(2017-09-21, 19:38)Wipe Wrote: [ -> ]Hey guys, i'm using FireTV 2 and Kodi 17.4, InputSteam is activated but i still get "No valid stream URL is found"
Any ideas?
I still have the same issue, no one with FireTv2 have the same problem?
For those of you who cannot get this working and is running a debian based system.
For some reason inputstream is not available for debian/debian multimedia. So what I had to do is this.
- Download this: https://www.ubuntuupdates.org/package/xb...m-adaptive
- Install as root with dpkg -i
- Restart Kodi
- Enable Videoplayer InputStream under My Addons
Viaplay will now work.
I get the "No valid stream URL is found" as well and my log says:
@Karellen- Log removed
I have removed your log as we do not allow logs to be posted in the forum.
Please ensure you have
enabled debugging in Settings>System Settings>Logging,
restarted Kodi then
replicated the problem.
Repost your log:
- Locate a Pastebin type site. Two examples are https://pastebin.com/ or https://paste.ubuntu.com/
- Paste the contents of the kodi.log file
- Press Paste or Generate or Create New Paste
- When the screen refreshes with your paste, copy the entire address in the address bar and paste it into a new message in your thread
Ok another try. I have a RPi1 with LibreElec 8.2.1 Kodi 17.6 and I get the "No valid stream URL is found" when trying to play anything from the Viaplay addon. Here is my debug log.
https://pastebin.com/VK6SS72i
Any chance this add-on could possibly support Estonia/Baltics?
(2017-11-27, 21:30)eldakkar Wrote: [ -> ]Ok another try. I have a RPi1 with LibreElec 8.2.1 Kodi 17.6 and I get the "No valid stream URL is found" when trying to play anything from the Viaplay addon. Here is my debug log.
Same here - any suggestions?
Hello,
I have this stream on the left bar of this page that I would like to add to my kodi.
I would appreciate the help
https://www.mako.co.il/
Hi
Can I make it play next episode when I watch a serie when the first one is finnish?
how does the playlist work if I want to add some epesiode to watch after each other?
(2017-12-05, 21:07)cazz Wrote: [ -> ]Hi
Hi...
Can you please tell me how to make this work...
Tried several times and it only says ...
Thanks in advance
I did get that error to when I install it from kodi Add-on place.
So I unstall it from kodi and get the file from github (see page 1)
After that I did install Widevine (see page 10)
After that everything works fine for me.
(2017-12-09, 14:58)cazz Wrote: [ -> ]I did get that error to when I install it from kodi Add-on place.
Thanks for the quick answer...will do like you did...
Thanks again
Always nice to help people.
Just write a replay if it works or not.
I have total account and only sports works. Movies and series wont play. Widewine and adaptive stream is installed. Here is my log file:
https://pastebin.com/f182Gd23
have not try sport but it does look strange.
Is somehow the can't open the URL
My inputstream adaptive settings is normal beside I have set "Max resolution decoding" to 720p and I use version 2.0.19.0
