Hi. I have installed Kodi in an old 32 bit machine which is running MX 21 Linux. Since MX is Debian based, i hope i post in the correct thread.
Kodi fails to start. There is just a momentary flash in the screen and that's it. I have installed Kodi through MX Package Installer (Popular Applications), no other repo or installation method has been used, and I have only tried to reinstall using MX Package Installer again with no luck. I'm posting my system info and debug log which I created according to wiki info. I would greatly appreciate any help.
https://paste.kodi.tv/wofitufivo
https://paste.kodi.tv/sunoxakeki.kodi
(2022-05-13, 18:38)xtal4 Wrote: [ -> ]Hi. I have installed Kodi in an old 32 bit machine which is running MX 21 Linux. Since MX is Debian based, i hope i post in the correct thread.
And again it is i915, just like @
hungry person .
OK let me check in the morning what the situation with driver is. So far i915 was replaced by i965 but as numerous reports show, the replacement is invalid.
Any news on the situation?
Is it possible to install 17.6 on Debian 11?
i have just migrated to Debian 11 and installed Kodi 19.1 from the repo. Still trying to nail down the Python scrapper issue as I'm running Python 3 already and get a few movies that just error out on the scrapper. Otherwise working well.
Most annoying problem is the "Regianl Timezone" is greyed out and is an hour later then current time on Debian itself.
Looked around for a add-on for it but there's a lot of to dig through, suggestions?
(2022-07-04, 23:53)MrDeplorableUSA Wrote: [ -> ]Most annoying problem is the "Regianl Timezone" is greyed out and is an hour later then current time on Debian itself.
I'd advise you installing 19.4 from bullseye-backports because I fixed exactly that issue there.
It turns out the time issue was bios/hwclock issue and is corrected.
Trying to install Kodi in Debian 11. The error I get is: The following packages have unmet dependencies: kodi-data : Depends: fonts-glewlwyd but it is not installable Recommends: python-qt3 but it is not installable or python-gtk2 but it is not installable or python-pygame but it is not installable
I've checked Debian for the missing packages and only find them for Buster, not Bullseye?
(2022-10-04, 21:26)jimkoh Wrote: [ -> ]Trying to install Kodi in Debian 11. The error I get is: The following packages have unmet dependencies: kodi-data : Depends: fonts-glewlwyd but it is not installable Recommends: python-qt3 but it is not installable or python-gtk2 but it is not installable or python-pygame but it is not installable
Where are you installing from? I'm on Debian 11 and kodi-data doesn't depend on that file here, only mesa-utils, x11-utils, libjs-query and libjs-iscroll.
I'm trying to install it on my desktop. When I do sudo apt install kodi I get this:
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
E: Unable to correct problems, you have held broken packages.
Can you paste the output of:
apt-cache policy kodi
You mix deb-multimedia and debian. If you want to move to Kodi from Debian, which is supported in this thread, first remove the deb-multimedia repository from your sources.list file, do
shell:
apt-get update
and post the output of
shell:
apt-get install kodi
again.
I removed the /etc/apt/sources.list.d file which had mutimedia in it. This is my /etc/apt/sources.list contents:
deb
http://deb.debian.org/debian bullseye main
deb-src
deb
http://deb.debian.org/debian-security/ bullseye-security main
deb-src
deb
http://deb.debian.org/debian bullseye-updates main
deb-src
And this is what I get after updating and trying to install kodi
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
kodi : Depends: kodi-bin (< 2:19.1+dfsg2-2+deb11u1.1~) but 5:18.9-dmo0+deb10u1 is to be installed
Recommends: kodi-repository-kodi but it is not going to be installed or
kodi-repository
Recommends: kodi-visualization-spectrum but it is not going to be installed
