(2022-06-06, 16:28)Daikokutenn Wrote: [ -> ]I can no longer access Japanese replay tv I get Error "AttributeError: 'NoneType' object has no attribute Every time I try to play a show, is there a fix? It happens with or without vpn connected. Originally I could watch only with vpn the. It worked without. Using on fire tv cube (newest version)
As you have indicated the issue persists with or without it but as you are new I would just like to draw your attention to our
VPN policy.
Likely there has been a change at the source which is causing the error but feel free to submit a
Debug Log for the developer and other users to view and attempted to assist.
Is anyone encountering a problem watching either France 24 or DW? Kodi returns an error seconds after I start them. I click “No” to forward the error to Kodi and the system hangs with a spinning gear object. It requires a restart of Kodi or reboot to clear the problem.
Environment: Raspberry Pi 4, Raspberry Pi OS 5.15.32-v8+, Kodi 19.4
Catch-up TV: v0.2.37+matrix.1
France24(EN)
Stream: LiveTV, International, France24(EN)
“kodi.log” Error: [Catch-up-TV-&-More.support] Exceeded 30 redirects.
Complete Messages:
https://paste.kodi.tv/avirapojem.kodi
DW(EN)
Stream: LiveTV, International, DW(EN)
“kodi.log” Error: [Catch-up-TV-&-More.support] Unable to resolve url
Complete Messages:
https://paste.kodi.tv/vifuhozuqa.kodi
I don't see any reference to the above errors in this forum. Any help would be appreciated.
Thanks,
John
I’m also having issues with STV catchup if anyone else is? Just errors every time I try and play anything
Yes catch up tv & more is not working. It was fine a few days ago. Nothing works but I use it mainly for Coronation Street !
(2022-06-09, 22:07)jmason Wrote: [ -> ]France24(EN)
Complete Messages: avirapojem.kodi (paste)
DW(EN)
Complete Messages: vifuhozuqa.kodi (paste)
Update on the above post from last month:
- The
DW(EN) problem resolved itself about two weeks ago and has been working since.
France24(EN) continues to not work, however the symptom has changed:
- The "kodi.log" Error: 2022-07-12 21:15:43.458 T:1673 DEBUG <general>: ffmpeg[0x5594da3710X]: [http] HTTP error 400 Bad Request
- Complete Log:
https://paste.kodi.tv/decegihive.kodi
Tried to reinstall but url not found. What’s happening with this ?
Devs have been contacted I believe. Should hopefully be fixed soon
Any updates on when or if this will be fixed?
(2022-07-13, 00:42)Globaltvfan Wrote: [ -> ]Yes catch up tv & more is not working. It was fine a few days ago. Nothing works but I use it mainly for Coronation Street !
I am not sure if you are aware but somebody has come up with a test version of catch-up tv and more that appears to work. You can download it here. 👇
https://github.com/joaopa00/plugin.video...ds/dev.zip
Can you tell me a little bit more about it please Chris?
Do I need to uninstall the old one? Will I lose all my progress etc... on the shows I watch? How do I even install it on an Nvidia Shield?
Many thanks.
Many thanks Chris - installed the update and all working well again
Much appreciated
Hi - I'm using Nvidia Shield
My method for installing the update is to load the zip file update in a folder then create the source location for this folder - then install from zip file.
Thanks but the test version doesn't work with me by installing from zip file or updating existing version ?? Wot to do ?!
Thanks Chris just downloaded and installed from zip file and STV catchup is working again!
(2022-08-02, 17:27)trpolo Wrote: [ -> ]Thanks Chris just downloaded and installed from zip file and STV catchup is working again!
What kodi version do you use as it's not working with me, error msg showing
