2021-10-15, 22:41
2021-10-17, 17:30
(2021-10-04, 10:31)bfgane Wrote: [ -> ]Is it possible to add code so that instead of just "Movie set", I can get the description from the "sets" table, field "strOverview"?
Delete line 325 from Includes_Variables.xml.
2021-10-18, 11:16
(2021-10-17, 17:30)nonJon Wrote: [ -> ]Thank you. That worked like a charm!(2021-10-04, 10:31)bfgane Wrote: [ -> ]Is it possible to add code so that instead of just "Movie set", I can get the description from the "sets" table, field "strOverview"?
But just a thought ... wouldn't that be a good feature to have for all views?
2021-10-18, 15:50
bfgane Wrote:But just a thought ... wouldn't that be a good feature to have for all views?
It does work for all views that display plot info. Some version of this change will be included in a future update.
2021-10-19, 09:42
(2021-10-18, 15:50)nonJon Wrote: [ -> ]bfgane Wrote:But just a thought ... wouldn't that be a good feature to have for all views?
2021-10-19, 21:08
Thank you for keeping this amazing skin current for us! I wanted to ask if there is anyway possible to have the ability to display the music file media flags/tags onscreen, especially when music is playing. I have searched thru all of the settings, and couldn't find this ability.
For those of us with large music collections, this would be much appreciated.
2021-10-20, 11:38
@christoofar can you post some screen shots, or otherwise point me to another skin that has this feature, so I can get a better idea of what you're asking for? thx
2021-10-20, 16:44
(2021-10-20, 11:38)nonJon Wrote: [ -> ]@christoofar can you post some screen shots, or otherwise point me to another skin that has this feature, so I can get a better idea of what you're asking for? thx
hmm...no easy way to add a pic, check out Amber skin, playing a music track showing both cover art and the audio flags for bitrate, channels,filetype, etc. Many thanks for looking into this!
2021-10-25, 02:25
Nonjon,
How can I set a single video add-on (as favourite) on the home menu?
Is there marked as view on the file I have already seen?
2021-10-25, 10:31
chitridang Wrote:How can I set a single video add-on (as favourite) on the home menu?Settings>Skin>Homepage>Home menus customizer
Another option is to pin the add-on to a media shelf above the home menu using: Settings>Skin>Homepage>Home media shelf customizer>Custom media shortcuts
chitridang Wrote:Is there marked as view on the file I have already seen?Settings>Skin>Icons>Show watched content icons
2021-10-25, 10:41
(2021-10-25, 10:31)nonJon Wrote: [ -> ]Thanks a lot Nonjonchitridang Wrote:How can I set a single video add-on (as favourite) on the home menu?Settings>Skin>Homepage>Home menus customizer
2021-10-26, 03:04
Nonjon,
When a video is playing, I can't move forward or backward with a mouse...
2021-10-26, 15:24
(2021-10-26, 03:04)chitridang Wrote: [ -> ]When a video is playing, I can't move forward or backward with a mouse...
Settings>System>Input>Enable mouse and touch screen support
2021-10-27, 01:18
(2021-10-26, 15:24)nonJon Wrote: [ -> ]I have already selected this option. It doesn't work. I don't know why... With other Kodi skin, I can drag with a mouse(2021-10-26, 03:04)chitridang Wrote: [ -> ]When a video is playing, I can't move forward or backward with a mouse...
2021-10-27, 02:18
@chitridang
Quartz has no built-in mouse support. What you get is what core kodi provides. So, yeah, dragging the seek bar won't work. That said, you can use the mouse scroll wheel to FWD/RWD thru a video. hth
