So, I think we're going to call the skin "Serenity". It sounds nice, it fits, and I really liked the series Firefly and the movie, so that helps too. Here's a video showing the custom plugins, custom fanart, and video views in action. I should wait until there's more completed, but I felt compelled to show off something other than me scrolling between icons in the home menu.
Serenity for XBMC
Features:
Minimalistic Approach - Instead of trying to have super-detailed textures, fancy glass overlays, and boner-inducing icons designed to make you drool, we opted to instead try and pack as much functionality into as little space as possible, allowing you to admire all of your hard-collected fanart. This "less-is-more" theory also means that the number of button presses required to do something are kept to a bare minimum.
Custom fanart - Configurable from the home menu(first time) and also from the "customize" menu.
Custom Plugins - Allows you to set up to 4 custom links each for the TV/Video/Music/Programs sections, accessible directly from the home menu.
Pick an Info View - Do you want posters and movie information? Maybe just the information in the corner? Or maybe you want it to take up the whole screen. Maybe you want something that shows you the minimal information. Maybe you want it to pop up automatically? You decide.
Mini Playlist - Accessible from anywhere in the skin, allows you to view/select 100 items from the playlist at any time. Can be configured to be always on or visible only when selected.
Music Fanart support - Displays fanart images based on the currently selected artist in music files/library/playlist areas.
Rotating video/audio OSD - Uses a variation of MacGuyver's carousel design to present the video/audio OSD in a pretty slick manner.
Conditional Weather Fanart support - If it's sunny, the pictures will show sunny. If it's rainy, the pictures will show that it's rainy. If it's dark, there won't be any pictures. Okay, the last part was a joke. It'll just show you pictures at night.
Radar...right on the home screen - This isn't implemented yet, but with the final version, you will have the option to have your current radar map display directly on the home screen when you select the weather button.
MPAA Logos - You know, the little box that shows up before a preview. Those things.
Studio Logos - Shows you pretty pictures that tell you what studio made your movie. There are currently 24 supported studios, with about an additional 15 to be added. I'm also willing to take requests.
HD flag support - Shows you whether the video is HD, SD, blu-ray, etc. This will be added as soon as development is finished.
Helps you make friends - Imagine all the people that will want to come over and watch you look at movie/tv show/album descriptions after you get this. They will be so amazed, they'll probably give you money. At least...that's how I see it in my mind.
And of course...there's still a lot more work to be done yet. A lot. But you get the idea.
