2017-02-27, 18:31
2017-03-22, 01:05
Does anybody know how to marry Kodi with Alexa I've tried this one video tutorial that I found from Paul and I even it didn't ,work but he made it work... I have the Alexa skills I just can't get it to work
Sent from my SM-G935T
2017-05-08, 02:13
I am trying to set this up. I have the skill configured but when I say to get my key it say 'I am having trouble please try again in a little while'. Is it all working at the backend? Any ideas?
2017-06-04, 17:27
Hi guys I've tried Pauls Video https://www.youtube.com/watch?v=_KSlz_lT1k4&t=1315s
only to get a Error
otocore.errorfactory.InvalidParameterValueException: An error occurred (InvalidParameterValueException) when calling the CreateFunction operation: The role defined for the function cannot be assumed by Lambda.
I am now stuck
When will Skill be added to Amazon without having to jump threw Hoops
I'm frustrated to the point that right now it not worth it
Especaly since My IP Changes
only to get a Error
I am now stuck
2017-07-13, 03:27
Is there any ETA on this being published by Amazon? Looks like a ton of work to set up otherwise.
2017-08-18, 22:14
Why am I getting this error?
Error: Please make sure that "Alexa Skills Kit" is selected for the event source type of arn:aws:lambda:us-east-1:414515788753:functionlayTV
2017-08-22, 14:09
This looks awesome !!!!!!!!!!!!!!!!!!!!!!!!
awesome work
am going to try it out when i get home tonight .
one question dose it support multiple kodi instances?
awesome work
2017-08-22, 17:07
Pain the ass to install they need simpler install instead of all these hoops to jump threw
2017-09-11, 20:56
I am getting an error at the part where i have to run
zappa init
How do i get bypassed this?
zappa init
Administrator@HTPC MINGW32 /c/Kodi Alexa/kodi-alexa-master/kodi-alexa/venv/bin (master)
$ zappa init
Oh no! An error occurred! :(
File "c:\python27\lib\site-packages\zappa\cli.py", line 2495, in handle
sys.exit(cli.handle())
File "c:\python27\lib\site-packages\zappa\cli.py", line 448, in handle
self.init()
File "c:\python27\lib\site-packages\zappa\cli.py", line 1399, in init
self.check_venv()
File "c:\python27\lib\site-packages\zappa\cli.py", line 2459, in check_venv
"Learn more about virtual environments here: " + click.style("http://docs.python-guide.org/en/latest/dev/virtualenvs/", bold=False, fg="cyan"))
ClickException: Zappa requires an active virtual environment!
Learn more about virtual environments here: http://docs.python-guide.org/en/latest/dev/virtualenvs/
Need help? Found a bug? Let us know! :D
File bug reports on GitHub here: https://github.com/Miserlou/Zappa
And join our Slack channel here: https://slack.zappa.io
Love!,
~ Team Zappa!
2017-09-11, 21:03
(2017-02-27, 18:31)lopez1de Wrote: [ -> ]Any news on this Skill?
OP hasn't been on the forum in over a year.
2017-09-12, 06:37
It's pain the ass to do it this way I'll wait till skill is added to Alexa natively
2017-09-12, 07:16
Everything worthwhile is hard to pull off at first. Stick with it and the end result will be.
*Sorry, I though you were on a different thread. This one works: https://forum.kodi.tv/showthread.php?tid...alexa+echo
2017-09-24, 03:21
Hi fellas, I set this up months ago and all has been awesome. I'm using AWS.
My power however went out tonight, and everything is now screwed up on my network, every IP has changed. I cannot for the life of me remember how to fix things so it'll use the new ip address. I'm using linux, can someone please refresh my memory as to what commands I need to run to push the new ip address to AWS?
2017-09-24, 03:28
(2017-09-24, 03:21)kohr Wrote: [ -> ]Hi fellas, I set this up months ago and all has been awesome. I'm using AWS.
Forget this method. This one works flawlessly...https://forum.kodi.tv/showthread.php?tid=254502&highlight=alexa+echo
Do yourself a favor and set up static ip's in your router this time.
2017-09-24, 08:16
(2017-09-24, 03:28)DonBrutto Wrote: [ -> ](2017-09-24, 03:21)kohr Wrote: [ -> ]Hi fellas, I set this up months ago and all has been awesome. I'm using AWS.
Assuming you do yourself the favour, make sure you back up your router settings, then you should be power fail proof :-)
