(2020-12-22, 23:20)matthuisman Wrote: [ -> ]please update. latest version is 0.5.3
Thanks big Matthuisman, 4k works top, great great addon, top work, congrats
You Need only make 2 more addons =P ESPN+ From USA and Fanatiz From USA too =D
I'm getting an unexpected error with the addon now.
Disney+ (0.5.3)
Keyerror: 'preferred_maturity_rating'
File "Api.py", line 48 in_set_languages
Plugin line 21
Signals line 26
Router line 114
Signals line 31
mattyspurs76
just pushed 0.5.4 that should fix that.
Happy Holidays!
there seems to be trouble to access all available audio languages (19 different listed when using webversion of D+) on this movie, in my case swedish, the add-on lists 31 different (2 versions / language).
/merry x-mas from kayfour
(2020-12-25, 15:33)kayfour Wrote: [ -> ]there seems to be trouble to access all available audio languages (19 different listed when using webversion of D+) on this movie, in my case swedish, the add-on lists 31 different (2 versions / language).
on movie Soul...
(2020-12-23, 01:24)Postiga Wrote: [ -> ] (2020-12-22, 23:20)matthuisman Wrote: [ -> ]please update. latest version is 0.5.3
Thanks big Matthuisman, 4k works top, great great addon, top work, congrats You Need only make 2 more addons =P ESPN+ From USA and Fanatiz From USA too =D
+1 for espn plus the app is sluggish
kayfour
Kodi 18 has a limit of streams it can process (kodi 19 doesnt)
If using 18, then you would need to use the
add-on settings > playback > audio allow list > sv
also maybe set subtitle allow list to same.
That will reduce the audio to only English and Swedish and should have all the streams for each
(2020-12-25, 22:11)matthuisman Wrote: [ -> ]@kayfour
If using 18, then you would need to use the add-on settings > playback > audio allow list > sv
matthuisman
Thx man, great job!
/K
Great addon, works like a charm. Tried it on my Fire stick 4K, 1080p TV, Atmos capable soundbar. Great picture quality and Atmos sound.
Hi, I am using Kodi v18.6 on a VTi 14.06 system. I installed Disney+, the same way it workes on other systems. But with VTi I can not start Disney+ and I get a "Disney+ Fehler Für mehr Informationen, Logdatei einsehen." Error. My Log-File:
https://paste.kodi.tv/ofihuqolam
Can the problem be the missing "pkgutil"? I did not make it to install "pkgutil" on the VTi System. Or is there another solution how I can run Disney+ with Kodi on VTi?
Kampfkugel
python install should have pkgutil available...
Anyway, I've just pushed 0.17.9 of the common module which should remove the need for pkgutil
By now it should have already updated itself
Not really, but I tried so much, that maybe there could be a problem.
Is there a new image, which I can flash on the Box, so that I get the described version?
