The tv integration don't work anymore.
salut juste pour savoir comment faire pour télécharger les traitres sur m6 ?
tel2lou - the forum language is English only please.
Usage of Google Translate or similar services is acceptable if required.
hello just to know how to download the traitors on m6?
how to download a program so i can see if i am offline
Hello:
Thanks for the great add-on! Been successfully using it for ages - but just now hitting a problem.
Running Kodi 20.2 on macOS 11.7.9, with Catch-Up TV & More 0.2.38+matrix.1
Opening many of the folders inside the add-on work fine - but on attempting to open Catch-Up TV > United Kingdom > STV, the displayed list of folders does not change, and I get
'Nonetype' object is not subscriptable as an error.
Getting to one of the programmes inside here via a previously-set up Favourite works fine - looks like it's the list of Categories which is failing.
I've added a log excerpt here:
https://paste.kodi.tv/vugusuzime.kodi
Please let me know if you need any more information to help fix!
Same issue for me. STV live TV plays fine but on-demand returns the same error message.
I’m getting the same “Nonetype' object is not subscriptable” error.
Any hope of a fix?
Hello,
I just install libreelec (last table version) on pc (optiplex 5040) follow by install of catch up TV (beta branch). I can see TV channels with catch up TV (thanks a lot by the way) but a can't see them in the default TV panel of Kodi. It seem IPTV doesn't work and I have followed the tuto
https://catch-up-tv-and-more.github.io/f...tallation/).
Do you know any workaround for reactivate this cool features?
Version 0.2.39 Beta 40 was running fine but a few days ago the UK Blaze catchup channel started giving a message "Runtime error no items found" and no content is listed. However, the shortcuts still worked fine. Is there something that I need to do to get this working again?
Hello,
I have just configured Kodi on OSMC with Catch-Up TV and More, IPTV Manager and PVR IPTV Simple Client.
I also put the m3u files and the link
http://bit.lyguideall.
When I go to TF1, it displays geo-blocked video
Do you know what the problem is?
I've just tried to install the repo as per the official website. In the addons I managed to install the zip file, but when I tried to go to the repo to install the add on I received an error that told me it can't connect to the repo.
Is there anyway to solve this issue?
