nsv
15:22:33 T:4860   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: radio
15:22:33 T:4860   DEBUG: CPlayerCoreFactory::GetPlayers: matched 0 rules with players
15:22:33 T:4860   DEBUG: CPlayerCoreFactory::GetPlayers: adding videodefaultplayer (1)
15:22:33 T:4860   DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=0
15:22:33 T:4860   DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1
15:22:33 T:4860   DEBUG: CPlayerCoreFactory::GetPlayers: adding player: DVDPlayer (1)
15:22:33 T:4860   DEBUG: CPlayerCoreFactory::GetPlayers: added 1 players
15:22:33 T:4860   DEBUG: Radio UECP (RDS) Processor - new CDVDRadioRDSData::CDVDRadioRDSData
15:22:33 T:4860  NOTICE: DVDPlayer: Opening: E:\ATV4\b5-3.mov
15:22:33 T:4860 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
15:22:33 T:4860   DEBUG: CRenderManager::UpdateDisplayLatency - Latency set to 0 msec
15:22:33 T:2384   DEBUG: Thread DVDPlayer start, auto delete: false
15:22:33 T:2384  NOTICE: Creating InputStream
15:22:33 T:2384   DEBUG: CUtil::ScanForExternalSubtitles: Searching for subtitles...
15:22:33 T:2384   DEBUG: CUtil::ScanForExternalSubtitles: END (total time: 0 ms)
15:22:33 T:2384  NOTICE: Creating Demuxer
15:22:33 T:2384   DEBUG: CDVDDemuxFFmpeg::Open - probing detected format [mov,mp4,m4a,3gp,3g2,mj2]
15:22:33 T:2384   DEBUG: CDVDDemuxFFmpeg::Open - avformat_find_stream_info starting
15:22:33 T:2384   DEBUG: CDVDDemuxFFmpeg::Open - av_find_stream_info finished
15:22:33 T:2384    INFO: ffmpeg[950]: Input #0, mov,mp4,m4a,3gp,3g2,mj2, E:\ATV4\b5-3.mo':
15:22:33 T:2384    INFO: ffmpeg[950]:   Metadata:
15:22:33 T:2384    INFO: ffmpeg[950]:     major_brand     : qt
15:22:33 T:2384    INFO: ffmpeg[950]:     minor_version   : 0
15:22:33 T:2384    INFO: ffmpeg[950]:     compatible_brands: qt
15:22:33 T:2384    INFO: ffmpeg[950]:     creation_time   : 2015-09-22 22:17:10
15:22:33 T:2384    INFO: ffmpeg[950]:   Duration: 00:06:23.70, start: 0.000000, bitrate: 5620 kb/s
15:22:33 T:2384    INFO: ffmpeg[950]:     Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p(tv, bt709), 1920x1080 [SAR 1:1 DAR 16:9], 5617 kb/s, 30 fps, 30 tbr, 30030 tbn, 60060 tbc (default)
15:22:33 T:2384    INFO: ffmpeg[950]:       handler_name    : Core Media Data Handler
15:22:33 T:2384    INFO: ffmpeg[950]:       encoder         : H.264
15:22:33 T:2384   DEBUG: CDVDDemuxFFmpeg::AddStream(0, ...) -> 0
15:22:33 T:2384  NOTICE: Opening stream: 0 source: 256
15:22:33 T:2384  NOTICE: Creating video codec with codec id: 28
15:22:33 T:2384   DEBUG: CDVDFactoryCodec: compiled in hardware support: AMCodec:no MediaCodec:no DXVA:yes iMXVPU:no MMAL:no
15:22:33 T:2384   DEBUG: FactoryCodec - Video:  - Opening
15:22:33 T:2384  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
15:22:33 T:2384   DEBUG: CDVDVideoCodecFFmpeg - open frame threaded with 8 threads
15:22:33 T:2384   DEBUG: FactoryCodec - Video: ff-h264 - Opened
15:22:33 T:2384  NOTICE: Creating video thread
15:22:33 T:2384   ERROR: CSelectionStreams::Get - failed to get stream
15:22:33 T:2384   DEBUG: CEdl::ReadEditDecisionLists - Checking for edit decision lists (EDL) on local drive or remote share for: E:\ATV4\b5-3.mov
15:22:33 T:1808   DEBUG: Thread DVDPlayerVideo start, auto delete: false
15:22:33 T:1808  NOTICE: running thread: video_thread
15:22:33 T:2384   DEBUG: CApplication::OnPlayBackStarted: play state was 1, starting 1
15:22:33 T:2384   DEBUG: CDVDPlayer::SetCaching - caching state 3
15:22:33 T:2384 WARNING: CDVDMessageQueue(audio)::Put MSGQ_NOT_INITIALIZED
15:22:33 T:4860   DEBUG: CApplication::PlayFile: OpenFile succeed, play state 2
15:22:33 T:4860   DEBUG: CApplication::OnPlayBackStarted: play state was 2, starting 0
15:22:33 T:1808   DEBUG: CDVDPlayerVideo - CDVDMsg::GENERAL_RESYNC(0.000000, 1)
15:22:33 T:1808    INFO: CDVDPlayerVideo - Stillframe left, switching to normal playback
15:22:33 T:1808   DEBUG: CDVDPlayerVideo::CalcDropRequirement - hurry: 0
15:22:33 T:2384   DEBUG: Previous line repeats 1 times.
15:22:33 T:2384   DEBUG: CDVDPlayer::CheckContinuity - wrapback :2, prev:66666.666667, curr:33333.333333, diff:-33333.333333
15:22:33 T:3536   DEBUG: ATV4 Screensaver player has started. Toggling repeatAll
15:22:33 T:4860   DEBUG: CGUIInfoManager::SetCurrentMovie(E:\ATV4\b5-3.mov)
15:22:33 T:200   DEBUG: ffmpeg[C8]: [h264] Increasing reorder buffer to 1
15:22:33 T:4860   DEBUG: CVideoDatabase::GetMovieId (E:\ATV4\b5-3.mov), query = select idMovie from movie where idFile=11815
15:22:33 T:4860   DEBUG: CVideoDatabase::GetEpisodeId (E:\ATV4\b5-3.mov), query = select idEpisode from episode where idFile=11815
15:22:33 T:4860   DEBUG: CVideoDatabase::GetMusicVideoId (E:\ATV4\b5-3.mov), query = select idMVideo from musicvideo where idFile=11815
15:22:33 T:4860   DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
15:22:33 T:4860   DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
15:22:33 T:1808   DEBUG: Previous line repeats 1 times.
15:22:33 T:1808  NOTICE:  fps: 30.000000, pwidth: 1920, pheight: 1080, dwidth: 1920, dheight: 1080
15:22:33 T:1808   DEBUG: CDVDPlayerVideo::OutputPicture - change configuration. 1920x1080. framerate: 30.00. format: YV12
15:22:33 T:1808  NOTICE: Display resolution DESKTOP : 1804x1004@ 60.00 - Full Screen (16)
15:22:33 T:1808   DEBUG: CWinRenderer::SelectRenderMethod: Requested render method: 0
15:22:33 T:1808   DEBUG: CWinShader::LoadEffect - loading shader special://xbmc/system/shaders/testshader.fx
15:22:33 T:1808   DEBUG: CWinRenderer::SelectRenderMethod: Selected render method 1: Pixel Shaders
15:22:33 T:1808   DEBUG: CXBMCRenderManager::Configure - 3
15:22:33 T:1808   DEBUG: CDVDClock::Discontinuity - CDVDPlayerVideo::OutputPicture - was:7031.434864, should be:-33333.333333, error:-40364.768197
15:22:33 T:4860   DEBUG: created video buffer 0
15:22:33 T:4860   DEBUG: created video buffer 1
15:22:33 T:4860   DEBUG: created video buffer 2
15:22:33 T:2384   DEBUG: CDVDPlayer::HandleMessages - player started 2
15:22:33 T:2384   DEBUG: CDVDPlayer::SetCaching - caching state 0
15:22:33 T:1808   DEBUG: CDVDPlayerVideo::CalcDropRequirement - hurry: 1
15:22:33 T:4860   DEBUG: Previous line repeats 1 times.
15:22:33 T:4860   DEBUG: CWinShader::LoadEffect - loading shader special://xbmc/system/shaders/yuv2rgb_d3d.fx
15:22:33 T:1808   DEBUG: CDVDClock::Discontinuity - CDVDPlayerVideo::OutputPicture - was:-31527.694352, should be:20040.003964, error:51567.698316
15:22:35 T:4860   DEBUG: ------ Window Deinit (DialogKaiToast.xml) ------
15:22:39 T:1808 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
15:22:39 T:1808 WARNING: Previous line repeats 1 times.
15:22:39 T:1808   DEBUG: CDVDClock::Discontinuity - CDVDPlayerVideo::OutputPicture - was:5319496.977456, should be:4849868.237702, error:-469628.739754
15:22:39 T:1808   DEBUG: CDVDClock::Discontinuity - CDVDPlayerVideo::OutputPicture - was:5349907.675381, should be:5333372.437679, error:-16535.237702
15:22:39 T:1808   DEBUG: CDVDClock::Discontinuity - CDVDPlayerVideo::OutputPicture - was:5367336.976127, should be:4900630.538448, error:-466706.437679
15:22:40 T:1808   DEBUG: CDVDClock::Discontinuity - CDVDPlayerVideo::OutputPicture - was:5434648.671690, should be:4967326.661657, error:-467322.010033
15:22:40 T:1808   DEBUG: CDVDClock::Discontinuity - CDVDPlayerVideo::OutputPicture - was:5501348.435301, should be:5034000.942459, error:-467347.492842
15:22:41 T:1808   DEBUG: CDVDClock::Discontinuity - CDVDPlayerVideo::OutputPicture - was:5568019.075702, should be:5100662.897569, error:-467356.178133
15:22:41 T:1808   DEBUG: CDVDClock::Discontinuity - CDVDPlayerVideo::OutputPicture - was:5634682.648768, should be:5167328.684102, error:-467353.964666
15:22:42 T:1808   DEBUG: CDVDClock::Discontinuity - CDVDPlayerVideo::OutputPicture - was:5701348.030812, should be:5233997.302058, error:-467350.728754
15:22:42 T:1808   DEBUG: CDVDClock::Discontinuity - CDVDPlayerVideo::OutputPicture - was:5768015.839790, should be:5300665.728992, error:-467350.110798
15:22:43 T:4860   ERROR: CPythonInvoker(17, C:\Users\mel\AppData\Roaming\Kodi\addons\screensaver.atv4\atv.py): script didn't stop in 5 seconds - let's kill it
15:22:43 T:1808   DEBUG: CDVDClock::Discontinuity - CDVDPlayerVideo::OutputPicture - was:5834693.974461, should be:5367339.200817, error:-467354.773644
15:22:43 T:1808   DEBUG: CDVDPlayerVideo::CalcDropRequirement - hurry: 1
15:22:46 T:1808   DEBUG: Previous line repeats 1 times.
15:22:46 T:1808   DEBUG: CPullupCorrection: detected pattern of length 1: 33333.33, frameduration: 33333.333333
15:22:50 T:4860   DEBUG: Keyboard: scancode: 0x50, sym: 0x0112, unicode: 0x0000, modifier: 0x0
15:22:50 T:4860   DEBUG: CInputManager::OnKey: down (0xf081) pressed, action is Down
15:22:50 T:3536   DEBUG: CAnnouncementManager - Announcement: OnClear from xbmc
15:22:50 T:3536   DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnClear
15:22:50 T:4860  NOTICE: CDVDPlayer::CloseFile()
15:22:50 T:4860  NOTICE: DVDPlayer: waiting for threads to exit
15:22:50 T:2384  NOTICE: CDVDPlayer::OnExit()
15:22:50 T:2384  NOTICE: Closing stream player 2
15:22:50 T:2384  NOTICE: waiting for video thread to exit
15:22:50 T:1808  NOTICE: thread end: video_thread
15:22:50 T:1808   DEBUG: Thread DVDPlayerVideo 1808 terminating
15:22:50 T:2384  NOTICE: deleting video codec
15:22:50 T:2384   DEBUG: CApplication::OnPlayBackStopped: play state was 2, starting 0
15:22:50 T:2384   DEBUG: CAnnouncementManager - Announcement: OnStop from xbmc
15:22:50 T:2384   DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnStop
15:22:50 T:2384   DEBUG: Thread DVDPlayer 2384 terminating
15:22:50 T:4860  NOTICE: DVDPlayer: finished waiting
15:22:50 T:4860   DEBUG: ------ Window Deinit (C:\Users\mel\AppData\Roaming\Kodi\addons\screensaver.atv4\resources\skins\default\720p\screensaver-atv4.xml) ------
15:22:50 T:3536   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                            Error Type: <type 'exceptions.SystemExit'>
                                            Error Contents: <NULL>
                                              File "C:\Users\mel\AppData\Roaming\Kodi\addons\screensaver.atv4\resources\lib\atvplayer.py", line 36, in onPlayBackStopped
                                            SystemExit
15:22:50 T:3536    INFO: CPythonInvoker(17, C:\Users\mel\AppData\Roaming\Kodi\addons\screensaver.atv4\atv.py): script successfully run
(2016-03-22, 22:29)thezoggy Wrote: [ -> ]always plays the same first video.. go to settings and disable ny now it plays the next one.. but always that one (not sure if its supposed to randomize... most screensavers would.. why im noting it).
same here, It always starts on the same video, causing me to never see most of the videos, always just the same ones, in the same order...
I just found out about this screensaver and I absolutely love it. However, downloading the videos doesn't seem to work.
I can set a downloader folder and download them and a progress bar will be displayed (with about 10% but it never continues) and then it's gone and the download folder remains empty.
Is there a possibility to download the files from a website/host and let the screensaver run them locally (when downloaded). Also, I'm not sure if that's already what it does, in case it would've downloaded the files.
In any case, thanks for the great screensaver and the help!
Edit: I just read that the add-on will check for local videos first. I have downloaded them, but do the videos have to located in separate folders (right now I have all of them collected into the official download folder)?
Also, the stutter at the beginning of the videos (RP3) still seems to be there and the screen turns black once all videos have been played. Is there any way to repeat them indefinitely?
