adbLink 2.07 Released
Changelog:
Windows: If installing on top of an existing installation, preexisting
database and log files will be erased.
Select multiple apk files for installation to Android device
Select multiple files for push to Android device
Start/Stop Android apps on connected device
Logs menu item added: view adbLink/Kodi logs
Download SPMC file menu function added
Double-print of port in logfile corrected
Parallel adb processes functionality restored
ADB Port is not reset when switching OS in preferences: fixed
Root menu removed
http://www.jocala.com
Did I loose all my devices I had added with the previous version (macOS)?
(2016-12-11, 00:24)D-an-W Wrote: [ -> ]Did I loose all my devices I had added with the previous version (macOS)?
Did you delete or overwrite adbLink.app? If so, yes.
If you still have a backup copy of your previous install AND that previous install is 2.06 you can copy the adblink.db file from adbLink 2.06 to adbLink 2.07
1. Right-click on adbLink 2.06 then select "Show Package Contents"
2. Double-click MacOS folder and drill down to the adbfiles folder
3. Copy the adblink.db file
Next:
1. Right-click on adbLink 2.07 then select "Show Package Contents"
3. Paste the adblink.db file copy just copied above.
This only works with 2.06 and 2.07
Good morning, i bought the Mi Box for a friend this weekend. after installing Kodi via the google play store i wanted to restore from backup using adbLink. i put the box into developer mode and all that. but i couldn't get it to connect to the box. any ideas how to make this connect, i didn't have any issues using adbLink on any Firestick, FireTV or Nvidia Shield. i even tried hooking a usb from the Mi Box to my pc like you need to do for the Nvidia Shield but had no luck. please advise.
(2016-12-12, 15:17)LilSnoop40 Wrote: [ -> ]Good morning, i bought the Mi Box for a friend this weekend. after installing Kodi via the google play store i wanted to restore from backup using adbLink. i put the box into developer mode and all that. but i couldn't get it to connect to the box. any ideas how to make this connect, i didn't have any issues using adbLink on any Firestick, FireTV or Nvidia Shield. i even tried hooking a usb from the Mi Box to my pc like you need to do for the Nvidia Shield but had no luck. please advise.
I responded to your email.
I am trying to find ADBLINK that works on OSX 10.6.8.
Can anyone help please?
(2016-12-25, 19:29)dante1 Wrote: [ -> ]I am trying to find ADBLINK that works on OSX 10.6.8.
Sorry, adbLink works with OSX 10.7 and above only.
What about an old version of ADBFIRE?
driver help for windows 10 64bit. just keeps me at the generic software. I need to get a driver for my firestick so I can install from usb.
