(2016-08-16, 13:40)droidelec Wrote: [ -> ]109 EUR including Tuner.
Great news! Thanks
Any info (release date, price) on the play2s?
Sent from my SM-G935F
There will be an option to buy the Play2 together as a kit with the keyboard remote or buy the keyboard remote separetely also this Thursday?
Is the Play2 having 2gb RAM and 8gb eMM storage?
droidelec , great info . Can't wait for new play 2 and later play 2s.
JoBcn , I think new remote with keyboard will be available later to buy . Hope very soon :-)
Regards
Is the DVB-S2 tuner that comes with the Play2 the same tuner used in the Play?
(2016-08-16, 17:28)adelias Wrote: [ -> ]Is the DVB-S2 tuner that comes with the Play2 the same tuner used in the Play?
I believe droidelec mentioned somewhere before.. That play 2 only has single tuner
(2016-08-16, 18:38)Tó Madeira Wrote: [ -> ] (2016-08-16, 17:28)adelias Wrote: [ -> ]Is the DVB-S2 tuner that comes with the Play2 the same tuner used in the Play?
Somewhere else was mentioned, that single tuner means no combinations of DVB-S2 and DVB-T2 and so on, am I wrong with this?
Anyway, can the tuner from Play used in Play 2?
No, it is different, Single Tuner DVB-S2.
(2016-08-16, 18:48)lama0900 Wrote: [ -> ] (2016-08-16, 18:38)Tó Madeira Wrote: [ -> ] (2016-08-16, 17:28)adelias Wrote: [ -> ]Is the DVB-S2 tuner that comes with the Play2 the same tuner used in the Play?
You will have options to buy:
DVB-S2 Single Tuner
Hybrid DVB-C/T/T2 Tuner
ATSC Tuner
(2016-08-16, 19:31)droidelec Wrote: [ -> ] (2016-08-16, 18:48)lama0900 Wrote: [ -> ] (2016-08-16, 18:38)Tó Madeira Wrote: [ -> ]I believe droidelec mentioned somewhere before.. That play 2 only has single tuner
DVB-S2 Single Tuner
ATSC Tuner
Got that. Now everything is clear :-)
Honest question: why do you need two tuners?
watch on one, record on the other.
Oh, didn't think about that...
droidelec can i take the dual dvb-s2 tuner out my Play 1 and put in the play 2?
