I'd like to see this:
-TV (default to library)
--Library
--Files (unlike mediastream, i think this should default to videos sources)
--Plugins (takes you to a list of all video plugins i.e. mediastream)
-Movies (default to library)
--Library
--Plugins (list of all video plugins i.e. mediastream)
--Apple Movie Trailers II (assuming user has set a valid path in skin settings)
-Music (default to library)
--Library
--Files (unlike mediastream, i think this should default to music sources)
--Party Mode
--Last.FM
--Plugins
(you could easily add programs or pictures here. With the launcher plugin and all the work being done on the 'games library' my vote goes to programs... however, I don't use either one but adding one or the other (probably not both, but maybe, you'd have to play around and see how well it fit) would look fitting in this spot.
-Accessories
--Favorites
--Weather (Enable & set path to TWC Supplemental Script in skin settings)
--Scripts
--Programs/Pictures (which ever you didn't put above)
--Addons Manager (Enable & set path in skin settings)
--File Manager
--System Info
-An icon representing DVD, only present if a DVD is actually in the drive
--Play
--Browse
--Rip (if audio CD)
(I don't know if any of these are really possible, but I'd like to see it like this if it is possible)
-An icon representing settings
--video
--music
--appearance
--etc.
--skin (which is also where you should define fanart, btw)
digitalhigh Wrote:Let's see...
One of the big things I want to add is an area for mundo customization. I was thinking of adding something like four custom buttons per menu, which you guys can then use to add w/e plugins wherever you want them, with the only plugs required being launcher and hulu.
if you can do through the gui via that would be frickin-AWESOME!
why in the world would you require hulu or launcher? people outside of the US can't even use hulu & a lot of xbmcers don't use launcher...
Quote:As far as having hulu jump to a specific section...I haven't tried it, but I don't think it's there yet. That would be something to ask rwParris for, along with having the plugin report content. Actually, it would probably be the same thing.
let me state for the record I'm against this, as it means I can't break the way it works later if I wanted... plus there are RSS feeds & other stuff people may want that is only available from the home screen. plus it wont work for people who aren't using my version of hulu
anyways, if you must, use plugin://videos/hulu/?mode=[TV/Movie]
Hulu also already sets content, seems to work OK in PM3.HD, some things may be a little quirky though (especially episodes, because of the folder actually being a video thing we talked about earlier)
