2009-04-03, 23:19
I really like how simple and clean the weather looks. No humidity and all that other nonsense. Just whats going on and the temp. I like it a lot.
kizer Wrote:I really like how simple and clean the weather looks. No humidity and all that other nonsense. Just whats going on and the temp. I like it a lot.
deano72 Wrote:Just downloaded the latest one on FTP (with emulators under apps). Tried to access weather supplemental. I get the option to choose 36 hours 10 days etc but it then says fetching weather and never finishes. Is that option not live yet on the version on FTP?
Cheers dean
joebrady Wrote:on the newest witht the weather on the home screen, i'm getting some
"[COLOR=FFAAA" type of text for the coming up days behind the temps. I'm also seeing this type of text in the Big Info view for movies.
Maps were working for me.
Loving the emulators stuff on the home page. For icons, you just putting an image in the folder with the same name as the rom, or is that pulled somehow by launcher? I saw that it pulled an image for the systems that I set up, but didn't see how to get icons for the games themselves...
Deano Wrote:Joe, I had that problem with the latest xbmc build, used svn prior to that and it went away again.
Digital, weather works great on home screen many thanks!
sinarquia Wrote:I'd be really mad, just updated to latest SVN just to be able to use Serenity .
Just kidding, take your time, release something you're proud of, what's a few days
joebrady Wrote:If the product is not delivered on time, then I'm not paying!
Dude, take your time, get it the way you want it, if it botheres someone, they can just suck it.
digitalhigh Wrote:So, if you're a tester, this week will be major crunch time. Save a few bugs that I'm already aware of, this is now where you can do your worst to the skin and report back here what you find. Hopefully, I can squash everything by this Wednesday and begin work on localization...at which point I will be needing some TRANSLATORS.
rwparris2 Wrote:Don't say what you don't mean...
deano72 Wrote:will download it now, and test and let you know tonight (appletv)
