2011-02-13, 19:48
2011-02-13, 20:11
Shuey Wrote:Thanks ronie!! Is there a link somewhere else for the map pack?? =\
they are available:
MapIconPack-large.zip (image size: 600x405)
MapIconPack-small.zip (image size: 256x173)
but you need to edit guisettings.xml in order to get them to show in the skin.
- quit xbmc
- open guisettings.xml and add (or replace if it's already there):
<setting type="string" name="skin.confluence.TWC.MapIconPath">\path\to\maps\folder\</setting>
2011-02-13, 20:39
Man ronie, you rock! Thank you so much for the files and info!
2011-02-14, 03:58
UK and Europe forecast videos available now.
UK - SKY News Forecast (next 24hours)
Europe - Accuweather.com Europe Forecast (if not available, it shows SKY Europe Forecast.)
For fetching Europe videos, I need to know area codes of european nations. (like FRXX...., SPXX....)
As of now, I added area codes for only Spain, Portugal, Germany, France, Italy, Greece and Netherland.
So if you live in another european nation, please let me now your area code of weather.com, and I'll add the code in add-on.
!! [UPDATED] Canada Also supported. !!
Download : http://www.mediafire.com/?wbwgidyuh2nvg52
2011-02-14, 04:08
ronie Wrote:would it be possible for US locations to fetch the local weather forecast video,
instead of the national one?
I know what you mean.
I think local videos can be fetched.
But those videos are supporting a few major cities.
For example, I'm living in Connecticut, Weather.com shows me local video for New York City and nearby areas.
If you can tweak the skin for showing two or more videos, I'm willing to work on it.
2011-02-14, 04:12
Wanilton Wrote:would it be possible for Brazil ou South America locations to fetch the Weather forecast video?
Thanks for this, great job.
It depends on whether there's any website which is providing forecast videos for Brazil or South America.
So if you can give me any information about that, I'll be happy to work on it.
2011-02-14, 04:36
still cant get it to work on Confluence skin
I am on ATV2 FW 4.21
Anyone have a solution
2011-02-14, 04:45
dallasnights Wrote:still cant get it to work on Confluence skin
Did you modify the skin yet?
http://forum.xbmc.org/showpost.php?p=722...tcount=179
2011-02-14, 05:58
[UPDATE] v.1.1.5
- added local forecast video code
video : regional forecast video url (empty if not available)
video.local : local forecast video url (empty if not available)
Only US major cities supported by Weather.com available.
Download : http://www.mediafire.com/?qf0s50gpqyh9edv
Do you think I need to make a new thread for this add-on?
2011-02-14, 07:02
brightstr Link on last post is broken
Also on the confluence mod giftie when i try and install the link you gave me install fails so I am not sure how to install other than install from zipfile on XBMC maybe you can help me or suggest another way
2011-02-14, 13:27
dallasnights Wrote:brightstr Link on last post is broken
I downloaded and test it, and it was okay.
please re-download and try to install.
You can install it just by extracting the zip file into %appdata%\xbmc\addons (vista, 7).
2011-02-14, 13:33
dallasnights Wrote:Also on the confluence mod giftie when i try and install the link you gave me install fails so I am not sure how to install other than install from zipfile on XBMC maybe you can help me or suggest another way
you don't need to 'install' the confluence mod.
just extract the zipfile in the skin.confluence folder.
it'll overwrite a bunch of skin files, so make a backup of the skin first.
2011-02-14, 14:11
brightsr Wrote:[UPDATE] v.1.1.5
Code:video : regional forecast video url (empty if not available)
way to go! :-)
noticed one small issue, not sure if it's the addon to blame or not...
if set my location to Chicago (IL)
the video url is: http://v.imwx.com/v/wxflash/CNcity.flv
and this one fails to play.
video.local plays fine though.
2011-02-14, 15:34
ronie Wrote:if set my location to Chicago (IL)
I fixed it.
Download : http://www.mediafire.com/?mivcm6chhupzh9a (re-uploaded)
2011-02-14, 16:05
I am in error in view 36 hours, this showing the temperature in Fahrenheit, not Celsius, in the other views is ok, showing correctly in Celsius, you can check please.
