I have an issue with the extension Catch UP TV and the link with IPTV Manager to show my favorite channels in the Live TV of Kodi.
My OS is Google TV platform using Kodi 19.3 and the last version of catch Up TV.
When Kodi is starting and I use Live TV and its EPG, there is no update of the EPG and my favorites TV channels are disappeared.
The only way to recover the situation is to proceed manually an update inside the IPTV Manager settings.
I know that there is a bug issue listed on the catch Up TV github :
Issue #507
But there is no real solution proposed.
Any idea to solve this issue ?
(2022-10-17, 11:03)Eye in the sky Wrote: [ -> ]Is anyone else getting "RuntimeError No items found" with All4 (Channel 4) documentaries and film?
Fixed with latest beta.
I'm Having a problem getting anything to play with UKTV Play & Channel 4, it seems the player isn't opening , I can see a blue timer that shows it's running, & a spinning circle with working ,but no picture or sound any help with this Thanks. Using ver 0.2.39-beta09, Kodi 19.4, Nvidia Shield
Works fine for me on Nvidia Shield 2015 (Android 9) and 2019 (Android 11).
Bonjour,
J'ai installé Kodi 19.4 sur une Mibox 4S xiaomi. Je n'arrive pas à installer Catch-up tv.
Lorsque j'essaie d'installer le dépôt "catchuptvandmore.kodi.beta-0.0.6.zip" j'ai le message suivant: "La dépendance de script.module.codequick version 0.9.13 n'a pu être satisfaite".
Ensuite lorsque je veux installer l'application à partir du dépôt il me déclare: "dépôt non trouvé".
Quelqu'un a-t-il une solution ?
Merci par avance.
arturetfils Welcome - this is an English language forum only. Please write forum posts in English. If you need assistance then please use a service such as Google Translate.
Hello, I installed Kodi 19.4 on a xiaomi Mibox 4S. I can't install Catch-up tv.
When I try to install the repository "catchuptvandmore.kodi.beta-0.0.6.zip" I get the following message: "The dependency of script.module.codequick version 0.9.13 could not be satisfied".
Then when I want to install the application from the repository it tells me: "repository not found".
Does anyone have a solution?
Thanks in advance.
UKTV have announced that from November, high definition (HD) content will become available, initially for new released programmes, but re-encoded back catalogue content will follow shortly after, where a HD master (original copy) is available. Great news for people who enjoy watching catch-up content from UKTV
More info available here:
https://www.digitaltv.org.uk/2022/09/hd-...uktv-play/
Hello everyone.
I just installed Kodi 19.4 & latest Catch up tv and more.
Works fine with, except that on several TV canals I have around 3-4h of delay. If it's 5 PM, it's displayed the 1PM program.
Am I the only one who have this bug?
Thank you for your help !
Is it possible to add Aljazeera channel to this?
BTW awesome addon thank you for all your hard work
Hello,
I have 2 issues to resolve doe French channels as follows:
1) I am having issues with M6 TV - it does not let me start this channel anymore. I get a message error " list index out of range".
Does anyone know how to fix this? It appeared suddenly and I am not sure what can cause this.
2) TF1 TV is not real time anymore. It's a few hours behind compared to France.
If anyone experience and resolved this issue, please let me know.
Thanks,
Quote:1) I am having issues with M6 TV - it does not let me start this channel anymore. I get a message error " list index out of range".
same to me (M6 or M6 group (gulli))
I change password, but same issue
Issue has already been fixed with latest beta.
